Question about Ovens
"F1" DISPLAYED AND BEEPING
I HAVE AN ELECTRIC OVEN AND "F1" IS DISPLAYED ON THE CONTROL PANEL WITH A CONSTANT BEEPING SOUND. I HAVE ATTEMPTED TO TO DISCONNECT THE POWER AND RESET IT WITH NO SUCCESS. ANY SUGGESTIONS
  • LJMBrannum Dec 24, 2008
    When I try to use the timer I get an F1 error message that just keeps beeping at us and we can't get it off.
  • fp1102 Mar 23, 2009
    F1 displayed and beeping. This started about two weeks ago. Model # CMEF352CFS1.
    Sergeant:
  • 409 Answers
the F1 code usually means that you have a key stuck on the keypad. unplugging it from power won't make a difference for this one. is it a wall oven or a stove? can you supply the make & model please?
Posted on Oct 03, 2008
I can't see a model no, but "Err F230 stuck key is displayed
Posted on Oct 23, 2008
  • lia123102 Oct 23, 2008
    I HAVE THE READOUT "ERR F230 STUCK KEY"
I'm getting a constant beeping sound and a F1
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced
Aug 10, 2011 | Magic Chef 9112 Gas Double Oven
Amana whirlpool oven F1 error appears and it won't stop beeping
Hello & Welcome to FixYa
Error code F1 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Sorry for the bad news but hope you understand... Please get back to me if you have any other questions.
Kevin
Apr 10, 2011 | Whirlpool RBD305PD Electric Double Oven
After the clening cycle I get the F1 code and the beeping sound.How do I turn it off?
Kevin
Mar 12, 2011 | GE Profile JTP56 Electric Double Oven
F1 and beeping sound on electric stove model FEF365BWF
Hello, the F1 and the beeping sound is as a result of the Electronic oven Control Failure (EOC), and you need to replace the electronic oven control also called the EOC or clock.
Thanks
Jun 13, 2010 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
F1 error code and constant beeping and oven shuts off.
Hi gwhiz03,
If you are having error code F1 with your Jenn-Air double wall oven this is because you have a defective touch pad or clock (ERC). This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Hope this helps.
Thank you for using FixYa.
Feb 10, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
FO error message. Oven light stuck on. No buttons work.
The F0 is a Function Key Stuck error - Replace touch pad or touch pad and control board if it is one assembly. Refer to F1 Test for more information.
How To Perform A F1 Touch Pad / ERC Test
This test is easy to perform and will help you determine whether the Electronic Range Control (ERC, control board) or touch pad is defective when the F1 code is displayed.
Note: With some models, the ERC and the touch pad are one single unit and therefore this test is not necessary. The entire assembly must be replaced.
Warning: If you have any doubts in your ability or safety of the repair, please contact a qualified appliance repair technician.
1. Disconnect the power to the range by either unplugging the power cord, or turning the power off at the circuit breaker. Always make sure the power as been disconnected properly before beginning this test.
2. Access the control panel.
3. Disconnect the touch pad ribbon from the ERC.
4. Reassemble the control panel. Make sure to check for any additional defects such as frayed or lose wires that could be causing the problem.
6. Wait up to an hour for the F1 code to reappear. This could be accompanied by an alert such as a beeping sound.
7. If the F1 code reappears, replace the ERC. If it does not, replace the touch pad.
Nov 06, 2009 | GE Monogram ZET3058SHSS Stainless Steel...
F8 Displayed
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
Apr 01, 2009 | Frigidaire 27 in. Electric Gallery Pro...
F1-->Failed Thermistor Control Replace ERC
you will have to replace the ERC or Electronic Range Control or the touch pad.
Dec 18, 2008 | Ovens
Beeping sound
Failure
Code
Condition Check/Repair F0 or F1 Failed transistor in control If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad
Mar 22, 2008 | GE JKP28 Electric Double Oven
Ovens Logo
687 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
