HELLO THERE AND WELCOME TO FIXYA:
tHERE ARE A FEW THINGS THAT YOU WILL WANT TO FIRST ENSURE
FIRST ENSURE THAT THE WATER IS ACTUALLY TURNING OFF AT THE INLET VALVES ON THE MACHINE IF THESE VALVES LEAK THE WATER WILL CONTINUE TO ENTER THE MACHINE AFTER IT IS FILING THIS IS THE MOST COMMON PROBLEM ON THESE
HOWEVER IF YOU HAVE ALREADY PINPOINTED THE WATER LEVEL SWITCH AS BEING FAULTY THEN YOU CAN REPLACE IT HERE IS WHAT IT LOOKS LIKE IN THE IMAGE BELOW BE ADVISED THAT THEPART MAY BE A LITTLE BIT DIFFERENT THAN THE ACTUAL ONE ON YOUR UNIT SO I WILL POST A FEW OF THEM
TO REMOVE THE PART YOU WILL NEED TO REMOVE THE COVER ON THE CONTROLE PANEL AND IT SHOULD EXPOSE THE TUBE THAT GOES FROM THE CONTROLE PANEL TO THE TUB WHERE THE PART IS
Hi
If the washer won't fill you'll need to check for the water
inlet hose, the water inlet valve and the pressure/water level switch assembly.
Inspect the inlet hose coming to the washer for any blockages. If the hose is
not clogged then check the water inlet valve for any clogs, if the water will
not even fill for few seconds then certainly the water inlet valve is bad and
should be replaced. You can also use a multimeter to check continuity on inlet
valve. If you don't get any value on the multimeter then you'll need to replace
the water inlet valve assembly. However, if the valve is fine then the
pressure/water level switch assembly should be replaced. Hope this helps...
Please post back if you need more information.
Daniel
