Question about Audiovox Car Audio & Video
Csi-400 remote start will not start a 1995 e250 work van. lights flash eight times with no start.
  • 360 Answers
This sounds like an open door or a light switch turned on for inside lights. check the hood also
Posted on Oct 03, 2008
Poition of o b d socket, 1989 lebaron convertable cheers baz
Your '89 has no OBD plug in. To retrieve codes, turn key on, off, on, off, on, off, and then leave on. (Cycle key 3 times on-off, then leave in ON, do not start engine.) Codes will begin to flash on the check engine light (cel). All codes are only 2 digits. Probably see a code 12-one long flash and two short flashes-code 12 is normal, disregard it. If you have to, keep repeating the codes until you get them all. Post them here, or google the codes for help.
here is a link: https://www.2carpros.com/articles/retrieve-trouble-codes-for-chrysler-dodge-plymouth-odb1-1995-and-earlier-car-mini-van-and-light-truckshttps://www.2carpros.com/articles/retrieve-trouble-codes-for-chrysler-dodge-plymouth-odb1-1995-and-earlier-car-mini-van-and-light-trucks
Nov 30, 2016 | Cars & Trucks
I need to know where the turn signal flasher unit is located in a 1995 E250 van
SHOULD BE ON THE FUSE BOX. WHAT I WOULD DO IS TURN ON MY HAZER LIGHT FOLLOW THE CLICK, THE ONE NEXT TO IT IS THE FLASHER.
Sep 16, 2016 | 1995 Ford Econoline
What other test can I perform??
What kind of remote start module ? Seams to me if the vehicle starts with remote start disconnected then doesn't start with it connectected it's a problem with the remote start electronics . Is it aftermarket junk ?
Jun 10, 2017 | 1990 GMC K2500
Eight red flashes
Eight flash indicates a protection to horizontal circuit. Might be a main board fault. It will be best to contact any service technician to make it confirm. It you're sound in electronics, check the link given here. http://electronicshelponline.blogspot.com/. It has blinking codes and fault detection procedure to many brand TVs, Pull up older posts there. See them either by pull up posts by its left side bar, or see it in 'Timeslide' option.
Jun 18, 2013 | Sony KDL46HX850 46 1080p LED 3D TV KDL...
2006 ford e250 van\r\rear tail lights dimmed and now dont work(.)
check the fuses and relays under the hood next to the battery. if they still dont work it might be in the wiring or if it has a tow package it might be in the trailer wiring
Feb 09, 2010 | 2004 Ford E250
1995 toyota camry light on
One of your rear ligh bulb are out. Turn all your lights on and then step on you brake have someone do it for you and look at all the light there is a bulb out in the rear. Hey If I fixed ya give me FIX-YA rating thanks. GOOD LUCK
Dec 18, 2008 | 1995 Toyota Camry
Dash lights flash when doors open
see if you got a bad ground or a short thats the most likely cause
Nov 21, 2008 | 1995 GMC Safari
Driving along interstate 90 and all of the sudden, my E250 seems to be losing power and the yellow service engine soon light comes on and a red light that looks like oil. the van's fan comes on and the...
I'm getting the same message, when I'm driving at about 65 mph van starts losing power, kind of "coughing". I've been told that could be either fuel inyector or the need of a good tune-up. I'm taking my van (2002 E250 V8) to the dealership, they have the special equipment to zero into the problem and fix it,
Aug 05, 2008 | 2004 Ford E250
Car Audio & Video Logo
204 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
