Question about Garmin GPS
Garmin GTM 25 charger cord has broken wire inside.
Would not charge GPS. Opened connector that plugs into cigarette lighter and found a small white wire not connected (appears to go to traffic receiver portion). Need photo of opened connector to see where small white wire attaches.
  • Nedum Thot Oct 23, 2012
    I've just had this happen to me this past weekend - at the worst possible time - the wire inside the right angle portion of the charger (that plugs into the GPS) looks frayed inside - am trying to get a free replacement since the unit is less than 8 months old
  • Garmin Master
  • 2,130 Answers
Most likely that is the FM antenna lead that goes to the traffic receiver. It should only be connected on the end that goes to the receiver.
You say the GTM-25 is not charging. Is the fuse blown? The charger takes +12VDC from the lighter socket and supplies +5VDC to the GPS.
Posted on Mar 21, 2016
mastersaintx
  • 928 Answers
SOURCE: don't work with the cigarette lighter connector
Check if you are able to charge other devices via the cigarette lighter such as a cellphone or try to use the lighter if the light does not get as hot as normal then that means that there is not enough power. If that looks ok then try another cable charger for your Nuvi
Posted on Aug 20, 2008
HarryHarley
  • 343 Answers
SOURCE: GPS plug do not fit in car cigarette lighter
Buy a adapter for your cigarette lighter socket that has multiple sockets with one that will fit the Garmin adapter.
I've never heard of a problem you are having??
Are you using a Garmin plug?
If not get one.
Posted on Feb 24, 2010
  • 26 Answers
SOURCE: My cigarette lighter doesn't work, do I need it to
You can use it on its internal battery but they only last an hour or two. If you can't fix the lighter socket you could add one fairly easily then the Nuvi will last for the whole trip running on car power
Posted on Apr 05, 2010
  • 504 Answers
SOURCE: StreetPilot C330 (010-00401-10) GPS Receiver: I just recently purchased a Garmin GPS system for ...
If you have the USB cable, you can charge the unit by plugging it into the computer. It will take longer (at least several hours), but it will charge as long as the battery is ok.
Posted on May 27, 2010
  • 589 Answers
SOURCE: Garmin GTM 25 Charger is
Unscew the Cig lighter plug silver or black tip part, the fuse in located in there, be careful its sping loaded....check fuse should be a 3 A fuse any Radio Shack should have it or auto store
Posted on Oct 23, 2010
Garmin nuvi 760 charging problem
The wire may be defective, especially where it plugs into the connectors.
Nov 25, 2013 | Garmin Nuvi 760 Car GPS Receiver
My Garmin GDB 50 MSN Receiver/Car Charger lost the piece on the tip to connect it to the cigarette lighter. Can I purchase the replacement part?
You can buy a complete charger by going to https://buy.garmin.com/shop/shop.do?pID=8526
Click on "FIND A STORE" and select your country.
A cheaper option would be to go to a car accessory shop and buy a plug for cigarette lighter accessories. Take it apart and use the tip out of it.
May 24, 2011 | Garmin GPS
Does it have to be charge by USB. Or can it just be plug in. It has not worked on the plug and I don't have the USB with me
The charger is still USB, whether you plug it into your computer or your cigarette lighter adapter. I sometimes use my phone charger which has a detachable USB cord and plug in the USB cord I use for my Garmin to charge it in the house.
Apr 13, 2011 | Garmin nuvi 255W GPS Receiver
Car power supply for Garmin nuvi 755t does not work. Not sure if its the Wire, mount Adapter or other.
I assume you have checked the cigarette lighter to be sure it's working.
The most likely problem is the fuse in the power cord/charger. The plug which goes into the cigarette lighter socket has a ring at the end of it. Unscrew the ring, taking care not to lose any small parts, and it comes apart. Replace the fuse and it should be ok.
Dec 25, 2010 | Garmin nuvi 755T Car GPS Receiver
Garmin GTM 25 Charger is not charging GPS, but the red light is coming on when plug in to GPS and Cig lighter. Could this be a fuse in the charger?
Sep 22, 2010 | Garmin GTM 12 FM TMC Traffic Receiver...
THE GARMIN GTM 25 NEEDS A NEW FUSE.THE FUSE IS F 1AH 250 V. I NEED TO KNOW WHERE THE FUSE IS ON THE UNIT, AND HOW TO TAKE OUT THE OLD ONE AND REPLACE IT WITH A NEW FUSE.
un screw the the tip of your charger that fits into the cigarette lighter, it is inside, be careful not to lose the spring, but if you do, a spring from a pen will work, i dont think you can buy one from garmin
Oct 30, 2009 | Garmin GTM 12 FM TMC Traffic Receiver...
Don't work with the cigarette lighter connector
Aug 09, 2008 | Garmin 010-00358-00 GPS Receiver
I can't charge my GPS while I am in the car
Verify that the car cigarette lighter outlet is working. Do you have something that you could plug into the lighter like a light?
With the car running plug the Garmin into the cigarette lighter outlet. Does it come on without pushing the ON button? If the answer is no then there is either a problem with the cable or the cigarette lighter outlet. It should come on by itself if the lighter is working. Also are you using Garmin cables and DC adapter?
Jan 31, 2008 | Garmin StreetPilot C330 GPS Receiver
GPS Logo
1,575 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
