Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Reset chainsaw brake on a husqvarna 455 rancher
I just replaced all the parts for the chain brake and I can not get the cover that goes on top spirng on because I can not seem to press the spring enough to set it in the unlock position. I have tried to screw cover on and then with the use of pliers reset it as I had been instructed to do by a local repair shop but it did not work. seems as though this is a common problem from what I have read on the internet but noone yet has the answer to solve this problem.
  • Anonymous Oct 23, 2008
    This is a hard thing to do. Place the locking part of the cover on the to the saw as best as you can. ( the bottom will not fit as you know ) you have to press hard to make the interlock fit into the cover . Then move the bar forward to get the brake to release. hope this helps.
  • Wim Wetzel
    Wim Wetzel Jan 19, 2014
    Remove the chain brake handle and attach the cover back on briefly and pull back on the handle to disengage the mechanism. Reinstall the handle and the cover will fit properly again. Always unlock the chain brake before replacing the chain.
You removed the cover while the chain brake was in the locked position.  The plier method will be a pain in the ***, as you cannot get enough leverage to twist lock or spread the spring.   I've accidently done this myself and found a much easier way to solve the problem.  Just remove the chain brake handle by unscrewing 2 screws.  Stick the cover and the handle together as they would if it was correctly assembled and twist.  You should be able to unlock the chain brake and it will now slide right on.
Posted on Apr 14, 2009
  • peter godwin Sep 16, 2011
    This is the way to do it! Dont bother messing around with clamps!
  • 16 Answers
Put on your cover over spring with brake in lock position and do not use a pliers to remove brake .leave bar off saw and keep side cover pushed in on front into brake lever and pull back on lever to unlock brake
Posted on Nov 11, 2008
This is apparently a common problem. The round spring that goes around the flywheel is fighting the cylindrical spring from the handle. First remove the three screws that hold on the plastic cover. This will reveal the cylindrical spring. You can pop this out with a screw driver. Now you should be able to push the assembly into the locked off (the ring spring is as big as it can be now and will fit over the flywheel again. Now take the whole side assembly and clamp it to a worktable or counter. I used a big wood clamp. Now using a small clamp you can compress the cylindrical spring back into place. I used a heavy flat blade screwdriver to clamp against. The other end of the clamp fits against a piece of steel rod (I used an allen wrench) that goes into a hole at the outside end of the spring. Crank the c-clamp to compress the spring and when its compressed push the end into the slot. To hold it in from popping out quickly put the plastic cover back on. The spring may bend up but tightening the screws will keep it down in the groove. This is how to do it.
Posted on Dec 08, 2008
See shaddymacdog (14 Apr 09). Brilliant solution Shaddy, thanks!
I did the fix in almost no time. Clamping the cover in my table vise
(with the spring facing up) allowed me to easily attach the handle and
open the spring. Simple solution from Shaddy, but I didn't think of it.
Posted on Jun 20, 2009
Shaddymacdog's solution did the trick. I assembled the handle and matching cover gear together and held them in place by putting a c-clamp snuggly over them which made them easier to turn. You need a fair amount of torque to reset the spring.
railer
Posted on Apr 17, 2009
    President:
  • 2,220 Answers
Belinda Why didn't you post a new question? An IPL for your saw with the detail you want can be found here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter “371” in the “Enter product” window (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Illustration A is the chain break and fairly detailed.
Reset Chain Brake by Dolfoff
Please follow this link, http://www.fixya.com/support/t3102817-re_install_side_cover_after_chain
cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button
If you don’t have a vise a large C clamp to a work surface might work, you may still need a block or two of wood. HTH
Lou
Please if you need more clarification or photos try here:
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
It’s a collection of chainsaw enthusiasts that will be willing to send you some photos. I did a search for 371, she gets good marks and many hits.
Posted on Oct 29, 2009
SAWFIX has it right. An additional note. The notches inside the brake handle hinge have to engage the three leaves that **** the spring. I HAD TO PUSH DOWN ON THE COVER AND MOVE THE HANDLE OUT TO ITS EXTREME POSITION AND WIGGLE IT UNTIL I FELT THE LEAVES ENGAGE. mOVING THE HANDLE REARWARD RELEASES THE BRAKE.
