Question about LG Dryers
Hi i have a lg dlg2524w gas dryer that does not heat up it ignites a flame then goes out within about 5 sec i don't know what to check i have the front door & panel off and watching it light but that's it please help if possible
  • 23 Answers
Check damper switch on back of dryer
Posted on Oct 03, 2008
Igniter starts to glow for 3-5 sec while making noise every minute or so
Check the thermocouple it is going bad or already has and that is why the gas valve is not staying open.
Jul 08, 2017 | Whirlpool GGW9200L Gas Dryer
Gas dryer does not heat igniter glows red gas valve clicks but no flame
Since the igniter glows i am wondering if within 1 minutes does it go off??or does the igniter just stay on??
If the igniter just stays on and doesnt go off the problem is going to the FLAME SENSOR
if the igniter goes off but no flame the problem will be the GAS VALVE COILS
GENE
Oct 12, 2011 | Dryers
Lg dryer dlg8388 , with power on drum runnng but no heating up, i'll check continuity in the igniter and is ok. don't lnow what else to check.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101[
Aug 25, 2011 | LG DLG8388 Dryer
For whirlpool duet GGW 9250 PW0 GAS DRYER How do you know if the gas solenoid are bad? I check the resistance as per manual and its within its limit. It ignites and flames come out but the flame only...
The gas valve solenoid coils work when cool that's why the resistance reading is within the limit but fail when heated. Bypass the thermostat on the burner funnel and if the flame still goes out too soon, the coils are weak and both must be replaced. The resistance reading is reliable only when the dryer does not heat at all or shall we say the flame does not go on at all and the purpose is to check the continuity of the coil.
Oct 12, 2010 | Dryers
Dryer starts hot surface ignitor comes on gas valve opens i get a flame 5 mins flame shuts off hot surface ignitor repeats and tries to ignite no flame after unit is off for 20 mins to 30 mins off unit...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 17, 2010 | Kenmore 77632 Gas Dryer
When my mdg 6000bww is turn on heating element glows, flame ignites, then flames goes off within 5 minutes. After waiting approximately 15 to 20 minutes, until it seems to cool down can restart and goes...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Aug 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Gas dryer heat is intermediate
does the igniter glow white or orange? if it is orange you need to replace it. has to be white hot to ignite. if the igniter is white it could be the coils not opening the gas valve all the time - an intermittent problem.
Oct 04, 2009 | Kenmore 73952 Gas Dryer
Inglis gas dryer heat loss
Replace these solenoids on the gas valve. Feel them if you can. They get hot and quit.d910ca8.jpg
Feb 04, 2009 | Dryers
KENMORE gas dryer
Hi .No The Solenoids Are Turning The Gas On . I would Check The Venting . Remove The Venting Clean All Venting. Thanks The Appliance Doc
Oct 03, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
200 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
