Question about Proview HX303 30 in. HD-Ready LCD Television
No picture only sound
I have a 32 inch lcd proview tv and the picture wont show but you could hear the sound clearly, what could i do to fix this
  • Anonymous Jan 20, 2009
    30 inch proview hx-303 when turned on it immediately shuts off but you still hear sound ! screen goes black !
    Sergeant:
    Champion:
  • 223 Answers
I think you might have dry solder joints on the line output stage but if this does not solve the problem then it is a faulty component on the line output stage. If you can do it check for yourself otherwise find a competant technician. Hope this helps.
Posted on Oct 03, 2008
Hello, i am no pro but i have a 30 proview that did the same thing and i went through changing perfectly look capacitors and didnt not sovle the issue. i slowly kept trying to figure it out and ended up looking into the transformers(rectangle black things) on the inverter board after changing all the capacitors on the inverter board that did nothing. the transformers checked out fine but would jump around -so i read online that sometimes the solder joints dont do so well from the factory.so i did my best to clean all eight legs on each transformer and resolder. THe tv works fine after that-lucky?maybe but you never know-by the way my tv would go on perfect for anywhere from 5 sec to 2 ;min before shutting off video-
Posted on Jul 25, 2010
I have a white westinghouse 40 inch tv model vr4090 and the tv wont come on it shows the power indicator turn from red to blue but no picture or sound
Westinghouse tx-42f430s wont turn on fix repair - YouTube
? 5:29
https://www.youtube.com/watch?v=DdfLu5RdVEQ
May 12, 2014 - Uploaded by After Hours Tv & Pc repair
Westinghouse model # 32H1G1 won't turn on , but If I unplug the TV and wait for a ... -tx-42f430s-42-inch-lcd-tv-appears-bricked-595806.html ... I have a Westinghouse 40" TV that is working, but sometimes it won't turn on.
Westinghouse LED LCD TV Repair - YouTube
? 12:32
https://www.youtube.com/watch?v=DGg5iuFEfdM
Feb 8, 2014 - Uploaded by INSIDEHARDWARE CHRIS
Westinghouse Model: LD-4680 Similar (LD4655VX LD4255VX ...Samsung LCD TV Repair - TV Won't Turn On - How to Replace Power Supply ...
40 inch Westinghouse lcd tv black screen help - YouTube
? 1:39
https://www.youtube.com/watch?v=tKLRihGgZAs
Nov 21, 2011 - Uploaded by Jason Flynn
Dec 19, 2015 | Westinghouse Televison & Video
SAMSUNG TV LA32D403E2 sound ok, does not show any thing on display
I have a LCD 32 inches LA32D403E2, the sounds are clear but the display picture is completey not there.
Please let me know if it can be resolved. The warranty expired 1 year ago.
Apr 07, 2013 | Samsung LA32D403 32" HD LCD MULTISYSTEM TV...
My Proview RX-326 lcd tv Has sound & picture but Picture mix colers brite
There is some incompatibility issue. Did you check the format is set correctly for PAL/SECAM etc.?
Jul 28, 2012 | Proview PA-32JK1A 32 in. LCD Television
I have a 40" Proview LCD flat screen tv Will it
This problems i fixed it before for other LCD tv models.The tv Tuner signal board is the causes and the problems.That the board,where the incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.Will solved this problems.
Nov 24, 2010 | Proview PA-32JK1A 32 in. LCD Television
JK321 32" High Definition LCD TV no picture has vertical lines on left side of screen, is it worth fixing.
well this is common on your model and could be a few different things. one is the video circuit and a cost would range around 100.00. the other is a weak picture tube this would cost more than the TV new. sometimes when it is the tube we can adjust it but it does not always last long. sounds to me it would be better to invest into a newer TV in this case.
good luck :)
Jun 02, 2010 | Proview PA-32JK1A 32 in. LCD Television
My Proview LCD tv is black but I can hear everything sometimes the picture comes back on but goes back out...what is wrong with it?
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board u will get ur picture back.Tries Shopjimmy.com,Ebay.com for a refurbish LCD backlight inverter board.It a long shape board.
Feb 15, 2010 | Proview PA-32JK1A 32 in. LCD Television
Proview 32' without picture or sound
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
Jul 07, 2009 | Proview PA-32JK1A 32 in. LCD Television
No picture
bad capacitors in the power board area these can be replaced and soldering is required to replace them
Nov 30, 2008 | Proview PA-32JK1A 32 in. LCD Television
Visio 32 with very little audio
If under warrenty then call vizio!
I believe its sound board but I could be wrong.
No easy fix, the part is 220$ service is 210 a used LIKE NEW 42-50 inch is 500$ shipped !
Sorry to say this but it happened to my 50 inch just before I heard a pop then it would not show a picture and had no sound.
Call them up if your tv is less then 1 yr old!
May 19, 2008 | Vizio L32 32 in. LCD HDTV
Ilo plasma 42 inch Crawling Moss
I wish I could help you ,, Can u help me ? I don't have the manual for my 32 ilo tv and I think the brightness need to be adjust -- am only hearing sound, not seeing any picture .
Jan 22, 2008 | iLO 3200 32 in. LCD Television
Proview HX303 30 in. HD-Ready LCD Television Logo
440 people viewed this question
Top Proview Televison & Video Experts
Tony
joncin91
Level 1 Expert
Are you a Proview Televison and Video Expert? Answer questions, earn points and help others
