Question about Westinghouse Protégé - 72189 Fan
Trying to find parts for aModel KB451TDM Double oven byWhite Westinghouse
The top oven will not come on. A repairman came and said the thermostat for the top oven was needed but can't find the part.
I have a KB451TDM unit..... If I Can't repair mine .... would you like to purchase the themostat?
Posted on Jan 17, 2009
We have a westinghouse wall oven PON783 and the error of F08 comes up on it regularly not allowing us to use it. It now turns on & off by itself and personally i reakon its dangerous. What needs to be...
Hi Paulahogan_1, We have had the same F08 error code with our Westinghouse oven. The repairman said its because of two holes drilled in the upper casing of the oven which allow steam to get through to the motherboard - messing with the thermostat I think. The quick fix was pulling out the oven unit by undoing two screws, then undoing two more screws to lift up the motherboard, and filling the two holes with silicone. However, the steam coming through over the last year or so has caused some corrosion of the motherboard, so they're going to replace that given that the oven's still under warranty. Sounds like your oven might have the same problem, but may have suffered more corrosion over time, thereby messing up the controls? Good luck! Hopefully you've already had it fixed by now :)
Jan 23, 2011 | Ovens
After putting my 10 yr. old Whirlpool Model RBD276PD double ovens thru the self cleaning cycle the bake and broiler elements in the bottom unit stopped heating. All the controls on the panel work and the...
This sounds like it blew the thermostat on the back of the lower oven. They are inexpensive and easy to replace. You will need to uninstall the unit and remove the back panel to acess. Check it for continuity if none replace. This is a fairly common failure due to the heat of the self cleaning. Here is a link to your part and diagrams are also available there AP3055316
Sep 28, 2010 | Ovens
OVEN OVERHEATING
thermostats are not the sane. make sure cooling fan is working as this is more likely to cause the oven to cut out
Jul 23, 2010 | Electrolux EOD6390X Electric Double Oven
Zanussi electric double oven. Top oven not working.
It sounds like a faulty thermostat, because when you turn the thermostat on it should supply the oven element and the neon light, so even if the element is faulty, the neon light should still come on regardless of the element working or not.
Hope this helps.
Feb 10, 2010 | Ovens
Trying to find Thermostat on the for the top oven not heating up
Call Rick at Restaurant Parts and More. 1-888-814-1110.
Be sure to have model and serial numbers to get the correct part.
Hope this helps.
Nov 18, 2009 | Southbend SLEB/20 Stainless Steel Electric...
Grill faulty on my double oven
Creda reflection double oven had the same issue, both ovens work but the grill was either hot or cold, no temp control. I changed the thermostat first, due to being a novice and not fully understanding how things worked. it didn't help so I have changed the grill regulator,( bit that the knob fits onto) and it has solved the issue. I expect this to be the same with most top oven and grill combinations with the oven working but the grill only being hot or off.
Apr 07, 2008 | Ovens
Kenmore 47779 double oven; lower oven doesn't work after self clean
Sounds like a thermal overload has opened up during clean. It may be mounted on the back.
Nov 02, 2007 | Kenmore 47772/47774/47779 Electric Double...
Dryers Logo
171 people viewed this question
Top Westinghouse Dryers Experts
stevensmn
Level 1 Expert
Naveen Sistla
Naveen Sistla
Level 1 Expert
Are you a Westinghouse Dryer Expert? Answer questions, earn points and help others
