Question about Back to Basics BPE3 Blender Express 2 Speed Blender
The lid/blender blades is stuck on to the jar.
My lid/blender blades is stuck on to the jar. Any suggestions on opening it. I have been trying to open it for 5 days. I have soaked it in hot water. Put it in the refrigerator to make it cold. I have tried a gripper pad. My hand hurts! Someone please help!!
Thank you for any input you can give me.
  • Anonymous Mar 07, 2009
    i'm going thru the same thing!!!
  • Bee wise May 05, 2016
    Hey, everybody this actually works!!! Take the lid that is stuck to the jar to a machine shop and use their metal clamp which is usually bolted to an industrial table to hold down the lid while you twist the jar left!
  • 8,596 Answers
Apply vinegar to a rag and a couple of q-tips - use the rag for any exposed areas, and use the q-tips to let vinegar drop into the hard-to-reach areas. You tried everything else I would have suggested.
If all else fails, break any of the parts on this list an reorder them :-) :
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=3659&linkon=subsection&linkid=120&secid=53
-Tha Mp3 doctor
Posted on Mar 25, 2009
    New Friend:
Take a spoon. try to put in the space available under the jar and pull it / move it. it will come out
Posted on Apr 27, 2013
How to open nutribullet jar stuck on blade base?
try heating the jar with hot water before removing it
Jun 30, 2014 | Magic Bullet Nutribullet Blender
Blender glass jar is leaking at base
It will either be the rubber gasket (it goes between the glass jar and the blade assy) or it could be a worn bearing/bush around the chopping blade shaft. Replace either the gasket or the blade assy.
Apr 02, 2014 | KitchenAid 5-speed Blender With Glass...
Blender does not blend, only buzzes. So I took the blender jar off the motor base and tried running it. It ran just fine. Put the jar back on the base and it only buzzed. Figured a piece of frozen fruit...
Smart move. The blade assembly is almost frozen and the motor does not have enough torque.. You need to remove the blade assembly and completely clean out the bearing and reassemble after the Mr. clean operation. A lite dab of oil is also called for.
Sep 10, 2017 | Oster 006832000000 10Speed Blender
GE single serve blender 898679--need replacement plastic gasket for grinding jar. I am told by Walmart, where I purchased it, that I need to return it. I don't want to return it. The blade chewed up the...
I had the same issue. i took the gasket from the other blade to use with the blade i use everyday. one trick is, don't remove that gasket to clean it but make sure it stays in there. Just soak it and scrub it good, to make sure it stays seated in there.
If the gasket comes loose while you are grinding, the lid will come loose in the base and sometimes causes you to not be able to get the jar from the base. you have to turn the jar the opposite direction to get the lid to tighten up, then you can remove the jar from the base.
I am trying to get replacement jars since those plastic nobbies that run the blender have broken off. It is down to one of 3 nobbies, so it can't be run anymore. I mght just have to buy a brand new blender but it seems so wasteful.
Mar 15, 2011 | GE Blenders
We own a kitchen aide blender and it has started to leak. This jar does not come apart. do we need to replace the jar?
The Instruction & Recipe booklet for the Kitchen Aid KSB550, KSB560, KSB570, KSB580 5-speed Blender can be found here:
http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209709225.pdf
There is no infomration to suggest that the blender blade could be removed for replacement of a seal
On page 27 of the pdf (page 24 if printed) there is contact information for ordering replacement parts. You might ask if the blade assemly can be ordered and replaced separtely but I believe you must replace trhe blender jar and blade unit as one piece.
Mar 13, 2011 | KitchenAid KSB560 5 Speed Blender
How to replace glass jug
Watch this video. If your jar has a lid that screws in rather than pushes in you unfortunately have to purchase a new lid, blade, gasket and collar.
May 08, 2010 | KitchenAid KSB3 Classic Work Top Blender
I have a Waring Pro Speciality Blender. After only a few times in use, the jar began leaking and I noticed glass shards around the outer rim of the jar. The blades are fixed on this model. I wrote to the...
If you don't see a physical crack or stress line on the jar, the issue could be either the gasket or blade assembly - Waring doesn't list any parts for sale for this model, but you may be able to call them and get these parts. There are not very many reviews on this particular Waring, so I am working with very limited information (and this is just my opinion), but the few that I have seen suggest that this might be the worst blender Waring ever made (in general, though, their blenders are usually top-notch).
Consumer Guide generally rates it high, but issues this:
"Cons: Strong churning motion requires you to hold the lid in place to prevent leakage through the top and limits the ingredients capacity, especially for hot mixtures"
The sites that invite the most user input into the rating generally give it a 2-star rating.
Waring seems to have escaped somewhat from their usual blender shape - and I have even heard that the shaft is made out of rubber, which is frightening.
Mar 31, 2009 | Waring RB75 Specialty Blender Stainless...
Back to Basics BPE3 Blender Express 2 Speed Blender Logo
3,143 people viewed this question
Top Back to Basics Blenders Experts
Mike
Are you a Back to Basics Blender Expert? Answer questions, earn points and help others
