Question about Refrigerators
Whirlpool S21S4D two door plumbed in fridge with ice maker etc. Alarm keeps going off and fridge cutting out.
  • kaz_taz Dec 30, 2008
    freezer keeps loosing temperature and alarm goes off. Fridge side is staying the same on the front of the temperature panel, but when tested with a thermometer, it is gaining temperature.
  • RicCutamora Apr 28, 2009
    Yes we have the same problem - the ref keep on going off and on, and we are still waiting for whirlpool, to fix it for the last two months.
    Ric Cutamora,
    Blacktown, NSW
3 Suggested Answers
  • 1126 Answers
SOURCE: Whirlpool S21S4d - How do i use the ice maker function?
http://shared.whirlpoolcorp.com/product_literature/search.jsp
If you have more model info. try this link.
Posted on Jul 11, 2009
iwillfixforu
  • 619 Answers
SOURCE: Whirlpool S21S4D Ice maker stopped working
You have a defrost problem going on. Either the defrost timer, the defrost t-stat or the defrost heater. Remove the back freezer wall and you will see the evaporator coils. This is where the heater and t-stat are located. One of these is more than likely the problem.
Posted on Feb 04, 2010
Testimonial: "We have just looked at the recommendation and it looks like the heater is not working properly! Will source the part tomorrow. Well done Fix Ya"
Door alarm doesn't work
The sensor is got faulty,which triggers the alarm or its wiring is got loose.Also see if the freezer or fridge component got over freezed with ice modules.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Whirlpool WRF560SFYM 19.6 cu. ft. French...
My whirlpool frost free fridge freezer's alarm keeps going off, ice-cream doesn't freeze?
Check condenser is clean, fans working, thermostat set correctly, try to check internal temp with digital thermometer
May 17, 2012 | Refrigerators
My s21s4d fridge ice maker doesnt work, everything else is ok. the motor on the ice m/c doesnt seem to reset itself. how do i fix it.
Hi and welcome to FixYa, I am Kelly.
This appears to be a Whirlpool side by side unit. Commercial Code 858618353010 / Model S21S4D. If I got the brand incorrect please respond with your brand name.
I do not know your geographic location. I am assuming you are outside of the US.
There are a couple of troubleshooting links I will post here. Keep in mind that they are for US units but the only difference will be the operating voltage:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34 This is for the BASIC ice maker without optics.
And Job Aid R-92 (With optics)
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Note there are 2 different optics for these. Pre and post 2002. You will have to determine which one you have. The troubleshooting steps require that you TAPE the door / light switch in the depressed position. Ensure you read all of the set up steps.
Often ice makers stop cycling because the ice maker thermostat never reaches 14 - 16 Deg. F due to a problem with automatic defrosting. Ice builds up on the evaporator coils and air-flow in the freezer gets restricted. It will still freeze but won't make ice until the ice build up is excessive.
If you think you may have an automatic defrosting problem do a MANUAL defrost with an external fan by turning the unit off, removing the freezer contents and directing an external fan into the freezer compartment for just over 2 hours. (water mess so be ready)
While the fan is melting the ice in the freezer compartment... open the lower rear of the unit by removing the fiberboard cover and cleaning the condenser coils, condenser fan, the drip pan and the ver end of the compartment drain tube that terminates in the drip pan. Reinstall rear cover when complete.
After the 2 hours clean up the mess and return the unit to normal service. The unit should start making ice within 8 hours. It will operate normally for 2 days and then if the automatic defrost problem exists... ICEMAKER and freezer performance will degrade after 2 - 3 days.
Hopefully you have enough information now to troubleshoot your icemaker issue.
Thanks for choosing FixYa,
Kelly
Sep 09, 2011 | Refrigerators
Hi, i have a whirlpool american style fridge that beeps etc.
its the compresor packed up,,,if this compresor is not pumping freezer gas around the pipe work the freezer wont work sorry but a new compresor is not a cheep thing to have fitted as it will need a re-gas as well
Jun 29, 2010 | Freezers
Frigidaire alarm for fridge keeps beeping
I would try switching the breaker. That will probably work.
May 15, 2017 | Frigidaire 22.5 Cu. Ft. Counter-Depth...
Whirlpool S21S4D Ice maker stopped working Now fridge stopped working Frezer OK Defrosted ice on condenser and fridge working for time being! Do you think its the mother board?
Feb 04, 2010 | Refrigerators
Whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted
whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted. the temp display on freezer shows - - flashing
May 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
403 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
