Question about LG Televison & Video
My LG 50' Plasma TV has continuos visible vertical line in the middle of the screen. I have tried to change channels and different inputs sources but the line still appears. It appears as a red verti
  • LG Master
  • 8,617 Answers
I will need the model number of your set to assist you with the most probable cause of the problem.
Posted on Dec 14, 2011
  • Joel Sande Dec 14, 2011
    Product model number is 50PG3000-ZA. Product Code :50PG3000-ZA AEKLLMP. Its an LG 50in Plasma Screen TV. Thanks for your prompt response. Hope information above is sufficient.
  • callum price
    callum price Apr 30, 2014
    LG50PC56 , has 8 pink vertical lines on screen most visible when on blue background , any help would be great
SOURCE:
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
Jan 16, 2016 | LG Televison & Video
Vertical green line
? 4:45
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
LG plasma 50 inch tv with a fine vertical black line in the center of the screen that runs from the top of the screen to the bottom
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | LG 50PG20 50 in. Plasma HDTV
Sony plasma 50 inch has lines in the middle of screen
It sounds like a bad plasma panel but I would have to see a picture to be sure
Oct 19, 2008 | Televison & Video
50" LG Plasma - Thin red vertical line in middle of screen
I work for a auth LG service center and each time I have had this symptom we had to either change what called the T_CON control board or the Plasma display panel itself. You need to cocntact LG @ 800-253-0000 report your problem and they will find a service center in your area you should have 1 year warranty parts and labor.
Feb 11, 2008 | LG 50PX4DR 50 in. Plasma TV
LG 42 PLASMA
check all inputs on tv ,also check if menu on tv is working ,make sure lines arent being produce by another source, cable box etcc..If menu and or OSD are affected .Then there is a good chance you have lightning damaged some where in signal section on tv .
Dec 03, 2007 | LG 42PX5D 42 in. Plasma HDTV
Got a blue vertical line on me plasma
I had the same problem, a vertical blue line from top to bottom on my samsung TV.
Try this download this http://www.jscreenfix.com/video.php i burned it to a dvd and it fixed it within a minute.
Nov 07, 2007 | Samsung HPN5039 50 in. Plasma HDTV
A 12" high by 4" wide block of colored vertical lines in middle of screen
I have the exact same problem as sal1965. Does anyone know which circuit board may have a problem?
Aug 16, 2006 | Samsung PPM50H2 50 in. Plasma Television
Televison & Video Logo
1,547 people viewed this question
Ekse
