Question about E-Machines eMachines Desktop PC
Won't power up
My T2625 will not turn on. I replaced the power supply about 5 years ago. Yes I know the machine is old but it does what I need it to do. Could the button to push it on go bad? I purchased a power supply and installed it. I can hear the motor on the power supply running but nothing happens when I press the button for the machine to turn on.
  • sldonigan Oct 03, 2008
    I double checked to make sure the cables were connected corrected. I didn't move any cards or the memory. The fan on the motherboard is not working. Please tell me where to find the reset button.
    Genius:
  • 1,124 Answers
Did you install correctly the cables?
Did you move any card or memory?
Check it out again!!
The fan of the motherboard is working?
Hit the reset buttom and see what happen
If doesn't work is a bad motherboard
Posted on Oct 03, 2008
I have a Panasonic HDTV 1080p and it won't turn
You have a 5 year old projection TV with power supply trouble
Jul 13, 2013 | Televison & Video
Hi we have a 720 Magnavox flat screen tv that is about 5 years old. When i went to turn it on the other day the picture started flasing and making a chirp noise.. and won't fully
power supply problems does it have a separete power supply if so you can try to change or if you have someone with the same you can ask to try it.if its internal power supply it needs to be fixed.
Aug 20, 2012 | Magnavox 37MF437B37 37 in TV
Samsung tv wont turn on
Check with Samsung first, most of their TVs and monitors come with a 3 year warranty and if you open the unit it will void the warranty.
Aug 20, 2012 | Samsung UN55C6300 55 LCD 1080p HDTV LED...
I have a roper washer 5 years old and it won't drain or turn on now it was working fine yesterday ive unplugged replugged pulled out all the clothes checked power supply and hoses what now?
I looked up your model number. You particular machine allows for wash with the lid open. You nothing happens. On that case I would check the motor capacitor.
Nov 13, 2011 | Roper RAS8445KQ Top Load Washer
"canon mp600..it's about 4 or 5 years old. It
The Power Supplies for the MP600 burn out over time. They are easy to buy and replace:
My MP600 Power supply died as well. Web searches (including Canon) turned up nothing. Called Canon. To order power supply from Canon, call: 866-481-2569 (credit card over the phone, no on-line interface). $34.49 with tax and delivery.
Note: the power supply has black tabs the you push away from the grey power supply case. One tab in front and one in back. The grey power supply box pulls right out of the printer. The internal connector (six colored wires) pulls straight out (there is no release tab/catch). Use small screwdriver or needle nose plyers to carefully remove. Pull/pry the female white nylon connector. Do not pull on the wires.
Jul 13, 2011 | Canon PIXMA MP600 all-In-One InkJet...
I own a Sharp Aquos LCD model LC46D43U. It's 3 1/2 years old. When I turned on the TV, the power does not come on. It clicks like it's trying to power up and repeats itself 4 or 5 times every 4 - 5...
there is a problem with the power supply. most likely too much ripple that is ac leaking into the dc. I have seen the power supply repaired but it is not always possible. If there is an obvious swelled capacitor on the power supply that can be replaced this will be the best bet for repair. If there is nothing visually obvious then it gets a little harder since you won't really know which component is not working, the tv shuts down on a protection circuit so if the power supply can be repaired and the voltage "cleaned up" then the tv could work again. I have also seen replacement power supplys sold.
May 26, 2011 | Sharp Televison & Video
I have a 5-year old Sony 19-LCD monitor that stopped working. The little power-on light does not come on, and their is no picture, but I do hear a faint buzzing from the back. Sounds like?
smyko, Sounds like a tired out old "switch-mode-power-supply"/ "inverter CCFL power-supply!!! May require unit to be REFURBISHED with upgraded power suppllies and if the LCD screen had been displaying an increasingly dimmer screen, it may also need new "cold cathode-fluorescent lamps" installed. A technician who knows all about LCD monitors and their backlight "ELECTRONIC BALLAST" circuits will need to evaluate it. Check with sony and find out if you can do a "cash+old unit swapout for a factory rebuilt (refurb) same model type. Before you do any of that have a look at youtube for longer video clips of "LCD monitor disassembly" and "LCD monitor repair" just FYI. You will then know and understand what is on the "OTHER SIDE" of what you been looking at for 5yrs!!! Yes, they are trying to experiment with WHITE led arrays that won"t fail for 10 years. Remember lcd Panels last 8 - 12 yrs. Hope this helps. Bye for now. 12fixlouie
Nov 17, 2009 | Sony SDM-HS93 19" LCD Monitor
2 emachines won't boot
Are you attaching them properly
if so then it is something other then power supply
something has caused both power supplies to blow
have you installed anything in the first emachine you talk about
Jan 17, 2009 | E-Machines eMachines Refurbished EMA...
I have an emachine T2984 that won't boot. No noise of any kind. I had another emachine T2625 that was working. I took the power supply out of the T2984 (that wouldn't boot) and put it in the T2625 and it...
Power supply sounds fine. If the pc won't power up it could be your motherboard. If the pc is powering up and you get a 'no signal' on your monitor it could be your gpu.
Emachine t2625 wii not startup
That may be due to a spike that has affected minimally the power supply or more/worse
Dec 22, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
63 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
