Question about GE Spectra JBP78 Electric Kitchen Range
Is audible and visible arcing inside the coil switches acceptable?
As the stovetop coils go on and off, the contacts inside the switches arc visibly and audibly. This appears scary. Is it a threat? Should they be replaced?
  • 750 Answers
Hello donna h57
welcome to fixya
You said,
This is dangerous!
DO NOT USE THE RANGE!
CALL service.
BEWARE: Danger of shock or electrcution!
Thank God you asked me and did not wait long!
I wish I was there hands on to help you.
Please be careful!!!!!!!!!!!!!!!!!!!!!
Huuum
Please remember to leave a rating before you go!
Posted on Oct 03, 2008
Kitchen aid stand mixer has sparks inside when on
Where do you see the visible sparking?? There are two places in the mixer where this could / should happen. One is at the brushes where they meet the commutator on the armature of the motor. I don't think you can see that place during operation unless you have the rear cover off and know just how and where to look down the tube of the motor head. The second place is at the rear of the machine at the copper contacts on the speed control switch. You can see in the machine during operation at this location. You should not be overly concerned about this...unless...you are seeing constant arcing, then you need a new speed control switch as the resistance (amount of metal to conduct the electric current) between the contacts is worn down. This will cause a constant arc and will eventually wear down and then freeze closed and ...Walla! the mixer will not work any more and it can short out the rest of the electrical in the mixer. So; if you are seeing short intermittent sparks at the rear of the machine , well no worries, if it is constant then replace the speed control switch if it is anywhere else it is an electrical short and that can be very dangerous indeed. Tell us where you are seeing the sparks...and we can FixYa.
Oct 18, 2014 | KitchenAid KSM150PS Artisan Series Stand...
Why does circuit breaker spark when turned on?
Under most conditions, sparks occur between contacts of switches, circuit breakers, etc. during the split instant between fully closed and fully open positions (these sparks are really refered to as arcs or arcing). This instant is the point when the full pressure of the internal spring-loaded mechanism that is pushing or pulling contacts together or apart; is not yet felt. This pressure is usually felt only in the fully closed or fully open positions.
The brightness and duration of the arc is directly tied to the amount of power is being switched and the condition of the contacts themselves (contacts become pitted and dirty over time and arcing becomes more noticeable). Many larger switches and circuit breakers employ specially engineered arc flash suppression techniques and materials as the intense heat from the arc is destructive to ordinary insulated switch materials. Ordinarily, the arcing should not be visible to the naked eye.
Here\'s a video of an incredible arc at a power switching station when the switch is opened.
Jan 13, 2013 | Electrical Supplies
2001 gmc jimmy cranks but wont start
Any fault codes?
Do you have fuel pressure?
If not, check relay, check to see if the tan wire in the relay connector goes to ground initially for priming. If not check harness for damage. If yes, initially then no after a few seconds replace the oil pressure switch.
Are you getting spark?
If you still have the distributor: check condition of cap and rotor and center button of cap. The button should extend at least 1/8 inch out (usually more) , these can break.
If still no spark, check for primary voltage at the coil. If that is okay, check for continuity across the inductive pickup, these wires are known to break. If that is okay, replace ignition module.
If you have the coil packs, try having someone start it at night while you look at the various parts of the ignition system for arcing. The carbon tracking is not always visible but the arcs reveal a great deal at night.
If it still refuses to start inspect the wiring harness for damage. Especially to the injector wires.
Jan 18, 2012 | 2001 GMC Jimmy
When im going down the road my 2004 pontiac hesitates you have to give it more gas
tune up, maintenance and likely an air filter required
Most new vehiclwes have a hesitation but if it is a definite lag then try the above
Jun 11, 2011 | 2004 Pontiac Grand Prix
Spark plug wire boot grounding out on coil, 96 outback 2.5 automatic, just put new spark plug wires, new spark plugs, and new coil on. ran great for two weeks, now spark is jumping out of boot at coil on...
Hi Solarstarene.
It sounds like the rubber boot is not completely seated or there is a small crack in the boot itself. This will cause arcing to the nearest ground when the vehicle is put into gear. Try removing the wire and turning the boot about 180 degrees to see if this will stop the arcing. I would replace the wires with a better set, preferably from the dealer even though they cost a little more. Hope this helps.
May 15, 2017 | Sport & Outdoor - Others
A miss in a 2001 ford focus
Replace spark plugs first then look for white arcing marks around coils and ignition leads, replace if any arcing marks are showing.Could run car at night and look for any electrcal tracking around coils and leads much more visible in dark condition.
Apr 20, 2010 | 2001 Ford Focus
Runs like ****, backfires and chugs, no power
Several possibles: Plug wires arcing (run engine in a very dark area and open hood to see is there is arcing) Bad coil (same test look for arcing sometimes you can hear spark jumping) Distributor cap arcing inside or outside ( remove cap and inspect for carbon tracks inside cap). Module inside distributor bad (not too expensive to replace). Lean toward wires or coil.
Dec 03, 2009 | 1989 Chevrolet S-10 Blazer
TV won't turn on
You probably have a high voltage arc in your set. Probably the flyback transformer arcing. Stargazer
Apr 21, 2007 | Sanyo DS27800 27" TV
GE Spectra JBP78 Electric Kitchen Range Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
