Question about Whirlpool Dishwashers
Water comes in and well drain but it does not wash
    Sergeant:
  • 409 Answers
the machine is not going into the next cycle. that means it's either the timer does not work, if it's older style dishwasher or if it's newer, you may need a touchpad or control board.
Posted on Oct 03, 2008
Smart Drive machine on starting, water runs straight through into drain, thus not filling up
Most likely the water coming into the washer through the Water Inlet Valve could be siphoned out to the drain pump and out the drain hose because of an issue with the pump or plumbing. Is your washer overfilling?Is the washer detecting an overheat error? Observe carefully as to what part of the washing cycle the water is draining out. By watching the washer as it goes through its wash cycle, you can find out which part or error is causing the Washing Machine To Not Fill With Water and Keep Draining issue.
Washing Machine Will Not Fill With Water Keeps Draining How To Fix
Dec 03, 2017 | Washing Machines
Washing comes out soaking wet
Drain pump clogged or not working. When in spin cycle check hose to see that water is draining. If water is draining slowly clean pump out. If no water draining, replace pump.
Aug 08, 2012 | Hoover UltraCare HC6 145M Front Load...
Odor coming from washing machine - smells like sewer gas
The odor coming from your washing could indicate a problem with your
hot water heater or possibly your city's cold water supply line.
In some cases the odor might be originating from the drain located adjacent to
the washing machine. During long periods of inactivity, if no water is flushed
down the drain, a sewer smell will be emitted from the drain. To alleviate
this condition, just flush water down the drain.
I hope this helps you solve your problem.
Jan 17, 2011 | GE Washing Machines
Not washing dishes
check the water make sure the water is correct. fill water drain water and circulation water.
fill water comes from under sink, drain water from drain pump and drain hose ,circulation pump controls the water washing. let me know if this helps.
Mar 06, 2010 | Dishwashers
I have to drain my washing machine through a front hole drain opening in the bottom corner of machine. Water comes out, it has been left in machine. I drain my machine every six loads. WHY did Bosch design...
you have a blockage some where in the drain hose.most likely in the hose the comes form the bottom of the tub to the pump.you attach a wet dry shop vac to the end of the drain hose and remove the water this way while the vaccum is working look at the hose that comes form the tub to the pump and if it colapses then there is something restricting the water flow.also make sure to check in side the drain pump cover for any thing that is obstructing the pump
Feb 23, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Water draining makes loud noises
if water isn't draining properly the cycle will stop thereon check the drain pipe
Oct 12, 2009 | Washing Machines
Water coming out from the bottom of washing machine
Have the unit panel taken of to see where the source of the water comes from. It could come from a leak or the water overflows or is not draining. Check for leaks in the valves or hose, as you inspect where the water comes from. To check if it is not draining see after wash if the water drains while the panel is taken off. IT could be caused by the water level sensor (usually a floating device on the tray) may have been dislocated or needs replacement or a faulty water pump.
Sep 12, 2009 | Kenmore Washing Machines
My washer wont drain
It sounds like you need a 2 way valve , its a valve thats suppose to recycle the water during the wash and then open so that the water can drain. it's at the bottom of the washer right by the drain hose.
Jan 09, 2009 | Kenmore Washing Machines
Dishwashers Logo
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
