Question about Lexmark Office Equipment & Supplies
I am trying to print a paper. it says the printer is paused.how do i un pause it
    Genius:
  • 1,913 Answers
Go to start menu control panel printer and faxes then select your printer
right clik it then u seee "resume printing: on 4 or 5 clik on it
thats all
Posted on Oct 03, 2008
Printer won't work says it is paused
Check your settings , & unpause it !
Mar 17, 2015 | Office Equipment & Supplies
How do I take Canon imageCLASS D320 All-In-One Laser Printer off from "paused" status?
On the printer properties on the computer there will be a paused option (Normally marked as "Pause Printing") in the printer drop down menu on the Printer Queue screen. Click this to remove the tick next to it and it should start printing again.
Feb 20, 2015 | Canon imageCLASS D320 All-In-One Laser...
Printing on TEC b-572 pauses
DEFAULT SPEED IS 9600 bauds, 8 data bits , 1 stop bit no parity.
Un fortunateley the best spped avaible is 19200 bds.
The pausing is due to too much data transfered trough the serial port.
To sole this, increse tehe baudrate and use internal fonts.
Aug 06, 2014 | Toshiba TEC B-572 Printer
Epson lq-2180 printer paper out & pause Indicator continously on
I have epson lq-2180 printer with the following problem: Paper out & pause indicator is continously on when I try to print. The paper is rolling when I push pause button.
Jan 22, 2013 | Epson LQ-2180 Dot Matrix Printer
My Dell All-In-One printer is not printing at all and the paper comes out blank. I need help.
Ensure that the printer power cable is firmly connected to the printer and the electrical outlet
Determine if the printer has been held or paused
  1. In Windows XP, click Start® Settings® Printers and Faxes.
In Windows 2000, click Start® Settings® Printers.
  1. Double-click Dell Photo AIO Printer 922, and then click Printer.
  2. Make sure a check mark is not next to Pause Printing. If a check mark is next to Pause Printing, click Pause Printing to deselect it.
Check for flashing lights on the printer.
Ensure you installed the ink cartridges correctly and removed the sticker and tape from each cartridge
Make sure you loaded the paper correctly
Jan 19, 2011 | Dell 922 All-In-One InkJet Printer
PRINTER IS IN PAUSE MODE. I REPLACED AN EMPTY COLOR CARTRIDGE HOPING THAT WOULD FIX THE PROBLEM, BUT IT HASN'T. I CAN RUN A test pattern and printer willprint it out . but if i try to print an email for...
Pause is set in your computer, you have to go to control panel, printers, and then right click on the printer icon for the printer you are using. Pause is about the third choice down and you need to un-check it and that takes it off of pause.
Sep 25, 2009 | HP Photosmart C6180 All-In-One InkJet...
HOW WILL I UNPAUSED MY PRINTER?
There should be a printer icon in the notification area. You can double-click on that to bring up the printer status. If the icon is not there, you can go to Start -> Control Panel -> Printers and double-click on your printer. The first item in the print queue should be listed as paused. Right-clock on it and select Resume from the context menu.
Jul 10, 2009 | HP Office Equipment & Supplies
Paused
Go to the printer properties and un-check "use offline"
Mar 10, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Will not print test page or documents
  • Make sure the printer is turned off and the paper-release lever is pushed back to the single-sheet position. Raise the paper guide upright.
  • While holding down the LF/FF button, turn on the printer. The PAUSE light flashes.
  • Slide the left edge guide until it locks in place at the guide mark. Next, adjust the right edge guide to match the width of your paper.
  • Slide a sheet of paper down firmly between the edge guides until it meets resistance. The printer loads the sheet automatically.
  • Press the PAUSE button. The printer begins printing the self test.
  • To stop printing temporarily, press the PAUSE button.
  • To end the self test, make sure the printer is not printing. Press LF/FF to eject the sheet; then turn off the printer.
Jul 04, 2008 | Office Equipment & Supplies
Zebra 4M Plus Pauses unexpectedly
try to run the manual calibratio from the setings.
run "manual calibration"
move the ribbon out from the sensor (with the print head open) and take out 3 or 4 labels from the rollar and put that blank label paper unther the sensors on the left,
say "ok"
wen appear "reload all"
put the ribbon and the normal labels on the correct possition, and say "ok"
try to run sext the sensor profile.
save data (twice on "setup button")
tur off, and on again.
Feb 12, 2008 | Zebra Z4M Printer
114 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
