Error code 6A00 on my Canon Pixma MP 830 printer
  • 8 more comments
  • jjpy76 Oct 03, 2008
    The problem is not computer related as the Canon pixma MP830 is a stand alone multifunction printer/copier/fax/scanner. this problem occurs even when not connected to the computer.
    I don't know .What's the berret
    No paper jams it just would not start
    No the sponge on the purge unit is in place & moving the cart car didn't do anything
    no I turned it up side down ( And shook it all about) no luck
  • jjpy76 Jan 04, 2011
    I eventually solved my problem .It was a jammed / broken gear in the purge unit. I replaced the purge unit and all was good. It was not a simple job as the purge unit was nearly the first thing to be put in the printer when it was made!!!!!
  • 19,396 Answers
Effectively error 6A00 means 'Mechanism jam code' and is not computer related.
Most common cause for this is paper stuck inside. Open all the printer doors and check. open the door at the back and check moving the rollers. Turn printer upside down and shake it gently to find out if there is any foreign object inside
This can happen because of a foreign object or paper inside the printer, or one of the mechanisms snaps out of place and jams, or a sensor wrongly detects a jam.
First unplug printer power cable for ten minutes, to drain power completely, and reset the printer in the eventuality that the unit is just stuck with the error code.
Try also holding the start button for ten seconds to reset the printer.
Other trick is unplugging the power and holding start button (if there is reset hold reset button) while plugging back, this should reset Pixma to factory defaults.
Try power cycling the printer as above twice, if it does not work, then remove and put back the cartridge. Try moving back and forward the in carriage on the rail, the ink carriage stuck on the rail, or the traction belt stuck, or the return motor are also common cause for error 6A00.
If it still does not work, it means that the printer has really a problem with the mechanic.
Try all the above once more, just in case, paying attention to paper inside, and checking if ink carriage is stuck.
If it does not unlock use the phone number listed on the owner manual and call a technician.
The printer must be taken apart and re-assembled, and probably some part replaced to fix the problem.
Posted on Oct 03, 2008
  • Ginko
    Ginko Oct 03, 2008
    Note: 6A00 is not necessarily a problem with the sheet feed unit, 6A00 is mechanic error, can be paper jam, print head jammed or any other mechanic error of this kind.
  • Ginko
    Ginko Oct 03, 2008
    Many experts are reporting solutions from this blog: Canon PIXMA MP800 Error 6A00 - fixyourownprinter.com.
    They are all testimonials from users that had same error, but they are not all necessarily accurate.
    Have a look at the blog, sure it can give you an idea of the scenario when you get this kind of error.
    Sergeant:
  • 208 Answers
6A00 is a problem with the sheet feed unit.
The print head carriage would have been stuck and try manually moving the carriage a few times and the problem would be resolved.
Try blowing some compressed air around hoping to clear any foriegn objects.
Notice whether some piece of torn paper lodged inside.
Hope my info solves your problem........
Thanx for using fixya.
    Guru:
  • 859 Answers
You have a stuck print head wiper blade.
When the printer starts up, a white squeegee device wipes the print heads off and frees the head from any gunk build up from the previous printing jobs.
If the printer hadn't been used for a while the wiper can get more or less glued to the print heads.
You will need 99% Isopropryl Alcohol, q-tips, paper towels. A flashlight, Old newspaper.
Turn off the printer and unplug it from your power source. Place several sheets of the old newspaper under the printer.
Open the top lid. Move the print carriage to the left. Using a flashlight locate the white wiper blade squeegee. Wipe this area down with the Alcohol and Q-tips. It will take several attempts. If the wiper blade seems glued, use a flat head screwdriver to gently encourage the wiper to release towards the rear.
Once the above is done, soak a paper towel with the alcohol and wipe down the print head rest assembly and print carriage down to clean everything of ink. This includes any waste pad you see that are quite full of dry ink. If needed you can use a pair of needle nose pliers to get the waste pads out. Place them in a disposable bowl and pour alcohol over them . Once soaked through take them out and squeeze them dry.
