Question about Troy MIG100 90-Amp. Wire Feed Welder
Suggested oxygen pressure
I haven`t set up or used a mig machine in years. What is the suggested pressure for oxygen when welding aluminium?
  • familysize Oct 07, 2008
    Thank You very much. I used to build nice stock trailers in Ok lahoma City. They were all alum. Like I told you, it was years ago. I thought it was 20psi, but wasn`t sure.
First of all good luck welding aluminium with a mig no disrespect intended but your gas pressure with change depending on the place you will be welding at 20psi is a good starting point
Posted on Oct 03, 2008
Best settings for mig on aluminium Lincoln sp170t
depends on the material thickness and wire in use for the welding
there are plenty of books and u-tube videos to help with getting the correct wire feed settings and voltage and current settings
It all comes down to operators experience and ability to use the welder correctly
Aug 16, 2017 | Lincoln Welding Tools
I can turn the welder on and it can run all day but when I start welding with in a minute the overheat light will come on and it will stop feading wire. I'm trying to weld on mid temperature.
Have you checked so see if your power cable is the right size?? Is it a 220 or 110? If it is 110 then it will cut off after it gets hot, if it is 220 and the power cord is too small then the machine will be trying to pull more amps than the cord can handle causing it to overheat and shut off.. My husband has been a welder for 20 years.. I'm just passing along what he suggested might be the problem.. Hope this helps!
Oct 03, 2015 | Millermatic 212 907405 Auto-Set Mig Welder...
Suggested setting for rossi mt 200 welder
read you hand book on the settings but it all depends on material thickness being welded
higher volts = higher amps will require faster feed speeds = thicker materials
sheet metal thickness (.040"-1mm) will require very low volts -up to 20 v with a slower feed speed
remember the unit will have a very short duty cycle and that means that you cannot start a weld and keep it going for many minutes especially at high amps
it works like this ,if it is a 20% duty cycle ( on the plate of the machine then for every 20 seconds of power ( high amps) the machine has to rest for 80 seconds
if you are welding panel metal the ( very low amps) then you can weld for longer periods but the rest period has to be 4 times the weld period
Jul 04, 2015 | Welding Tools
I have a mishto 220 mig tig mma I can get the arc to work fine but the mig there's no arc at all the machine sounds like its welding but no arc at the gun I'm using gassless wire I thought it may be an...
They told me at welding school the mig transformer has a different slope (whatever that means?) to the tig and mma transformer so I am a little surprised at your question. The implication is two transformer are needed for the three types of welding and for tig and mig a dc converter and also for dc mma welding.
From your description it seems as though welding current is not arriving at the tip of the mig torch or the current is arriving in the wrong form.
You say the mma is fine but you didn't say whether it is fine on ac welding, dc welding or both. I have not tried mig welding with ac and have no idea whether it would be successful but I imagine a lot of sparks and not much welding. The problem could be the rectifier unit is either not working or is switched out of the circuit.
Polarity is important too with dc tig and mig welding.
I hope this provides food for thought.
Feb 04, 2015 | Welding Tools
Why does wire weld to tip when trigger is pulled when welding aluminium
The tip of the welder may need cleaned out, your feed speed might need slowed down, check the polarity is it straight or reverse?
Sep 20, 2014 | Welding Tools
Machine makes a grunting sound and dims the lights in the shop
sound like your welding rectifier has blown, take cover off find rectifier usually large aluminium plates remove and insulate 1 cable from transformer then test if all is ok rectifier has gone
Aug 16, 2013 | Welding Tools
I have a lincoln weld pack 100 hd, and i want to weld aluminum but i dont know how to start. i buy a 4043 fil d aluminium mig and i dont know if my welder it ill be fine to weld,
you can weld aluminum with the lincoln but you will need to change the liner in the wand to a nylon one and swich the gas to 100% argon and of course change the wire to an aluminum roll. and practice-practice-practice it is much more difficult to weld aluminum then steel and requires much more control.
Feb 03, 2011 | Lincoln Welding Tools
Welder probems
a mig welding unit of 100 amps is very low, you will require a small wire size, plus the contact tip, liner to suit, expect to get a maximum amperage of 70- 80 amps max, if the unit is Aluminium wound transformer then expect 6 months use, and the ampage will drop ,then its scrap, depending on the weather conditions that the unit is kept, will depend on the live of the unit.
Dec 30, 2008 | Welding Tools
Mig gas pressure
15 PSI is the absolute MINIMUM flow rate you should use on ANY project.
35 should be the max required without physical shielding. If he is good at what he does, he may feel the need to stick with what he knows for good shielding/penetration/ and quality. You are the boss, and he should be supbordinate to your requests. If all else fails, comprimise on 25, and lock-tite the adjustment knob!
Also, your welding supplier may have a handy dandy reference chart for regulator settings based on material and wire you are using.
http://www.millerwelds.com/resources/improving-your-skills/mig/
Research a little here for guides and reference materials.
Nov 30, 2008 | Troy MIG100 90-Amp. Wire Feed Welder
Mig Question
MIG stands for Metal Inert Gas welding, many times called Wire-feed.. Also referred as GMAW (Gas Metal Arc Welding). The "Metal" refers to the wire which is what is used to start the arc. It is shielded by inert gas and the feeding wire also acts as the filler rod. A semi-automatic process, it is fairly easy to learn and use.
Aug 27, 2008 | Lincoln Electric LINK2400-+1 CV-305 MIG...
Troy MIG100 90-Amp. Wire Feed Welder Logo
157 people viewed this question
Top Troy Welding Tools Experts
Bill Boyd
Are you a Troy Welding Tool Expert? Answer questions, earn points and help others
