Question about Refrigerators
Refrigerator drain tube clogged, I cleared it, it keeps clogging-SZ 550 14 yr old
14 year old Sub-Zero 550. The tube is in the back of the refrig compartment, starts just above the vegetable crispers and runs down the back of the freezer compartment down into the drainage pan.
I cleared the tube with alcohol, it clogges up again within 2-3 days. It is clearly ice, not debris. Tried several times and it ices up again.
I heard one possible solution: insert a copper wire down the tube and leave it in, so it transfers heat up the tube. But, not sure where to attach it to so that it would pick up the heat. Would this work? Is there another solution?
Thanks
    Sergeant:
  • 409 Answers
the tube that you are talking about is the water line and it runs all the way to the icemaker. not sure about the copper line and it's also not a good idea, as cooper conducts electricity and you may damage your heat exchanger or even worse your compressor. i would have a technician come and take a look at this one. the mfg. should have a water line freeze kit available to remedy this problem.
Posted on Oct 03, 2008
Water is leaking out from the fridge floor onto the ground.
The drain pan in the back evaporates from the heat of the compressor. The freezer drain drains into this pan. If there is water under the bins it sounds like the drain is partially clogged and over flowing into the refrig section. But I need more info, like model , brand.
Nov 17, 2013 | Sub-Zero 700 Refrigerator Freezer...
Water from fridge not going down plug hole into container. How ofter should the water container be emptied at the back of the fridge/freezer I have a sub zero frigerator #550 its about 15 years old....
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. .
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.You can use a hair dryer and remove the ice buildup
Oct 30, 2008 | Refrigerators
I have the subzero 632 side by side and there is water dripping from under the bottom drawers onto the bottom of frig and then onto floor. Could that be the rubber gasket stripping on the bottom of the...
Behind the crispers and the shelves at the bottom is a drain trough. This drain trough is clogged and would need to be cleared by air pressure. You can use canned air you can seal the opening to keep the pressure in the tube. Once cleared you should be fine.
This happens when food or foreign object get into this trough clog or slow water flow out of the fridge section.
I hope this helps.
Oct 05, 2013 | Sub-Zero Overlay Design 632/O Side-By-Side...
Leaking water
The drain tube under the evaporator in the fridge is clogged. these can only be accessed by removing all the shelves and the light diffuser, then removing the back wall. even then, the hole is tiny and hard to put anything down into to clear the debris. I usually use a steamer to force steam down through to clear out the clog or ice. I get theses hand held steamers at walgreens for about $25. Might be cheaper than a service call to invest in one. Hope this helps.
Sep 07, 2013 | Sub-Zero 700TC Bottom Freezer Refrigerator
A puddle of water shows up on the floor once a day. had it fixed a year ago--the guy said we that the food crumbs had clogged the plastic tube in the back inside of the refrigerator, and he drained it. He...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 17, 2011 | Sub-Zero 690 Side by Side Refrigerator
Getting water under my bottom freezer refridge found drain in refrige was clogged with gunk cleaned out then blew out with compressor is this the problem or is it my water line going to my icecube maker...
Leo Ponder
imufo2
Aug 18, 2011 | Sub-Zero 650 / O Bottom Freezer...
On the top back of the fridge is a unit that seems to be connected to the freezer. It leaks intermittently into the refrigerator and pools under the crisper baskets as well as wetting food that is on the...
Looks like you have a clogged drip tray channel. Unplug the refrige ,leave freezer and food compartment doors open for at least 12 hours. After that look under behind the refrige for a plastic-rubber tubing ending in the drain pan under the refrige.That is clogged, get a 2 feet hose 1/2 inch diameter. Attach end to the drain tubing then blow through this will clear the way.. and your done.
Dec 31, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Drain in fridge is clogged - ice formation under crisper drawers
We have cleared / de-frosted the drain twice and it keeps freezing up, causing the accumulated ice problem to recur. Should the freezer settings be changed?
Aug 13, 2009 | Sub-Zero Bottom Freezer Refrigerator
Leaking sub zero 650
I fixed my leaking problem by pulling out the vegetable drawer and checking the condensation drain hose. Sure enough, it was clogged and the condensation had nowhere to go but move out toward the front of the fridge, down the left side and onto the floor. Once that drain hose was cleared (with a bendable straw), no more leak!
Jan 16, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 550 water leak and freezing
Seems to be a common problem with these units. You can get a drain tube heater ( got mine from an online refrigerator parts distributor), though may not totally solve problem. Some suggest running a copper wire through tube - supposed to conduct just enough heat to keep tube from freezing.
Sep 05, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
454 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
