Home | Phones | Sony ericsson k800i sto...
Phones
Problem for Phones
Generic problem for all Phones
Sony ericsson k800i stopped switching
By karenc1603 on Oct 03, 2008
sony ericsson k800i stopped switching on
Comments:
Oct 03, 2008
- new battery was put in but the phone won't switch on and was perfect before it was switched off. i have noticed this problem highlighted a few times in the sale of used phones on ebay. all same comments just stopped powering up.
Oct 03, 2008
- when you try to switch on there is a dull flicker in the infrared light area but nothing else
Oct 03, 2008
- hi thanks for your response but there must be some way to fix otherwise no one would buy them for £30 plus knowing about this problem any whiz tech guys out there
Solution #1
posted on Oct 03, 2008
Not Rated)
coolguy008
Rank: Wiz
Rating: 83%, 565 votes
HI,
If your phone does not turn on then please remove the battery from the back and reinsert it.Next allow it to charge for 6 hours and then hold the power button for 30sec.Your phone should switch on now.
Comments:
Oct 03, 2008
- Make sure your phone is on charge when you press and hold the power button for 30sec.Let me know the result.
Solution #2
Somewhat Helpful)
marked
Rank: Guru
Rating: 86%, 903 votes
Try first to remove the battery for 5 minutes than after that put it back in and charge the phone for about an hour , if still the same better if you can try a new battery to check that this is not a battery problem...
Hope that helps.........
Comments:
Oct 03, 2008
- YOu may need to flash the Erom of this unit or better yet take it to a servcie center so they can check this and hopefully they can fix it...
Solution #3
Not Rated)
kakee
Rank: Wiz
Rating: 81%, 432 votes
Maybe the battery terminals and metal contacts on the battery compartment are pushed. Try to pull them upward so the battery can have a tight contact with those metal terminals. Try to clean those terminals as well using alcohol and cotton.
Solution #4
Not Rated)
voodoomox
Rank: Wiz
Rating: 83%, 390 votes
the flickering dim red light is not the infrared, it signifies that the battery lacks power to initialize the cellphone operation. you may want to leave it charged with the new battery for at least over night (initial charging) then once it is turned on, never leave the battery drained.
Solution #5
Somewhat Helpful)
Ajkill
Rank: Wiz
Rating: 84%, 1086 votes
When your battery is fully charged and you get a dull light light as soon you switch on the phone, then try to reinstall install the phone software as it could corrupted and updating firmware - that is, changing the program code running the operating system of the phone - can be risky. If something goes wrong during the update process, you could be left with a non-functional device, which must be repaired at a service workshop, so its recommended to do it local mobile service center.
Good luck...
Solution #6
Somewhat Helpful)
jaketasnake
Rank: Wiz
Rating: 77%, 74 votes
I use to have the same problem with my phone and the reason why that was happening to mine was that i dropped one too many times after one day i tried turning on and nothing happened. I would check and see if your phone is under some sort of warranty which is the case for most phones.
Solution #7
Somewhat Helpful)
ohms
Rank: Wiz
Rating: 83%, 756 votes
tried re-seating the battery and / or using the power adaptor ?
Popular Solutions for Phones
Questions and Unsolved Problems for Phones
Answer
Need a unlimited phone book memory phone in CDMA
Answer
I was playing with my phone a week ago and turned off the call waiting and voice mail features. How... (More)
Answer
i have a star c5000 wi fi tv phone but cant set up the internet , the phone has some setting on it... (More)
Answer
I cannot find my manual & need to correct my philips phone in order to get it to work.It is... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Phones:
Top Phone Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Phone Experts
Top Telephone Repair
(800) 513-9962
Component level repair and complete refurbishing...
BARCLAYENTERPRISESINC
(316) 262-7171
Cctv,Cable Tv Wiring & Outlets,Computer Wiring...
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