Posted on Jul 25, 2012
See shaddymacdog (14 Apr 09). 10 min. fix! Thanks shaddy!!!
Posted on Jul 18, 2010
Oi anybody out there with a moody 371xp husqvarna chainsaw. basically i need detailed photos of the chain brake etc
3 Suggested Answers
philwalker78
  • 608 Answers
SOURCE: why would my chain on
Hi, have you made sure you haven't knocked the chainbrake on? Regards Phil.
Posted on Sep 18, 2011
dontbother10
  • 2220 Answers
SOURCE: 455 rancher chainsaw does not pump oil to the chain
Check your operators manual carefully many new Huskys have a 3 position oiler with 1 being the least and 3 the most. It is easy to turn beyond the detents and once done oiler problems abound.
Is this a new saw? Still under warrenty? If yes the dealer where
you purchased should be willing to verify proper oiler operation at no cost. If purchased from a big box store or on line all bets are off.
HTH Lou
Posted on Sep 09, 2009
How to reassemble chain brake on an Echo CS-350T that jammed and was pulled apart by someone else?
From what I see you will need assemble thing leaving the main spring and brake cover off. Before attempting to put the main back in install a clutch drum inside the brake band. Then you slip on the main spring and pry the end on with a flat blade screw driver. Now install in the cover for the spring and brake. Reset the chain brake and remove the drum.
Now install the chain brake on the saw and test. Do not trip the chain brake without the clutch drum in place. If these are anything like the Husqvarna version after they get worn they will get where it is nearly impossible to reset.
Echo CS 350T Chainsaw CS350T Parts Diagram Page 7
Jan 12, 2015 | Echo Garden
Tip
Replacing brake band on Husqvarna 357/359/340/345/350/346/445 and many others
Before attempting to repair any chain brake, eye protection should always be worn, these machines all have an out board chain brake, known as a knee link brake due to its actuating mechanism, start by makeing sure the brake is off, by pulling the brake handle fully back to the top handle, now remove the bar securing nuts, remove the brake/side cover, the hand guard stays with the saw, so the cover is quite difficult to hold when removing the spring, so take two 8 mm bolts, clamp the hex heads in a vice, spacing them out the same as the fixing holes in the brake, now fit the brake /cover band up onto the up standing bolts, use the two bar nuts to secure the brake to the bolts, now insert special tool part no. 502522202 into the actuating quadrant and turn to activate the brake ( this will remove much of the spring tention ) if you do not have the tool you can remove the hand guard from the saw and use that, or a sturdy pair of long nose pliers, now remove the cross head screws from the spring cover, edge the back of the spring up enough to insert a suitable screw driver into the end, lever the spring up and onto the screw driver shaft ( this will stop it flying out ) remove the c clip securing the actuating quadrant to the brake cover, gently lever out the roll pin in the anchor end of the band, the band will now lift out of the cover, remove the single cross head screw securing the knee link mechanism to the band. Refit the new band into the knee link and re fit the screw, re fit the quadrant onto the post in the cover and re fit the e clip, press the anchor end of the band back into the cover, insert the spring back onto the knee link spigot, compress the spring and push it back into the cover, the best way to compress the spring is to use a good pair of long nose pliers, push the closed jaws into the end of the spring ( this will stop the spring flying out ) now push the pliers in to compress the spring against the knee link, and back into the cover, refit the spring cover screws, you now need to load the brake before it can be put back onto the saw, use the special tool, or the removed hand guard to do this, it will take a fair amount of force to re load the brake, once loaded re fit to the saw.
on May 12, 2011 | Garden
07 mcculloch 3516 has new bar and chain when running chain will tighten to the point it will bog motor down
Check your brake spring. It may be broken causing the brake to drag. Plus replace melted side cover.
