I have a Panasonic and I am not getting any power to the T.V Is there a reset button
    Scholar:
  • 142 Answers
No, sorry. No reset buttons since the '70s on tv's.Good Luck!
barneyluc
Posted on Oct 03, 2008
How to do lamp reset on panasonic pt-lb50u projector.
To reset the lamp hours, turn on the projector. Then press Menu and use the Up/Down arrows to highlight Options. Press Enter then highlight Lamp Runtime. Press and hold Enter for 3+ seconds until the Lamp Runtime screen is displays. Press the Power button (any other button cancels the reset). When the Power button LED turns red, unplug the power cord to the projector. You can either use the remote or the controls on the projector. Reconnect the power cord after a few minutes.
The reset instructions are on page 62 of the user manual. The manual is available from Panasonic here: https://support.panasonic.co.nz/docstore/PT-LB50U%20Operating%20Instructions.pdf .
I hope this helps.
Jun 18, 2016 | Panasonic PT-LB50U Multimedia Projector
How to reset the lamp time in Panasonic projector model vex 500
  1. Press the Power button so that a picture is projected onto the screen
  2. Press the Menu button to display the "Main Menu", and then press the F or G button to select "Option"
  3. Press the Enter button to display the "Option" menu, and then press the 5 or 6 button to select "Lamp Runtime"
  4. Press and hold the Enter button for approximately 3 seconds
  5. The "Lamp Runtime" will change to "Time Reset [Power Off]"
  6. Turn off the power and disconnect the power cord
Get A Quote for a Panasonic Projector Lamp or to Replace your Existing Projector Lamp now.
Here are some links that will help you.
Change the Panasonic PT AR100U projector lamp in 3 easy steps DLP Lamp...
How to Reset Panasonic Projector Lamp Timer Projector Lamp Services
May 29, 2016 | Panasonic Office Equipment & Supplies
How to reset lamp hour of panasonic pt lam1 lamp
hi,
Do the following for reset the lamp hour timer of Panasonic PT-LM1U
1. Power ON the projector. (wait for the display)
2.Press the menu button to display main menu and then press the up arrow or down arrow to select OPTION2.
3. Press the Enter button t display the OPTION 2 menu.And press the up/down arrow to select LAMP RUNTIME.
4. Press and hold Enter button for approximately 3 minutes.
5. The LAMP RUNTIME will change to TIME RESET. (power off).
6. Turn off the power.
OK
Jul 18, 2011 | Panasonic ET-LAM1 Projector Lamp for...
What will I do to reset lamp timer for my Panasonic PT-AX200 model
Read very carefully this is the only solution to reset lamp timer
1. Connect the mains lead to the projector and a mains socket, and switch the MAIN POWER on. 2. Press the POWER button.
3. Press the MENU button to display the menu.
4. Select the OPTION menu and press the ENTER button.
5. Select LAMP RUNTIME.
6. Press and hold the ENTER button for approximately 3 seconds.
7. The confirmation screen will be displayed and select OK.
8. Press the POWER button to turn off for resetting the duration of the LAMP RUNTIME.
9. Next time when you POWER ON the projector the duration of time in LAMP RUNTIME is reset to "0 H".
Jan 06, 2011 | Panasonic PT-AX200 LCD Projector
I need code number for a Panasonic tv
Hello
To get Panasonic TVs to factory settings do the following.
Put it in standby mode and press "POWER" and "ACTION" button at the same and then turn the power off. The set should reset to factory defaults, and reset V-Chip.
Nov 09, 2010 | Panasonic Televison & Video
How do I reset the lamp hours on the Panasonic LB20u projector.
Press the MENU button to display the "MAIN MENU", and then select "OPTION".
Press the ENTER button to display the "OPTION" menu, and then select "LAMP RUNTIME".
The "LAMP RUNTIME" will change to "TIME RESET [POWER OFF]".
Turn off the power and disconnect the power cord.
This will reset the cumulative usage time for the lamp unit to "0".
Oct 25, 2010 | Panasonic PT-LB20U Multimedia Projector
Panasonic Lumix Fx35 Malfunctioning
Go into the setup menu and scroll to "reset"...follow the on-screen instructions. This procedure might work. If you can't get into the menu because of malfunctioning buttons, try a manual reset...remove the card and battery...press all the buttons...insert the card first and then the battery...turn it on.
Sep 14, 2009 | Panasonic Lumix DMC-FX35S Digital Camera
How to unblock v chip in panasonic panasonic CT 27SL15 TV
Push the power button and the action button on the tv set until it shuts itself off and this will reset your tv. You cannot use the remote to reset...must use the actual tv buttons on the television set.
Jun 17, 2009 | Televison & Video
Cant turn off panasonic PIP
To turn off the "stuck" pip on a Panasonic tv without a remote, turn off the tv. Then hold down the "Action" button on the front of the tv and press the power button. This will activate a reset and self check of the systems and voila! The pesky pip screen will be gone! This is on an approximately 10 year old regular crt "CT-xxxxx" series tv.
Jun 12, 2008 | Panasonic CT-36D32 36" TV
Lamp reset
This also works for the Panasonic PT-61LCX65. You hold the volume button down on the projection display, then hold down the Split/ DVD button on the remote control at the same time. I just did it after reading the advice posted. Thank you!
Oct 11, 2007 | Panasonic PT-50LC14 50" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
