Question about Insignia 15 in. Flat Panel LCD HDTV
Schematic pointing to a video sync pulse out for the above tv.
I am looking for the schematics for this 15" Insignia TV to find a video sync pulse that I can use with a video sync sensor for on and off status tests for a IR control system. This monitor does not have a video monitor out and I am looking for the equivalent on board schematic to make this connection happen. This is not a voltage sensor, this is a video sync sensor, and no it does not work on voltage as I have already tried it...
    Sergeant:
    Champion:
  • 223 Answers
I dont know if they will have what you are looking for but try: www.eserviceinfo.com you might find it there. By the way why not use an oscilloscope? Good luck in your search.
Posted on Oct 03, 2008
Where can I get a TV schematic for Insignia NS32D200NA14 ?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Power supply schematics to many popular brand TVs and others are illustrated.
Sep 14, 2014 | Televison & Video
Mitsubishi VS-55609 top left screen has folded over
chk for any electricity or magnetic interferanc. change the location to the TV. switch of the tv fro 5 min and restart it again back.
Jul 03, 2008 | Mitsubishi VS-55609 55" Rear Projection...
Where can i find a TV schematic for Insignia NS32D200NA14
Check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Schematic insignia ns-hd2114
Hello
I've the repair manual to your Insignia set, but I can's send it to you by this window as it does not allow me to upload any files by it. If you are interested, just buy one among my services advertised in Fixya, and com over to me. OK.
Dec 31, 2011 | Insignia 75W DVD/CD/HD Radio Compact Shelf...
How to repair the tv if it no power
First take the back off and look for blown fuses; fuse should be on the circuit board close to where the AC cord attaches.
If that doesn't work, you are to a point where you need a schematic and a voltmeter.
Most all TV's use pulse power supplies today and are difficult to repair.
The power supply will go into shutdown if it detects an overload anywhere in the TV. This makes it look like a power supply problem and it may not be.
Jun 06, 2010 | Toshiba 26LV610U LCD TV
Green Display Problem
Hello vinodquilon,
The problem you described is more then likely related to the video processor. Possibly also some power supply issue, since the audio section is being effected also. Or this may be two unrelated problems in that case the video processor and the audio processor and amplifier should be suspect. This is how I would handle this problem:
1) Get the schematic for this TV
2) Tackle the video problem first
a) Locate the video processor connect a known video source generator (I use the Sencore VA62A) and take voltage measurements and compare them to the schematic values (For red, green, and blue), if the values are not as they should be, use and oscilloscope to look at the waveforms of the video section and compare them to the schematic values if they are not as they should be, change out the video processor. Retest the TV, this should take care of the video problem.
3) Tackle the audio problem
a) Using the audio section on the VA62A inject a 1000Hz tone into the TV and using an oscilloscope check the input to the audio processor and the output of the audio processor if you do not see a 1KHz sine wave on the output check the voltage levels and compare them to the schematic, if they do nor match change out the processor, if they do match and you see a 1KHz sine wave at the output of the processor, then check the input and output of the audio amplifier stage in the TV if there is no audio at the output change out the amplifier.
This is a good starting point, now I must be frank with you, I run a TV repair business and I do understand that you may not have , Video Signal Analyzer or Oscilloscope, and Video/Audio Signal generator, or even a multimeter to do this job correctly, so since I have told you how I would do this job and you can follow the instructions given and solve your problem, Let me advise you on what you should do,
If I were you and did not have the above equipment nor experience in electronics, I would take the TV to a qualified TV repair center and have it fixed there since they would have the necessary equipment to do the job properly.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jan 21, 2009 | Televison & Video
Horiz sync
take the tv to a tech the tv is haqving a problem in the power and the horizontal circuit.you can get a schematic from www.samsphotofact.com
Apr 03, 2007 | Samsung TSK2792F 27" TV
Horizontal sync
zeutaluras, My guess would be the same as yours because the horizontal osc. is synchronized when you apply the signal to the HD inputs. I am assuming the signal with embedded horizontal sync and composite video passes through the tuner boards as you mentioned. I'll confirm with the schematic once I see it. If it is a separate board can you get one to substitute? I think you may be able to locate the problem with an oscilloscope and schematic if you can access different points in the schematic. I'll try to help once I know more. My problem prevents any type of built in diagnostics since the set doesn't power up.
Oct 03, 2006 | Toshiba 57H81 57" Rear Projection...
Insignia 15 in. Flat Panel LCD HDTV Logo
165 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
