Question about GE Heating & Cooling
Ac keeps throwing reset switch in plug
My AC reset switch keeps throwing when I plug it in. Any idea on causes?
  • 23 Answers
Bad cord, if on window unit.
Posted on Oct 03, 2008
If my freezon would be low then why is it very cold air when I'm going on the road
because the temp difference between the hi and low side will be greater faster than a normally charged system the reason it cycles off is the keep the evap. from freezing up, but running to low on Freon can cause poor lubrication in the compressor causing damage to the compressor, yes it will blow very cold for a short period of time with a low charge
Oct 14, 2015 | 2004 Dodge Neon
Receiver keeps going to standby
I don't know about the newer receivers but this sounds like an arching OFF/ON power switch that was a problem on Pioneer receivers years ago. I would bypass the switch and see what happens.
1. Unplug unit from wall.
2. Jumper two wires going to off/on switch using alligator clip with insulated boots on clips.
3. Plug amplifier into disconnected circuit breaker/fuse protected AC strip.
4. Plug AC strip into wall outlet, turn AC strip switch ON and see if problem disappears.
Feb 20, 2013 | Insignia 200W Stereo Receiver
My window ac was leaking water and ran down wall and got the plug wet. we have tried drying it out with hairdryer but when we plug it in the reset button keeps switching. do i need a new ac or can i buy a...
It's hard to know which one needs replacing, without testing the outlet first. Unplug the AC unit and outlet in a lamp or some other electrical appliance to see if the outlet works as it should. If does function correctly, then the problem is in the AC unit. But, buying a new power cord will probably not solve the problem. More than likely, one of the circuits or sensors in the control panel got fried, when the water got into the outlet and shorted it out. That's why the reset button n the cord won't reset.
Depending on the age of the uni, you may want to consider having it repaired, rather than replacing it. But, if it's 5 years old or older, I'd opt for replacement.
Now, lets address what caused the problem. Either the drain hole in the drip pan was clogged and or the rear of the AC unit did have enough downward tilt. The general rule of thumb is 1/4" to 1/2" rear downward tilt. This allows the water collected in the drip pan to flow to the rear of the unit and drain away thru the drain hole. Whether you repair or replace the unit, keep this in mind.
I hope I was able to help you and thanks for choosing FixYa.
Aug 22, 2011 | Heating & Cooling
Cannot turn on my laptop only the start button light turns on but no screen display and a few noises help
This is only the first of many things you may need to do to determine the fault. But it is a process for determining the exact cause.
Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
If everything is plugged in correctly and it still will not power on, follow these steps to complete a 'power reset' of the notebook.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
May 15, 2011 | Acer Aspire 5500 5570-2609 Laptop
I have a question on Coleman AC
First of all, an extension cord and GFI receptacle to run an AC unit will almost always blow either GFI or circuit breaker or both due to large current draw from AC unit. If an extension cord needs to be used, keep it as short as possible, and use the heavier gauge that is approved for AC use. What happens when you use an extension cord, is the voltage drop that will happen by the time the AC gets power. With any voltage drop, the amperage draw increases, so a 15 amp circuit breaker will most likely trip. Nowadays, all AC units are wired with a minimum 12 gauge wire rated for 20 amps.
You say nothing is happening now, is that to say that the fan only mode doesn't work on the AC unit either?
Apr 26, 2010 | Dometic Rooftop RV Air Conditioner
Hi I have a sharp portable AC unit model CVp 10lc works for 1hour
I have the same problem. I have only used my unit 3 times. It keeps "triping" and shuts off. Also, I smell a plastic burning smell and the plug gets very hot.
Apr 02, 2010 | Sharp CV-P09FX Air Conditioner
Cannot engage RESET Button on plug to power the 220v AC unit
The reset button is a voltage leak detector it is possible the unit has a short in it or the cord has a short
Apr 28, 2009 | Heating & Cooling
Worked fine yesterday, today zilch !!
One computer I fixed had its internal power regulation confused. With the AC adapter plugged in, holding the power switch down for twelve seconds, then pressing it again, switched it back on. This sort of problem can come from a variety of causes, though. There is an internal power distribution chip which could have received a static electric shock or power surge and gotten cooked. The RAM could have gone bad. The socket where the adapter plugs into the computer could have been cracked loose. Check the power switch and then RAM first, and write more if that doesn't fix it.
Jan 05, 2009 | Toshiba Satellite M105-S3041Notebook
Heating & Cooling Logo
170 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
