I have a Toshiba 52HM95 52" DLP TV. When I came home this weekend, I hit the power button but the TV would not turn on. The TV is powered and a green LED light blinks 3 times repeatedly, goes off, and then starts blinking again. I took to a local TV repair shop to diagnose the problem as I was convinced it was a lamp balace or color wheel issue (the lamp itself was okay and not blown/burned out. However, when I called the tech today he said the TV had a faulty DMD(Digital Model Display) that needed to be replaced and the part was $850. He said it wasn't worth fixing and that the TV was worthless. He said either I could pick it up or he would throw it away. I'm suspicious he's hoping I'll tell him to keep the TV and he can salvage it for parts. I've scoured the web and can't find a "DMD" part or anything like it... Not to mention, all parts I find are $450 or less straight from Toshiba. Any idea on what the real issue might be and how I should proceed?
I have the same problem. Do not know what to do!
Posted on Jun 08, 2010
Samsung DLP TV has power but no picture.
There is a capacitor that often fails.. it round and contains a thermal sensor.
May 29, 2015 | Samsung HLT5687SAX 56-Inch Slim LED Engine...
I have a Toshiba DLP 62HM15A TV; I turned the TV off the night before and everything was working fine. But the next morning I went to turn it on, but the power red light came on then turned off then o
Many LED TVs and other electronics have bad capacitors on their power supply boards. You can visually inspect them by opening the TV and looking for capacitors with bulging tops. If you see any, replace them all in the power board section. This should fix the problem. Check to see if your TV is still under warranty first though.
Dec 04, 2014 | Toshiba Televison & Video
Need to access service menu
GO to All TV Service Menu Code to browse olmost tv factory mode.
You can find lot of service code for tvs, DVDs, Monitor and many more.
Mar 27, 2011 | Toshiba 26AV52R LCD TV
The power light blinks 3 times. What does this mean?
Toshiba Flat Panel Television how-to instructions, help and tips Three times so far, just the tv not the cable. Toshiba Flat Panel .... Timer light blinking red. TV will not turn on by power button on TV or using the ...
tv.manualsonline.com/.../toshiba/.../flat_panel.../product_problem toshiba.justanswer.com
Mar 11, 2011 | Toshiba Televison & Video
My Toshiba 62HM95 62 in. HDTV DLP TV won't turn on...the green and red lights under the power button remain on and the red light flashes. How do I fix this?
Most likely, you need to replace your DLP bulb. The one that comes with your TV will last a few years max. The replacements seem to only last about a year. D:
Dec 08, 2010 | Toshiba 62HM95 62" DLP HDTV
44" dlp hd44lpw62 won't turn on
I would first suggest removing AC power to unit for several minutes in order for unit to reinittialize; other than that, check out the power supply to determine if you may have a blown primary fuse or lost one or more voltage sources.. thats where to start....
Sep 10, 2007 | RCA D44LPW134 44" HDTV
Televison & Video Logo
145 people viewed this question
Top Televison & Video Experts
