Question about Spidem Trevi Express Plus Espresso Machine
Just bought this Spidem Trevi Express Plus Expresso
Try to make a coffee but it never did. Water seems to stay in the plastic thank. Maybe it`s the valve who stays closed. I don`t know. Very disappointed. Brand new and not working. Do you have a suggestion?
Thank you in advance,
Pierrette
mirran
  • 515 Answers
SOURCE: Spidem Trevi Water Problem
I think it´s your boiler that is leaking, if you don´t decalcify the machine regulary this will happen.
Posted on Jul 11, 2008
mirran
  • 515 Answers
SOURCE: How to Prime Spidem Trevi Combi Plus Espresso Machine
Open the steam knob on the side and make a cup of water (Tea).
Best regards
/Mirran
Posted on Oct 26, 2008
freetek
  • 5568 Answers
SOURCE: No power to my Spidem Trevi Digital Coffee machine
Although it may be a different problem completely, most of these failures are caused by a thermal fuse that has opened. They are positioned close to the heating element and serve to prevent fires in case the control of the heater element fails. Unfortunately, they often fail for no reason at all (except being poorly made in China) and are welded into the circuit (solder melts at too low of a temperature) making them nearly impossible to replace at home.
Posted on Feb 18, 2009
  • 10865 Answers
SOURCE: Wiring diadram
http://www.partsguru.com/FixingaVienna.html there you go, wiring diagram and a lot more info.
Posted on Apr 01, 2009
EsWorld
  • 1618 Answers
SOURCE: Spidem Trevi Water Problem/ my machine is leaking water and sort of coffee grounds. I have decalcified it several times, but it continues to leak. It is an office machine is 3 years old and I don no
Easiest way is to open the machine and find the blockage then clear it out and then get on a regular descale cycle. Check the brew unit also to make sure that it is not blocked. You model only has one boiler so if you're getting hot water from the steam wand it is possible that the problem is in the brew unit.
Posted on Jun 03, 2009
Can I use coffee cleaning tablets with a Spidem trevi digital plus
I would not use this product unless you exactly know what it is, and if it's appropriate for your coffee machine. Instead get some Saeco decalcifier powder DEZCAL that you add to your water and follow your machine instruction on how to decalcify.
Nov 24, 2012 | Saeco Spidem Trevi Digital Plus Fully...
Spidem Trevi Plus coffee is not being dispensed.
The grind chamber is blocked, remove the beans and brew unit then clean the grinds chamber, then adjust the grind 2 numbers coarser and try again.
Nov 05, 2009 | Spidem Trevi Digital Coffee Maker,...
Spidem trevi digital plus coffee machine not working as it should
it sounds like you need to go into the programing mode. in there you can set the machine so it grinds when you select coffee. at the moment it is pregrinding this is so you can make lots of coffees 1 after the other
Jan 27, 2009 | Spidem Trevi Digital Coffee Maker,...
Best regards
/Mirran
Oct 23, 2008 | Spidem Trevi Automatic Espresso Machine
Spidem Trevi-the water is not traveling through the machine to allow the machine to make the espresso.
hi, i have a trevi i bought used with no manual and had problems starting with it, i found an airlock stopping water flowing, i held the water bin over the sink and pressed the valve on the bottom until water flowed out, i do this now when filling the bin and have not had any problems so far. i am still trying to find a copy of manual. i hope this may be your problem as it is easy to remedy. col.
Jan 01, 2008 | Spidem Trevi Combi Plus S2231 Espresso...
Spidem Trevi Express Plus Espresso Machine Logo
Top Spidem Coffee Makers & Espresso Machines Experts
Michael Galve
Michael Galve
ray gallant
nikolay nikolov
Are you a Spidem Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