Dec 06, 2013 | McCulloch Garden
Problem chain / break cover chainsaw
Hi, hold the cover in a vice where the bar nuts normally tighten up to, then pull the chainbrake lever back in the direction the handle bar would be. You will feel a click and the lever will stay back and the brake band will be released. Then refitted cover to the saw. Regards Phil.
Aug 20, 2012 | Garden
Hello. I own a Husqvarna 350 chainsaw. 25 minutes of use and the chain popped-off the bar. After inspecting the chain I noticed that some links were not bending, thus making me believe that the oil...
Hi
I have seen something similar on my own saw some time ago. Probably two things have gone wrong. First there is something wrong with the transfer mechanism between the clutch handle and the brake spring. I do not remeber the exact detailsy, but there is a plastic part engaging a metal part in the transfer mechanism between handle and spring, that tends to wear out so that it will not release the spring when moving the brake handle. (look at the engaging mechanism where the handle is turning on its axle/bolt) If you take off the chain guard / cover you should be able to follow or see this mechanism and use a screwdriver and a pair og pliers and try to move the transfer mechanism so that the brake can be set to the released position. Once this is done the brake mechanism/cover can be taken off and you can clearly see what part that needs to be changed (I think it was the handle itself, due to worn out enganging plastic lugs). The brake spring obviously needs to be disengaged when assembling and disassembling.
Whent it comes to chain lubing, you can try to clean out the oil tank, blow through the hoses and look for dirt and particles clogging the lube circuit. As a test, when the lubing is working correctly, the chain should throw off visible amounts of small drops of oil from the tip of the blade, when you let the chain run at working speed just in front of a piece of paper or cardboard. If no oil stains appear, the lubrication is failing and overheating and excessive wear will occur. Use the correct oil too. The wrong type of oil can potentially ruin the lube circuit. There is a small plunger-type oil pump that is driven by an excenter located near the inside of the chain sprocket drive shaft. You can easily test its function by pressing the plunger carefully and see whether oil comes out on the lube oil opening. It should be cheap to replace if broken.
I hope this can help you.
Jul 15, 2011 | Husqvarna ChainSaw 18 in Bar 32 HP Model...
How to remove starter from a 2005 sportster custom
Disconnect the positive battery cable. Drain the primaary and remove the derby cover. Take the spirng and the locknut out. Go to the bottom of the primary cover and loosen the lock nut on the primary chain adjuster and back the adjust out a good little bit. Remove anything that's in the way of the primary cover and remove all the bolts in the outer cover. Turn the clutch adjuster clockwise as your remvove the cover.
On the other side of the bike, disconnect the positive battery cable from the starter and remove the exhaust from the bike.
Back on the left side of the bike, remove the two bolts just above the clutch assembly. They are different lengths so remember which goes where.
Reassembly is the reverse of the disassembly. When you put the outer primary back on, turn the screw counterclockwise until you can put the bolts back into the primary cover. Once all of them are in and tight, turn the screw counterclockwise as far as it will go and then go back clockwise 1/4 turn. Put the locknut, spring, and derby cover back on the primary. Adjust the primary chain by turning the screw inwards until you have 5/8" to 1/2" inch of up and down play on the chain. Feel of it throught the upper inspection hole. Once finished, add one quart of primary lube to the primary.
Good Luck
Steve
Oct 01, 2010 | 2005 Harley Davidson XL 1200 C Sportster...
Husqvarna 136 chain brake handle spring.
You can get an IPL here:
HusqvarnaUSA.com
I don't think this has the detail you need.
If it were me I'd visit my friendly neighborhood Husky chainsaw seller (not Big Box Store) and ask to look at the clutch cover with the brake installed (take a camera). I'd probably ask for a quote for their repair too. HTH
Lou
Your model is no longer sold. The seller will know what model replaced it and may be willing to explain the repair procedure for your saw you. Take the cover and loose parts with you.
Jun 27, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
18" husqvarna chainsaw
It sounds like your chainbrake was on when you took off side cover .To get brake off place cover against saw with bar off so cover fits into brake lever and pull back on lever
Oct 14, 2008 | Husqvarna Chain Saw 20" Bar
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
8,090 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
