Question about Car Audio & Video
Powers isnt turning on but everythings hooked up?
Ok so i was driving my car and the bass stated to fade out as if i was turning the car off. but then it ddnt come back onn. so i stopped and everything seems to be connected ok. the rca and the rem seem to be connected and the power. there is some noise from the speakers so i know the rca cables are good but im not geting the power to turn on. what should i do? i was thinking its the rem cable so should i disconnect the battery then redo the rem connection or is the amp just bad.oh and the amp was pretty hot when i touched it cause i thought that it could have been over heated but its cooled down and has not gotten any better.
    Scholar:
  • 142 Answers
Check the fuses. If the fuse is bad the amp's power supply is burnt. If the red light stays red and never goes green then your amp is in protect mode and the output section is burnt.To test for rem. problem just use a jumper wire (paper clip... or whatever)to jump from +12v power to rem. If rem. wire has no voltage when your radio is turned on that will make your amp come on. then look for the fuse in the rem. line. Good luck !
barneyluc
Posted on Oct 03, 2008
So i have installed my amp, epicenter, all wiring is done, hace great ground.. But once i turn my car on to sound check everything starts fine but after turning up the volume a bit.. My amo goes into...
It sounds like you have your gain to high. best way to solve this is by turning the gain way down to - or lowest number , then turn everything on and upto the volume you desire, then slowly up the gain. also avoid using bass boost, I agree it sounds great but it puts strain on the amp and shortens life in the amp. with the bass boost off, you can adjust others (not the gain) to get bass.
Hope this helps
Jan 26, 2013 | Car Audio & Video
I have 2 12in kenwoods and a 1200 watt pyrimade amp, how can i hook these up to be the loudest
1st have your subs facing inwards towards the front of the car, not facing out the boot, This creates a better bass.
Wire 1 sub to one channel and the other sub to the other channel.
Turn down your gain as low as possible and then power everything up.
turn volume to desired loudness and then start turning up the gain slowly, if distorts a little turn in back down a notch.
avoid using bass boost, I agree it sounds great but it puts more strain on your amp and shortens its life.
after sorting out your gain, tweak all others until sound is bassy and clear with no distortion.
If you would like to use bass boost, turn on bass boost first, then up your gain etc.
Jan 16, 2013 | Pyramid PB915X 1200 Watts 2 Channel...
Need to know how to adjust bass, treble, fade, etc. on Alpine model CDA-7862
Press the MODE knob to choose between bass, treble, balance, or fade.
Turn the MODE knob to change each setting as it is displayed.
Mar 15, 2011 | Car Audio & Video
The amp worked fine for about a year then one day the bass would not play through my subs properly sounding like a cd skipping only with the bass i would turn volume down and it would work fine until a...
When you hooked up your amp, did you hook it directly to the head unit so that it didn't come on with the car? Did you find the inline fuse in the amp positive cable? Few things to check..
Jul 13, 2017 | Kenwood KAC-6104D D Class Mono Power...
Wire hook up for radio
Your going to have to run a constant power source to your unit to maintain the memory. I would suggest running it to the fuse box located on the Drivers side. Hope this helps
Djmike
Oct 30, 2008 | 1992 Jeep Cherokee Sport
Sony amp 1000w
Check the wiring of the speakers (both inside the box and between the box and the amp). It sounds like one speaker is wired incorrectly at one connection point.
Sep 09, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Setting low pass and bass eq
Hello, i have a hifonics brutus also, in the manual it states to set the eq at half way, so that there is no clipping or at least to prevent clipping , the eq will make the bass punchier, if you do go pass half way, i would recommend to readjust your gain settings, also check your head unit settings and make sure everything is flat, bass, mid bass etc. example i had my eq past half but i had my gain at mid way, it was hitting hard, then i tried turning the eq all the way down and the turning up the gain and the bass was smoother so it depends where you set it, and what settings you have on your head unit tone control (bass, treble etc)
May 15, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Amp LED light turns on then off
You need to use a multimeter to confirm that you have both B+ and remote voltage at the amp.
Oct 28, 2007 | Sony XM-2200GTX Car Audio Amplifier
LIGHTS ON BUT NO BASS
Is the master/slave switch set to master? Have you tried feeding the signal into a different amp to make sure that there is signal reaching the amp?
Sep 18, 2007 | Car Audio & Video
30 seconds down the road and no bass and lot of smoke
Well, it burned up. Too much power.
It is repairable, however, that is not covered by any warranty.
Oct 19, 2006 | MA Audio HK2000D Car Audio Amplifier
Car Audio & Video Logo
438 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
