SOURCE: Changing company message on KX-T7730
hi there! can you please help me? how can I create/record a voice message? Thank you.
SOURCE: NEC phone system - Forwarding incoming call gets busy signal
please call the engineer from which you have purchased the EPBAX system to congiure the same. It happens if something is wrong in line card at the exchange or the extentions are not configured properly with the Key Telephone System.
SOURCE: Panasonic KX-T7730 Diverting Calls back
If you set call forward all calls then lift your handset press the FWD/DND button, dial 0 , you should get a tone, then hang up. If you set Follow Me then dial 8 and your extension number instead of the 0 . Good Luck. ....Mike
SOURCE: Incoming Call not Ringing
Either call line 3 first, or make your phone ring :-)
What might be the easiest is to swap modular plugs in the back room between 2 and 5. That way, you get your old extension back and everything will work as it did.
If you can't do that, then you're going to have to do some system programming to turn on the ringing on your phone. If you have a TA series system, you should be able to do it from either the PC or a phone connected to jack $1. If you have another model, you should have a system manual on how do make programming changes.
Carl
SOURCE: Incoming calls sound only on reception desk.
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear only
press the Chng key till it says appear & ring
press next key (lower right arrow)
The display should say line 002: appear only
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
Testimonial: "Great! Very specific and easy to follow instructions. Thanks for your fast response. RO"
