My new sony xbr 55hx929 on occasion shuts itself off and comes back on within a second or two. shuts off to the point when it comes back on the sony logo on screen is displayed and in the upper left hand corner the input (hdmi 1) is shown follow by the program on tv.
Customer care support SERVICE number+1--833'''272''''0777,,,,,,,,,,,call them
SOURCE: KDL-32XBR6
Try resetting the TV by holding down the "up" button on the remote (with the TV powered on) and then, while you hold down the up button on the remote, hit the power button on the TV. This should do a "factory reset" which will wipe all settings in the TV. There is no reason why the TV should not "remember the last input it was on when it was ;last turned off. Also be sure that the TV is not plugged into a switched AC outlet, like the outlet on the back of the cable bix. The TV should be plugged into an output that receives power at all times.
SOURCE: I have a Sony Bravia XBR 46
Please make sure that the connections are secure.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
Please try connecting the TV to a different wall outlet and check if that helps.
SOURCE: on my sony bravia tv if i use bt vision box hdmi
On the remote control on the top left corner a button marked i+ is there. Press it. This will eliminate the hdmi sign.
SOURCE: TV Sony Bravia shows the
Hello
There is an Info/Text reveal button on your sets' remote control. It is located just above the Tools button, marked (i+) (?).
# In digital mode:- Displays brief details of the programme currently being watched.
# In analogue mode:- Displays information such as current channel number and screen mode.
# In analogue text mode: Reveals hidden information (eg:- answers to quiz)
Press this button to dissapear the details displaye on screen. OK
Correction: make that "shuts OFF then turns on"
