Question about Dell XPS™ 600 PC Desktop
My computer freezes for no apparent reason :(
Ok so bear with me here I'm not a computer wiz but I am a gamer. Basically I got this xps 600 from a friend who just got an alienware desktop so he gave this to me and I do not know the history about it but he says it worked fine. So basically I it runs fine for any big programs like World of Warcraft which is pretty much all I want to use it for. The first time I tried playing it, it worked fine for about 30 mins and then the whole comp froze not just the program. Then the next time I was downloading a file off the internet and the whole comp froze again. Basically any time I go on it and do something that requires no internet interruptions (which I'm thinking is the problem but not sure) it freezes and I'm not sure what to do/check. Anyways It would be great help if I could get some suggestions. Just reply if u have one or u need to know more. thanks.
  • Anonymous Oct 27, 2008
    I have the same problem, and I'm not sure what can I do to fix it. In my case (and I believe the original poster's too), the computer simply halts every processing and ignores any keyboard or mouse input. I kind of discarded the "it is the OS" and "the hardware is to blame" approaches. Reinstalled XP more than once, and the obvious hw parts are fairly new. And it doesn't seem like overheat either, because if it were the system would hang almost instantly after a restart, but I can use it for a long time before another freeze.
    I'm believing it is a driver's fault and my first guess is on my D-link adapter, because when I restart the windows it is not on the PnP devices list and everything else is still there. But my brother has another of the exact same Dlink adapter as we bought together, and his works fine.
    My second bet is in my graphics card, because of some post I read on another forum. Not too likely for my setup, but it is still worth a try.
  • 781 Answers
Thanks for the details
something you need to know is that freeze ups (intermittent ones) are hard to diagnose.. and it may require to swap some with known good ones to determine what the problem is
this is what I would start with.
1. if you're new to the computer.. check for viruses and malware in general or better yet do a clean reisntall of the os. (it problably would be faster particularly if you don't have any info on it since you're using it for games) then test your games and see how it behaves... if the problem is fixed.. you may have had a software issue or simply malware or some virus.
2. you did a clean install and it kept freezing up on you (that's when it gets interesting).
you suspect it could be something related with internet... check the network updater:
couple of things you can try:
a. if the network adapter is onboard: check for new drivers then test if it does not work disable the adapter in device manager and test... run some games of the harddisk or the cd/dvd drive and see how it behaves..
b. if the network adapter is a pci card..check for new drivers then test if it does not work uninstall from device manager and uninstall card phisically and test running some games off the hdd or cd/dvd drive, (feel free to try to use your onboard network adapter if avaliable.. don't forget to enable this one if it was disabled on bios) and test
3. if you're a gamer and your old pal (the one that got you the computer was one too) you very likely have a good video card on your system.. check for new drivers then test if it does not work uninstall and then use onboard video adapter and test...
4. you tried 2 and it kept happening... first thing I would do is do some checking on the memory: if you have 2 sticks of memory.. run the computer with one memory stick at a time and test (one memory stick at a time)
if it only has 1 memory stick.. get a new memory stick and test the system with the new memory stick.
5. check your hard drive (it may be getting old)... download a program called speed fan and check the startus of your hdd and the the online comparison (if it doesn't freeze up on you).
6. if you got upto here... things are not looking good.. you may have a problem with the motherboard or even your cpu... I would do some monitoring with task manager... check and see if by creating some stress on your cpu usage (open, close, run programs).. you can duplicate the freeze up).. at this time you may to think on replacing either one of those components.. been more likely your motherboard... but only way to find out would be swaping components for know good components..
have fun and let me know how it turns out.
Posted on Oct 03, 2008
XPS 600 will not boot up
goto safe mode and remove the router software from start up ? check on the screen to find which button to press normally it's f7 or f9 but it depends on the model
Jun 15, 2010 | Dell XPS 420 PC Desktop
My XPS M140 is slow. It pauses for no reason
If the system is pausing for 10-30 seconds , there could be some bad sectors on the harddrive or , there are some unwanted programs running in the background
To check if your hdd is working fine
1. restart your computer
2. And press the F12 key slowly 5 times
3. Run onboard diagnostics on the hdd.
Thanks for using Fixya
Proton
Oct 18, 2009 | Dell Inspiron XPS M140 Notebook
Coby 600 4G frequently freezes, requires reset
Please try these steps to fix your Coby MP-610 MP3 Player.
Sep 16, 2009 | Coby MP-610 MP3 Player
Dell XPS 600 turns itself on to solid amber
Hi. the mother board seems to be having some initialization issues during boot up. this is common when the mother board is failing. i would check to make sure the battery on this board is working. if it is, the board my be ruined.
power board seems to be fine.
please rate and god bless.
Mar 17, 2009 | Dell XPS 600 PC Desktop
XPS 600 - Six Beeps No Boot
Follow this link and figure out what the beep code is telling you and i can try to help you fix it from there. I can tell you that what you are describing usually is caused by a hardware issue.
http://www.computerhope.com/beep.htm
Jan 22, 2009 | Dell XPS™ 600 PC Desktop
My Dell xps 600 won't startup
have you check the hardware of your computer? try to change the memory of your computer. and check the cables of your keyboard and mouse.. if there is any problem again try to contact me. thanks!
May 28, 2008 | Dell XPS™ 600 PC Desktop
XPS 600 serious Boot up Problems!
sounds to me like the fan is on the way out ,and if the cpu gets too hot the pc will shut down.
check that the fan is not obstructed,clean it if it is full of dust, replace it if it is not working as it should.
also listen to the power supply fan, is it working ok,this could cause the same type of problem but for different reasons.
good luck
Terry
Mar 11, 2008 | Dell XPS™ 600 PC Desktop
Dell XPS™ 600 PC Desktop Logo
522 people viewed this question
Alun Cox
