Question about Kitchen Ranges
One burner does not ignite when the others ignite
All top burners are supposed to click or fire when one is turned on, but, after 4 years of successful operation, one burner does not fire anymore.
  • dickeydue Apr 03, 2009
    hotpoint gas range one of the top burners will not ignite even though it clicks and has a flame rest of burners work fine
    Sergeant:
  • 409 Answers
the clicking sound is good, that means that the spark module is working and you have power to the stove. you may have a faulty gas valve or ignitor. most gas ranges have electrodes as ignitors. check the ingitor before you look at anything else.
Posted on Oct 03, 2008
Jenn-Aire Model CVG4380 gas stove top. Why doesn't igniter work?
Under your knobs are burner switches, 3 of them are the same, so this will be a hit and miss on getting them but possible. Each burner should trigger the ignition system. This will be needed to be inspected to find out which one needs to be replace. If you get the right person to look over the unit they could tell you if it can be repaired. I worked on one about 3 years ago and it worked out fine. Good Luck and I hope this helped.
Apr 11, 2016 | Kitchen Ranges
Burners slow to ignite
you may have your gass set to low or you need a new regulator valve
Apr 05, 2012 | Hotpoint Kitchen Ranges
I have turbo CG4TDBRN and It stoped working. I used to push in the knob and hear clicking and the fire would start. now no clicking no fire. the Rotiserie went out a couple of years ago and I would like...
Some igniters need batteries. Try calling the company and asking them. They might also be able to sell you a replacement igniter. In the mean time you can always start the grill with a long lighter or by lighting a stick and putting it near the burners before turning on the gas.
Jun 05, 2011 | Barbeques Galore Turbo STS 4-Burner with...
All 4 Igniters keep firing after the burner is lit.
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
ghhdf
May 02, 2010 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
My DCS range burners with electric start.
Very likely the spark module. All four are supposed to click when one is turned on, however they are supposed to stop when the burner ignites. Replace the module and test. Good Luck, Appliance Specialists
Jan 03, 2010 | DCS 36-6-1 Gas Kitchen Range
Igniter clicks on the wrong burner
The spark supposes to go to all burners. The spark igniter of the non working burner needs to be replaced.
Sep 26, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Igniter on Wolf Stove clicks continuosly
Depends what Wolf model you have, if you have model AS48KI and the flame looks really high, (it supposed look like a flower), most cases the top burners are misaligned, you can try to re align the burners by turning them around. afterward if the burners are still clicking it may be ignition problem. Have fun.
Aug 14, 2009 | Wolfgang Puck BTOBR0040 Toaster Oven with...
Igniter of back burner dies not click or light
I had the same issue with washing the top with water and cleaning solution. I had arching, eventually one burner failed to ignite. I tried the above solution and it did not work. Remove the ceramic top on the burner that will not ignite. Turn on another working element. Do you see the igniter working?
If so slowly turn on the gas on the failed burner and it will ignite. I'm looking into what component automatically controls the igniting and gas release when the knob is turned on.
Dec 22, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jenn-Air part RI302 4 pt gas re-igniter with flame rectification tytronics #Z21-20 and 7431 PO38-60
We had the same problem on a Thermador cooktop with the same RI-302 ignitor. Turns out it was one of the switches that sits on top of the gas valves. These switches cause the ignotor to fire when the valve is turned. In our case, one of the switches had malfunctioned and was "always on" causing the ignitor to continuously fire.
Oct 29, 2007 | Jenn-Air JJW8530C Expressions Collection...
Igniter
It is normal for all 4 burners to spark at same time.  Often burners won't light even when you can see the spark at them because the burner is dirty.  Take a pin and clean out all the holes in rim of burner.  Also look for small cracks in white part of igniter.  If cracked it must be replaced.
Oct 21, 2007 | Kitchen Ranges
Kitchen Ranges Logo
216 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
