Question about Bosch Washing Machines
I am getting a e 04 error code on my washing machine
  • elizabethdmc Feb 27, 2009
    quick mix load, stopped, beeping, E04, won't spin, water left in drum
    Sergeant:
  • 409 Answers
this can happen due to the following:
you either have a faulty control board
or
you are using too much detergent. the machine things that it's overfilling. keep in mind that you should be using an He detergent for your front loading washer.
Posted on Oct 03, 2008
What does error code E7:04 mean? Quicksmart 7.5 kg frontloader
To stop the sound, touch any button and perform the following steps:
  1. Turn your machine off at the power point.
  2. Wait one minute and turn it back on.
  3. Check your machine is correctly leveled .
  4. Remove your wash load.
  5. Perform a 'Rinse' cycle.
  6. If the fault re-occurs repeat steps 1 and 2.
https://removeandreplace.com/2015/12/07/fisher-paykel-aquasmart-top-load-washing-machine-error-codes/
Dec 15, 2017 | Washing Machines
My ifb washing machine top load is got error in timing display as number 4
If the error comes up as E:04, then that is an error code that the washing machine is overloaded.
Try this:
Remove the clothes from the washing machine.
Unplug the machine from the power receptacle for 1 hour.
After 1 hour, plug machine back in and run the machine without the clothes in it until it completes the cycle.
On the next load, do not load the machine with as many clothes.
Please reply to me if this works.
Thank you!
Jun 13, 2016 | IFB Washing Machines
Error code 141. How can I fix it?
Bosch error code 141 Washing Machines Questions ... - Fixya
www.fixya.com > Forum > Tags > error code 141 > Washing Machines
Bosch washing machines error code 141 related questions and answers. Ask your Bosch questions. Get free help from washing machine experts.
error code 141 Washing Machines Questions & Answers ...
Washing Machines error code 141 questions and answers. Ask your error code 141 washing machine questions. Get free help, advice & support for popular ...
Zanussi Washing Machine Fault Code Reset - iFixit
https://www.ifixit.com/...Washing+Machine+Fault+Code.../34977
iFixitMy Zanussi Washing Machine hasn't been working properly for a while. then it stopped spinning and emptying, then wouldn't go through the programmes at all.
[PDF]TOP LOADER Automatic Washing Machine - you
Dec 29, 2015 | Washing Machines
What is error code E04 on hoover washer
E:04" on the washing machine. Check to ensure there is no water in the tub. This is a common error often associated with too many suds blocking the pump. It is caused by using the wrong laundry detergent which is not designed for high-efficiency washers. You can adjust your use of detergent and reset the machine to eliminate the error code.
Read more : http://www.ehow.com/how_10038363_reset-bosch-washing-machine-error-e04.html How to Reset Bosch Washing Machine With Error 04 eHow
Jun 21, 2015 | Hoover Washing Machines
Code f2-02
I don't know exactly what the Machine's Make & Model # are that go with the error code above to help give an answer that is specific to you. Please go to this link to view an excellent video to help explain to you how the front load machine works. You can also order new parts through them also!
The link is; http://www.repairclinic.com/RepairHelp/Washing-Machine-Repair-Help
Good Luck!
Rich Lilja
Washing Machine Repair Help
Apr 01, 2014 | Washing Machines
A code of f-04 keeps coming up
This error code is indicative of a programme module/heater error
Aug 25, 2009 | Hotpoint Aquarius WD640 Front Load...
Error E;04
Located front down on right hand side. Remove cover gain access to water pump.
Jan 31, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Error F 04
im not up to speed with the codes. BUT if you are able to open the door this suggests the bulk of the water has pumped away, so I suspect motor or belt problems. Can you hear the motor spinning when it should be? ie on spin cycle. If not suspect carbon brushes in motor, or even a broken/burned out wire to motor. Replace belt if broken
Oct 15, 2007 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
85 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
