Question about Bugaboo Frog Stroller
Put the wheels in wrong
Howdy,
I made a massive booboo, I put the swivel wheels in he wrong way. (I didn't notice the DO NOT DO THIS picture in the instructions till after the mistake) Has anyone else done this and what is the solution, the wheels seemed to be jammed real well and I don't want to break anything.
Thanks for the help
  • 3 more comments
  • mmilch7 Nov 06, 2008
    i put the swivel hubs in the wrong end of the socket. What do i do???? Please help!
  • famoust Jan 29, 2009
    honestly- i can imagine half the people with the frog end up putting the swivel wheels in upside down...
    so how do i get them back out again? i cant see anywhere to put a screwdriver,let alone a fancy re-do button!!
    PLEASE help!!!
  • Anonymous Apr 29, 2009
    I have the same issues--but I don't know where to insert the screwdriver.
  • rfreire May 03, 2009
    I have the same problem, can anyone tell me if the suggested solution worked? Or did you try anything differente?
    Many Thanks
    Ricardo
  • ecbizzle May 11, 2010
    same problem any other solution to the backwards wheel problem?
  • 13 Answers
Yes I've seen these before the best thing to do is to use a skinny flat srew driver through the reverse and try to push the wheels tab in and pull on wheel at the same time good luck hope you resolved
If any other question you can e-mail me at bugabooexperts@yahoo.com
Thanks, Nathalie
Posted on Dec 07, 2008
Very simple... get light so you can see ... shine light in hole in the back... use butter knife to pry the little tab back... pull on wheel...
Posted on Jun 06, 2009
Just wanted to add a little more detail because I was still somewhat unclear about the previous solutions. You need to shine a flashlight into the end where the wheel was supposed to be inserted. You must use the flashlight because you may not be able to see the tabs even in a well lit room (because the tabs are black, and btw- there are two tabs!)....use a butter knife to push each tab in while pulling lightly on the wheel. You will feel a pop as each tab is pushed in, and it will come out very easily. This worked best with two people- one pulling the wheel while the other person uses the knife to push the two tabs in.
Posted on Nov 23, 2009
Stiff wheel
Hi Kristia
We would recommend you contact Bugaboo for assistance.
Bugaboo UK
Aug 20, 2013 | Bugaboo Baby Gear
Just bought britax blink, i wrongly placed the 1 front wheel in which the swivel lock was trapped at the back. can i still remove that wheel and put the swivel lock at the back? how? thanks
I did the same thing! Trying to pop the wheel off at the top joint with a flathead screwdriver was going nowhere.You probably got your answer by now, but I figured I'd post here for any future peeps. I called Britax customer service and it took talking to two people, but the second told me the secret!
Put the stroller on its back and look at the very bottom of the wheel assembly. You'll be able to see two small plastic "prongs" that you should be able to squeeze gently with some pliers and POP the whole wheel will come right off! Then it's easy to flip the swivel lock to the front and put the wheel back on.
Mar 14, 2011 | Britax Blink Umbrella Stroller - Double...
We put the swivel hub into the wrong end of the sockets
I'm assuming you put the front wheels on from the wrong side. You need two large screwdrivers to slip down between the top stub of the wheel and the tube of the frame to press the two tabs in to release the wheel. I use a short piece of pipe that slips over the stub and pushes the tabs in.
Feb 18, 2011 | Bugaboo Frog Stroller
Swiveling Problems
Sounds like a loose bolt. Check under the front of your foot protector.
Sep 29, 2009 | InSTEP Safari TT Single AR165 Jogger
Remove the swivel wheels from the bugaboo frog
should be a small metal circle you push in and then pull the wheel off . probably in the back
Jul 07, 2009 | Bugaboo Frog Stroller
Bugaboo frog stroller- front small wheels put on wrong way. how do I get them out without breaking them?
get flash light and butter knife... shine light through back of where you have your wheels... use knife to press tab back and pull on wheel.
Jun 03, 2009 | Bugaboo Frog - Aubergine Stroller
Self- reboots at start-up, then shows picture but with pink dots.
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM811, CM812, CM817 & CS806; 1000ufd 25volts. It is the board to the left and you notice that the four cap tops are swollen.
It is easy to replace get a stanard solder pencil and you are in business.
Thanks for using FIXA, BIG IRISH.
May 24, 2009 | Samsung LNT5265F 52 in. LCD HDTV
Blue instead of red colour afer replacing lamp in sharp xv-z2000
You didn't put your 3-D glasses on backwards, did you? :)
Seriously, if you are using the component inputs, be sure the three cables didn't get mixed up when you put the projector back. Otherwise, you might have an issue with the color wheel inside the projector, but I doubt it.
Dec 31, 2008 | Sharp XV-Z2000 Multimedia Projector
Problems with releasing front wheel lock
I have just fixed my stroller which had a similar problem. The wheel was still swivelling but it was sticking slightly. I noticed that the pin that locks the wheel in place was half out and therefore the wheel was getting caught on it. I undid the nut that holds the end of the wheel lock cable in place and tightened this as tight as I could which pulls the pin back into place (making sure that the switch is in swivel position). I then put the washer and nut back on (making sure cable was as tight as possible).
May 30, 2007 | Zooper Boogie Jogger Stroller
Bugaboo Frog Stroller Logo
349 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
