My tv keeps turning off when I turn it on. I hit the remote button, and it turns theh power on, then it turns off before the picture can come on.
    Scholar:
  • 142 Answers
Your tv is going into shutdown mode because of a fault detected by the microprocessor. This keeps the set from coming on and causing possible damage to other circuits or fire or x-ray emissions. You need a service technician. Good luck!
barneyluc
Posted on Oct 03, 2008
Last night about 3 am I turned off my tv. when I usewd my remote to turn it back on it would not ( t v) come on and no picture or sound . I turned it around to see the back of it but it has no reset
Your TV have faults on Horizontal deflections, the oscillator and the Flyback might be the problems. If you are not familiar with TV circuits?... call tecnician to check your set.
Oct 03, 2014 | Televison & Video
On my maine tv , my remote will not turn the tv on or off or adjust the volume. I have changed the batteries
Has your remote been correctly configured to work with your TV?
I have a very similar model of remote to the one pictured, as such I remember the man in charge of connecting my satellite box "activated" the remotes ability to interface with my TV.
Try hitting any button marked "TV" and then hitting your power button.
Aug 24, 2011 | DISH Network IR Remote Control
Cant progam not understanding the instructions
The best way to program with this remote is to follow these instructions.
1. Turn the device you wish to program on by hand 2. Press and hold the key for the device you are programming. (If it's a TV hold the TV button etc.) 3. While holding the button down, press and hold the power button down until the light turns off, and then back on. Once the light is back on release both keys. 4. Now, while pointing the remote at the device, hit the power button until the device turns off. Once the device turns off, you have found the right code. 5. Hit the stop button on the remote in order to save the code, and program the remote to that device.
This should work for most universal remotes these days. It might take you a long time to find the right code as well, the code list is very long so you just have to keep chugging through them. I've reprogrammed this type of remote many times and have hit the power button for over 5-10 minutes before the device turns off. Best of luck to you.
May 04, 2011 | RCA RCR350 Remote Control
Lost the manual and can't get tv to turn without the right code
if the remote has a set-up or code button you can search for the right signal manualy.first turn the tv on.press the "tv" button on the remote,then hold down the "set-up or code" button til the remote light stays on.the keep pressing the power button on the remote until the tv turns off,careful not to press the button again or you'll lose the code.omce the tv shuts off.hit the enter button on the remote,that should do it:) good luck
Sep 22, 2010 | Universal Remote Control GE174Universal...
I need the codes for my ge universal remote so it will work my sanyo television
if the remote has a "code" button you can search for the code by using the power button on the remote.make sure the tv is turned on first.now press and hold the "code" button till the light on the remote stays on.now hit the "tv button,the light on the remote should still be on.now keep hittin the power button until the tv turns off (careful not to press the power button again when the tv turns off or you'll lose the code) then hit the enter button ont he remote.hope this helps you out:) good luck
Sep 21, 2010 | Universal Remote Control GE174Universal...
I do not have a manual and need to know how to set it up and the code for a vizio tv.
On your remote you will find a setup botton and what i want you to do is hit set up then hit the tv botton and hit channal up and do that untell it turns off your tv are the channal if that works it tv botton again and your remote will work other wise in the back of your remote it well tell you a code number and go on line to philips and they will give your your codes for you.
Dec 09, 2009 | Philips Magnavox Learning Universal Remote
Need codes for LXI tv/vcr combo
you need to hit code search and hold it in untill the light lights up and then you hit button that says tv and then keep hitting power untill tv goes off but dont hit the button after the tv goes if you do you will have to restart and after the tv goes off then hit enter and then turn the tv back on and then you can control the tv.
Jun 15, 2009 | One For All URC-3021 Remote Control
Cannnot control my new emerson tv using my COMCAST controler. model LC320em9 what code do i need to use to make this work.
you need to hit the tv button, then hold down the setup untill the lights plink twice, then hit 991, then power, if it doesnt turn off, hit tv again, then the power again, keep doing that untill the tv turns off, as soon at it turns off, you need to hit the set up button again, that locks in the code, then you should be able to turn it back on with the remote
Jan 08, 2009 | Televison & Video
No Picture
Sharp 42" lcd. TV accessed incorrectly. Resulting in no picture.
Using TV remote, changed from analog 2 to input 4. Turned off TV remote. Returned to satallite remote, turned on TV, turned on satallite, still no picture. We seem to have power but no satallite signal. Ist time users of satallite TV.
Dec 27, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Electro Med Services...
