Question about Protron PLTV3250 32 in. LCD Television
I have a problem can you help???
Ok so my tv while i am watching it turns to a blue screen then black and the power bottom is going red then green and red then green. then the tv goes back on. ahh what do i do
It was a cheap-o price point promotion TV, lasted three years, pitch it and buy something else to replace (not a Protron).
Posted on Jun 15, 2012
This set model has power supply problems that Protron does not seem to want to fix. The problem is leakage in a diode that eventually shorts a filter capacitor...poor design. Be prepared to buy a power supply board. This is not a component quality issue, it is a P_ss poor design.
Posted on Oct 09, 2008
Problem with Panasonic PT-53WX54J 53 in. Rear Projection HDTV Television - Green Screen
You may have a component failing in the red drive stage possibly the blue as well or even the quadrature stage. A can of cold shot should help narrow the search considerably. It is also possible the red and blue projection tubes are nearing the end of their service life as well. If you have the means to test the tubes themselves, check the red and blue tubes for gas.
Dec 19, 2011 | Panasonic Televison & Video
Red, green and blue colours diveded on my TV
ok well "tube" tellys as they are called use an electro magnet to keep the picture stable and colours correct its called gaussing now if you have a speaker or something magnetic nearby it will stuff up the colors but only normally producing colors like purple,green, or white
if you have colors across the screen (that aren't caused by magnetic force) then you need to take it to a repairer or decide wether or not to buy a new one this issue can turn out to be quite hard to fix and can be expensive the different colored electron guns may be burning or burnt out causing pale color or it could be as simple as a power transistor in the H.V supply has shorted out..and causing power issues to the tube.
hope this helps,ben
Aug 13, 2009 | RCA 20F512T 20" TV
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Nov 11, 2007 | Toshiba 50H72 50" Rear Projection...
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Weird lines on the screen
Needs convergence circuit repair----give complete service # off
back so I can get part #...........T.
Sep 16, 2007 | GE 46GW 948 46" Rear Projection Television
Screen
What you may have needed to do was adjust the green & blue crt screens to match the red. Go into your picture menu adjust, turn color all the way down to a black & white px. Now adjust each crt screen so that you end up with a true black & white px. Then adjust each focus control to get a sharp px, have your tv on a channel like the home shopping network so you can adjust each crt focus one at a time for clarity by cover the other 2 up. Then go back into picure adjust & turn color ahlf way up, you should see a better px.
Jul 01, 2007 | Philips 60P8341 60" Rear Projection...
Protron PLTV3250 32 in. LCD Television Logo
99 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
