Question about Motorola Mobility RAZR V3
Won't make or receive calls
My phone doesn't send calls. It says it's sending, but isn't. When I call my phone I hear one ring and then nothing. My phone doesn't ring either.
    Brigadier General:
  • 7,752 Answers
You should contact your mobile service provider and explain that to them to see if that the problem is coming from the simcard on their end.
Or if that is not the problem then you need to take it into a mobile service center to have it fix..it is extremely hard to say what the problem is so have it diagnosed
Posted on Oct 05, 2008
Cannot receive a fax but can send faxes with no problems. No diverts etc on the line.
From your phone call the fax number. Watch the printer console. It should give a message that there is an incoming call. Also you should hear the fax noise on your phone. If none of the above happens, plug a phone into the wall jack that your fax is plugged into. Call the number from another phone, if the phone doesn't ring...you have the wrong phone number. If everything above works, you may need the fax card on the formatter replaced.
Sep 23, 2011 | HP LaserJet 2840 All-In-One Printer
How can I get the telephone on my Brother Fax T96 to work?
Step by step information at the link below.
Brother Fax T96
The F/T Mode is used to allow the fax machine and the telephones to share the same telephone line. When a call comes in, the fax machine and all extension telephones on that line will ring according to the number of rings you have set for the Ring Delay.
When the Ring Delay is completed, the fax machine will answer the call and determine if it is a fax call or a telephone (voice) call.
The fax machine can determine this by the signal it is receiving on the telephone line. If someone is sending a fax automatically , the sending fax machine will transmit a fax tone (a series of beeps every 3 seconds).
If your fax machine hears these tones, it will receive the fax.
If the fax machine does not hear any fax tones, it assumes it is a telephone (voice) call and will begin ringing the F/T ring tones (double ring) for the length of time you selected for the F/T Ring Time. These tones will only ring on the fax machine's handset (extension or external phones will not ring). At the end of the F/T ring time the fax machine will go into the receive mode in order to receive a manual fax.
(If the call was a voice call and was not answered, the caller will hear the fax receive tones also).
  • If you answer the call before the fax machine(during the ring delay period) and determine it is a fax, you can transfer the fax to the fax machine for receiving.
  • If you answer the call on an "extension" phone and hear a beep every 3 seconds (automatic fax) or silence (manual fax), press *51 or *91 for New Zealand (remote activation code) on the telephone keypad, wait to hear the fax machine turn on (chirping sounds) and then hang up.
  • If you answer on the handset of the fax machine and hear a beep every 3 seconds or silence, press the Fax Start or Start/Copy key on the control panel of the fax machine and then hang up the handset.
  • If you answer a call on an "extension" phone during the F/T Ring Time, you will hear the F/T ring tones.
    To release the call from the fax machine, press #51 or #91 for New Zealand (remote deactivation code) on the telephone keypad and you can speak to the calling party.
  • If you pick up the handset of the fax machine during the F/T ring time, you may talk to the calling party immediately.
Mar 28, 2011 | Office Equipment & Supplies
Cannon Fax Machine Super G3 Unable to send. Phone rings but does not send. No error message.
In order to send, the recieving machine and the sending machine need to handshake (agree on setting, etc.)
If, as your description says the phone is ringing, I presume your are the sender.....what you need to hear is the other machine pick up, and then fax screech noises..... Test by calling the receiving fax by regular phone, and you should hear a pickup and fax noises....if not, your machine would never send.
Mar 26, 2011 | Computers & Internet
Can send faxes, but no fax tome coming on when the number is called
that's right,you would be able to send fax,but wont be able to hear the fax tone,your fax ring shoud be 2 rings higher than answering machine,or else,do 1 thing when you hear the ring,just pick up the receiver u wud be able to hear the fax tone,do not disconnect the call,just keep the receiver aside without disconnecting,and then press start fax...you will be able to receive fax...........
Aug 25, 2009 | HP Hewlett Packard Officejet Pro L7680...
I am able to call but can't hear the other persons phone ringing, busy, voicemail or if anyone answers, there is no sound. The same if someone calls me, it rings, I try to answer & nothing. I can send...
well the ringing is from another speaker that works as a loudspeaker/ handsfree on your phone
as a preliminary check try connecting a headset and answer the phone if you can hear the other party then the problem is with the earpeice, you might want to get it repaired
Jul 22, 2009 | Motorola Mobility RAZR V3
Kyocera candid ii will not send/receive calls.
you have to deactivate your call divert service for all
May 19, 2009 | Kyocera Candid KX16 Cellular Phone
No respond to incoming calls
go to phone settings. check the profile and change it accordingly..regs
Jun 19, 2008 | Nokia 6260 Cellular Phone
Chocolate LG -- I'm calling but nothing happens, I can't hear a ring or anyone answwering the call
LG Chocolate is the worst phone EVER! i've already self-fixed two problems, and now a new problem that i cannot make phone calls / receive them (they do actually go through but i can't hear anything). someone please tell me how to fix this....
May 09, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Not able to talk
have the phone check fully the microphone needs to be replaced and the earpiece as well........the housing by the earpiece might be block so take a small flatbit screwdriver and have try to to clear it.
Nov 06, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Motorola Mobility RAZR V3 Logo
37 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
