Shredders
Problem for Shredders
Generic problem for all Shredders
GBC Shredmaster 5260X - door is closed by ...
By tom3520 on Oct 03, 2008
Door is closed but light on panel shows an open door. I have made sure
the door is closed but the light indicates otherwise.
Same Problem
Jan 07, 2009
-   I need a manual of shredmaster 5260x. -   Guest
Best Solution
posted on Oct 18, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Most shredders use a little lever on the door itself to depress a switch on the shredder cabinet when it's closed. This acts as a secondary on/off switch to allow the motor to work when it's safe to do so.Look inside the cabinet with the door open (usually around the perimeter of the opening, towards the top) for a switched door catch, a "slot" with a metal strip exposed, a little box with a lever jutting out of one end of it, or similar. The "slot" type is used when a door mounted "finger" depresses into the slot upon closing, and the metal strip completes the circuit. Any of these different mechanisms may need to be readjusted, replaced, or usually is just jammed up with bits of loose paper that doesn't allow the switch to close all the way. Hope this helps!
Solution #2
posted on Feb 10, 2009
Very Helpful)
bth110
Rank: Apprentice
Rating: 100%, 1 votes
This shredder has a magnet built into the door. If you open the door you'll see a metal strip on top right side of shredder. Either the magnet is not getting close enough to activate the reed switch or the hinges have came loose allowing a door sag condition. Also, if the shredder isnt that old, just contact GBC for some warranty work at 800-790-7787
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Shredders
Questions and Unsolved Problems for Shredders
Answer
we have an intimus 430 se that is having keypad problems.(I think!) It will run in reverse but not... (More)
Answer
Paper will only feed through shredder teeth if I press in the plunger / switch the paper normally... (More)
Answer
it has been working fine, but today, I emptied the basket and replaced the shredder unit, and it... (More)
Answer
bits of paper is jaming the cutting wheels.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Shredder Experts
Top Copier & Fax Repairmen
in , CA
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
