Question about Sony FD Trinitron WEGA KV-36HS510 36" TV
Tired with this sony tv
I turn the tv on but it goes black, i can still hear the sound but no picture. till i change the channel the picture comes back on and the colors are distorted, WHY.................
    Scholar:
  • 142 Answers
Sony doesn't want anyone to see a poor picture on a Sony tv so they have a circuit that blanks the video if there is a weak picture or any other problem concerning picture quality. My Sony factory Instructor told me this many many years ago. I'm feeling old...but anyway you need a technician. Sorry.
barneyluc
Posted on Oct 03, 2008
How to change the channel my Sony Trinitron TV turns on to?
hit menu button on your remote, navigate to channel setup menu. on the sub-menu, set channel fix to your channel that you require. now when your tv powers up this will be the default channel. if this doesn't fix your issue then try cycling through video inputs tv/video button on your remote.
Nov 10, 2013 | Sony FD Trinitron WEGA KV-24FS120 24" TV
My Magnavox TV give sound but no picture. When I turn it on the light in the bottom right hand screen goes green, then flashes to yellow and goes back to green. The screen does not change it is constantly...
You need to replace your backlight inverter.
Check that all voltages are coming from the power supply as they should. The power supply will be stamped with the correct amounts, and you just read with the multimeter to confirm.
After those check out ok, you will need to replace the inverter to "light" your screen again.
You can hear sound because the tv is ON, but the inverter isn't lighting the screen!
Hope this helps, please rate!
May 11, 2011 | Televison & Video
Change channel, lose picture. power off/on, picture appears
switched HDMI plug from HDMI1 to HDMI2 port and that solved the problem
Oct 11, 2009 | Polaroid Televison & Video
MY TV IS ON STANDBY WHAT DOES IT MEAN AND HOW DO I GET IT TO WORK I CAN HEAR SOUND AND CHANGE CHANNELS BUT NO PICTURE STANDBY LIGHT IS ON
my sony videoscope xbr was in storage for a while. I brought it home and let it warm up before I plugged it in. now the standby light blinks all the time. I have sound but no picture. any idea what to do?
Sep 13, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
TV screen goes black but tv is on. But will stay on sometimes.
i have a 2000ish 32 inch trinitron Wega and i have had the EXACT same problems as you have, except mine was blacking out more and more frequently, but yes if u changes the channel or hit return onto the same channel you're watchin the picture wil come back, but not very long, about the longest it'll show a steady picture is 1/2 hr, but it's usualy going black within every 10-15 mins or so.
I took it to a Sony approved/recommened repair shop and aftet having a look i was told it would cost $200 cd including taxes to replace a 'vacuum tube' or something like that, i wish i could be more specific anout the part. I'm still considering whether or not to go through with the repair. I might just buy a working/used newer Tube Flascreen with HD for another couple hundred dollars. If there was a newer 2003+ 32 or 36" Sony that has a good track record I would love to hear suggestions. I don' trust flat panels, way too mny horror stories, and for every 1 i hear about there's probably 10-20 more.I'll give them another 5 years or so to get their acts together.
On the other had, if i do decide to get my 32" wega fixed i will post the results and the exact pt numbers of the pts used i the repair. Your problem is exactly the same as mine, to the letter. I'm a mechanic by trade, but i have a good feeling they're not going to give me correct pt # until i have payed them to fix it. Or else i'd order the part and install it myself.
Good Luck,
Aaron
Jan 24, 2009 | Sony Televison & Video
Sony Trinitron - Picture Disappears
Hi, IK circuit is engaging which basically means the picture tube is getting tired, the only "fix" is temporary (may get another year out of it). You have to increase the "screen control clockwise".
Remove back of set, follow large black or red wire attatched to picture tube down to the flyback transformer, mounted on flyback are two black controls, one is focus (leave it alone) the other is "screen", adjust it clockwise approx. 1/4 inch, remember that this is a high voltage circuit so use one hand in the set the other hand out of the set at all times,any questions ? e-mail me back, good luck, BMW Rider
Feb 27, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony FWD-50PX1 no picture
try changing the channel with the original remote or by the tv's physical controls. It sounds like it has switch to an AV channel.
Oct 09, 2007 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
2000 27" Sony Wega
Sony has a code for those blinks indicating the problem area. Count the blonks till the pause then google Sony blink codes for the area to fix.
Jul 03, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Channnel keeps flicking like your changing channels with remote
when you say flickering??? are you saying the screen goes black and comes back on?? does the sound go out at the same time and comes bag on with the pic ? Is the sound there when this happens but is distorted. Is the pic blacked out or is it greying out with lines and twisting?? Need more info please as if its blacking out and the sound goes with it it may be going into shutdown. If the pic is getting kinda greyish with it twisting and the sound is there and ditorted then the tuner could be bad
Mar 25, 2006 | Sony KV-32S26 32" TV
Sony FD Trinitron WEGA KV-36HS510 36" TV Logo
266 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
