Won't turn on/
Was typying and it just quit, and will not do anything now. Can you help?
  • cldgordon Oct 03, 2008
    You told me there would not be any additioal expence for today. If the problem was not solved.
    Cora
  • cldgordon Nov 01, 2008
    Still have the same problem, nothing is solved. Tried differt outlet that works with other things, checked fuse, checked tape. and nothing seems to work. Cora
    Scholar:
  • 183 Answers
First check the outlet by plugging something else in it that you know works. If the outlet isn"t working, plug the T/W into an outlet that something else is plugged onto that is working.
Some machines have fuses that blow out for no apparent reason. Some fuses are easily replace by the user and some need to be done by a technition, depending on the machine.
Also some machines have a sensor, so that when the ribbon is at the end, the machine simply quits working.
Any other problem would require the machine to be looked at by a qualified technition.
Posted on Oct 28, 2008
2004 ford explorer quit while running, and won't turn over.
check coolant and oil level.check battery and connection,starter,fuel filter,fuel pump,spark plugs and coils.
Feb 27, 2013 | 2004 Ford Explorer
I'm getting this message "The operation could not be completed. No other information is available about the problem." I had a paper jam..fixed it and now it won't scan anything without that er
1. Quit neat app.
2. Turn off scanner.
3. Unplug scanner from computer and outlet.
4. Wait a minute.
5. Plug scanner into outlet and computer.
6. Start Neat app.
Hope this helped.
Feb 21, 2013 | Neat Company NeatDesk Scanner for Mac
I have 2001 mercury courage replace alternator 2wks ago ran great. Now today will not start. Tried to start and it would click when I turned key now won't do anything doesn't have any power....
Could quite possibly be you have a bad starter. I would have it tested. Could also be a bad battery. If, when jumping it, you used too high of a voltage, could have shorted out a wire somewhere
Oct 27, 2012 | Cars & Trucks
93 nissan altima died on the road, won't turn
If it just up and died on the road and will not turn over now even with a jump it almost sounds like you engine may have locked up on you. But it is hard to tell without actually seeing the car. For your sake I do hope it is a different problem. I would like to help you out more. Can you be more specific as to what the car did when it quit on you? Did it make any sounds or anything? Did it quit when you where actually driving or were you sitting some place at an idle? I look forward to hearing from you.
Aug 27, 2011 | 1993 Nissan Altima
So driving down the road my transmission just quit working completely, no forward, no reverse, it was just like it was in neutral, fluid level fine and bright red, and my turn signals and 4 ways also...
I would solve the electrical issues, before I would let anyone
pull the transaxle out
A trans shop is not the place to be for that
I used to own one
They will rebuild the trans & you will still have
the other problems & they won't have anyone
that can help
Aug 22, 2011 | 1998 Ford Taurus
I have a Kenmore 80 series Heavy Duty Quit Pak Dryer and it won't turn on. No sound or anything
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 27, 2011 | Kenmore Dryers
I can not type anything, sign up. the key pad is confusing tyoing dfferent things
Your keyboard has a "keypad-lock" key, to switch the keys from typing letters to typiing numbers in a layout like an adding machine.
Or, since Windows supports "foreign" keyboards (German, Spanish, French, Norwegian), where the layout of the keys is different, use the "Regional" settings inside "Control Panel" to select the "USA English" input-method.
May 30, 2010 | Computers & Internet
Won't allow me to print
in the start search typy printers & hit entre then u will get the printer page open then try n make your current print default by right clecking in your printers icon, u will no longer have this problem
Mar 30, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I cant find the schematic diagram of Sony CD changer CDX-757MX
typy in on a google search sony cdx-757mx manuals or how to if i remember right it was e-support sony// i saw on there about a week ago//
hope this helps
Sep 29, 2009 | Sony CDX-757MX 10-Disc CD Changer
Worm turning files into *.exe
hie dear,
this typy of infection causes due to a virus if we are using various types of mmc, mobile cards to a pc. u need to install an antivirus and if possible format ur pc first.
after installing the antivirus, always remember to scan the cards, pen drives and other devices before using.
if u want free antivirus then avira and avast are good.
bunty
May 05, 2009 | Microsoft Windows 2000 for PC
75 people viewed this question
jasbo
jasbo