Move the carriage to the right replace the cover lid, plug the printer in and you are ready to print again.
Good Luck, and let me know how you make out.
  • 4,889 Answers
6A00 is a problem with the sheet feed unit.Move carriage back and forth manually.If it still doesn't work then checking and cleaning paper feed might help. Also make sure all rollers are free. If none of this works some people have reported that they fixed it by turning the unit upside down.. May be worth a try before sending it off for service..
  • 1,879 Answers
If you had a recent paper jam that caused that error code to show up on the LCD screen, you need to have it serviced.
  • 6,487 Answers
Try doing this:
1, With the printer unplug remove the ink cart to the right.
2,Plug in the printer ,Press the POWER button, Do not release the POWER button ,and then press the RESUME button twice in succession .Now release the POWER button ,press the RESUME button 4 times .
3,The beeper may sound once ,Then With the printer unplug ,after that reset the printer electronics ,open the printer and this process is finished
Hope that helps..........
  • Mark Gil
    Mark Gil Oct 03, 2008
    Try doing this:
    Master:
  • 351 Answers
Dear JJPY,
you may have damaged one of the paper fill sensors when you took the berret out, take it to a Authorised Service centre.
Regards
ScorpionAkku
    Master:
  • 763 Answers
Try to uninstall and reinstall again the cd driver camed with your printer and reboot after you done it. check also the cable connection. if still the problem persist then try another installation by the control panel and look for add hardware. it has an instruction and follow the step by step.
CHARCOIS
    Genius:
  • 3,422 Answers
6A00 is a problem with the sheet feed unit. try to on/off the printer......change the position of the printing head.....the cartridges.....
If you see on the right (inside printer)...a small 1/4 cm rectangular "hard sponge" in a unusual place try to replace it
Then change the position of the cartridges again
  • Priya darshan Oct 03, 2008
    Let me know the result.
Canon MP 830 showing error code 6A00. alarm light flashing, no lights on ink cartridges.
6A00 is AP position error.First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 29, 2009 | Canon Office Equipment & Supplies
I have a error code 6A00 and alarm light flashing on my canon pixma mp 830
Canon lists the solutions for the error 6A00 as...
1.
Press ON/OFF switch to reset the multifunction device
2.
Press Stop/Reset and ON/OFF to reset the printer
3.
Removing paper jams
4.
The MP830 may require repair
5.
Unlock the scanner lock switch (MP830)
Oct 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
MP 830 flashes between the copy button and hazard light(triangle symbol with squiggle in it)12 x.then starts the same 12x after a short pause.It will not do anything..whats the problem?
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Sep 03, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My canon mp 830 all-in-one printer says 6A00,
no need to reset your printer, the things your should do is you just open the over at the back of your printer, then you can see a paper hang on, then please remove it, then try to print, if it does not work open also the tray which is your bond paper stored, just see if there is also a bond paper hang, then remove it, then print again, that the cause of paper jam
 Good Luck!!
 Nice
Jul 01, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon mp 950 has a error code 6A00
There is a problem with the carriage lift mechanism.
Probale causes
1.PR Lift shaft assembly
2.Sheet Feed Unit
3.Logic Board
Only your local Canon Dealer will know
Mar 12, 2009 | Canon Pixma MP950 All-In-One InkJet...
On my MP 830 Canon Error on my computer 5C10 Error on printer screen 6A00 Print head moved top the far right and appears to be jammed Had removed and cleaned printhead, reinstalled printhead and inkwells...
Hi
This happens a lot
Solution 1:
Solution 2:
Solution 3:
Feb 27, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon Pixma MP 810
Try moving the cartridge unit back and forth a few times, this usually works.
Jul 15, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Pixma 830 error code 6A00
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Dec 24, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon mp 830
The copy and alarm buttons are flashing.  On the led screen there is an error code that says 6A00 and I can't get the printer to work.  Help!  I've already unplugged it for a while, didn't work.  What next?
Oct 28, 2007 | Canon PIXMA MP830 All-In-One InkJet...
88 people viewed this question
k24674
