I dont hav a remote for my sylvania sdtv and i cant find the aux channel to veiw my dvd player manually
    Scholar:
  • 142 Answers
Sylvania is a branch of North American Phillips...Phillips\Magnavox\Sylvania are all the same. If you can't find one that will work you might try tritronicsinc.com to order a replacement remote. Usually a universal remote doesn't give you access to the menu or changing inputs. Good Luck!!
barneyluc
Posted on Oct 03, 2008
Sylvania tv/vcr/dvd keeps going from channel 3 to AUX
Hi my name is Mike Houston of DISH Network, with the TVswitching between channel 3 and AUX there are some things to check to resolvethe issue. You will want to make sure all connections are hand tight from thereceiver to the TV and to the wall. After all connections are hand tight checkto see if the channels are still going back and fourth. If it still persiststry changing the remote address, I will send a link that better explains thissetup; http://www.dishnetwork.com/SupportSection/remote-setup
Nov 26, 2011 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
Lost our original remote and now cannot get into auxillary manually. Cant find a universal remote that works. Please help! Many people on this site say there is someway to get it to AUX setting manually...
Try connecting this TV to a VCR or DVD player. Then press channel two and continue to press channel down. See if this will work. Also...if you have an older model Emerson TV remote, it will operate the Orion TV. Let me know if this will work!
Dec 12, 2010 | Orion1934 19" TV
I tried connecting a simple dvd player to the
get an universal remote control....look for the code for the tv...and u can get the tv working.........
Oct 06, 2009 | Sylvania 6413TC 13" TV
We cant get the aux channel so we can watch a dvd or vhs
The "Game" or "AV" buttons on a remote usually switches the signal sources from antenna to RCA or AUX IN function. If you have lost your remote, there are many cheap remotes that have the AV or GAME button with the codes for your TV. These codes are normally in the little manual that comes with each remote so be carefule not to throw it away with the packaging. Hope that helps.
Jul 11, 2009 | Sylvania LC320SS8 32 in. LCD Television
Tv works great, dvd is new , cant figure out the right hook up , dvd has 3 cables white yellow red
Red = right sound channel, white = left sound channel and yellow = video (picture) channel. if you have the connections matching these on the tv, then there should be an AV channel on the remote/tv control panel. Select this channel to view, if more than one AV channel on the tv, there will be a number next to the sockets you plugged into. Select the AV number and away you go.
If your tv doesn't have the correct sockets you can buy a converter to use the ariel socket on the tv.
May 28, 2009 | Televison & Video
Cant program direct tv remote with my new sylvania lc320slx
The remote is only programmed with only so many codes. Sadly, It doesn't hold all code for every TV made.
But you can try making the remote search every code stored inside to see if one of them will work.
Here are the instructions form the DIRECTV web site:
You may still find a setup code that works for your device by stepping through the library codes in your remote. The following instructions will help you do this.
StepNSet
  • Set the "Mode Switch" to the desired mode such as TV for a Television.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the code "991" followed by the "device number"
    1. for Televisions
    2. for "AUX 1" devices - VCRs or DVDs
    3. for "AUX 2" devices - Audio
  • You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
  • You can try out each code by pressing one or more function keys such as power, volume or digit keys.
  • When you've found the setup code that works for your device, press the "Select" key.
May 18, 2009 | Sylvania LC320SS8 32 in. LCD Television
Need the remote code for a phillips dvd player
These are the codes printed in the owners manual for your dvd/vcr player.If they do not work you will have to contact Emerson and ask them for help getting the code. The contact number should have come with the instructions for the remote. Just give them the model number of you remote and the units model number and they should be able to help you. I hope this information helps you with your problem. Switch the input selector on your TV to an appropriate external input channel (usually near channel 0).
Press a button on the TV’s original remote control that selects an external input channel until the DVD
recorder’s picture appears. Check your TV owner’s manual for details.
Admiral
Curtis Mathis
GE
Hitachi
JVC
Kenwood
LXI-Series
Magnavox
AUX
LINE1, LINE2, 00, 90, 91, 92, 93
INPUT, TV/VCR, 00, 90, 91, 92, 93
INPUT, AUX
VIDEO, VIDEO 1, VIDEO 2, VIDEO 3
AUX
00
AUX CHANNEL
Input Mode Names for Common TV Brands (Example)
Panasonic
RCA
Samsung
Sanyo
Sharp
Sony
Toshiba
Zenith
TV/VIDEO
TV/VIDEO
VIDEO
00
VIDEO1, VIDEO2, VIDEO3
TV/GAME
00
Apr 25, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Unable to turn on video mode without remote. I dont have remote
Who the hell builds a TV w/o a AUX or video button on the TV.... i hate this darn sylvania...
Jan 10, 2008 | Sylvania 6419TC 19" TV
Viewing vcr
Aux is used for a buncha reasons, video, dvd, etc.... How is your video connected to your TV? Many TVs have a remote control button to change input, or TV/VCR button, try tapping that if you've got it. need the model of the TV if not applicable
Jan 08, 2008 | Sylvania SST4322 32" TV
Emerson VCR and new TV don't hook up
hey i sort of hav the same problem except, i cant access the "channel" with my sons game stuff on it
if i click menue then it just givs me "Picture" "Channel Set" "Language" "V-Chip Set-Up" "Captions" and if i click channel set i get "CH{TY}" "CH{CATV}" "CH{DTV/TV}" and v-chip asks me for an access code. and i got this tv from a friend and he lost the remote. i only hav an iO Digital Cable remote. help me plz
Oct 28, 2007 | Emerson EWD7003 DVD Player
Televison & Video Logo
194 people viewed this question
Top Televison & Video Experts
