Question about NorStar T7208 Corded Phone
Change time Please I need to set the right time on my T7208 telephone user card because it does not say on the manual
  • princessammy Apr 17, 2009
    I am unable to find out how to change the time on my T7208 phone. Is there any way any of you can help me with this problem?
    Scholar:
  • 125 Answers
Hey here is something you can use to adjust the time on your T7206.To Change the Time:
1. Press the CHANGE softkey Display will read: "Hour:
2. Press the CHANGE softkey Display will read: "Hour: _ "
3. Enter the new HOUR. (in 24-hour format - Ex.: 5:00pm = 17:00. Display will then read the new Hour programmed.
4. Press NEXT Display will read: "Minutes: # # "
5. Press the CHANGE softkey Display will read: "Minutes": _ "
6. Enter the new MINUTES.
To Change the Date:
1. Press NEXT Display will read: "Date DD MM YY"
2. Press the CHANGE softkey Display will read: "Year: # # "
3. Press the CHANGE softkey, (If the year is incorrect) Display will read: "Year: _ "
4. Enter the new YEAR Display will then read the new Year programmed.
5. Press NEXT Display will read: "Month: # # "
6. Press the CHANGE softkey, (If the month is incorrect) Display will read: "Month: _ "
7. Enter the new MONTH Display will then read the new Month programmed
8. Press NEXT Display will read: "Month: # # "
9. Press the CHANGE softkey, (If the day is incorrect) Display will read: "Day: _ "
10. Enter the new DAY Display will then read the new Day programmed
Let me know how that turns out and good luck
Posted on Oct 03, 2008
SOURCE:
How do I program the T7208 telephone to display incoming telephone numbers?
I managed to find the manual, but it does not say a thing about this. I think your provider has to give you the information, with the incoming call. When he switched that information of, your phone can't display it. Sometimes the providers charge you extra for that service. If, on the same extension, another phone did display the number, perhaps hetre is a way to switch it on, but I could not find it.
The link is to the manual.
http://ipf.msu.edu/_files/pdfs/user-guides/norstar-t7208.pdf
Sep 30, 2014 | Nortel Networks T7208 Telephone
How do I remove Denied in Admin from a Nortel phone handset t7208
It's not so much removing Denied in Admin as it is enabling whatever feature the user was trying to access at that set.
Which was... ?
Aug 11, 2014 | NorStar T7208 Corded Phone
People say they can't hear me on th t7208
If there is another phone that this doesn't happen on, try changing your handset with that one. If this doesn't fix the problem it most likely is your telephone.
Sep 27, 2013 | NorStar T7208 Corded Phone
Nortel T7208 phone will not let me change password-locked
You can obtain the manual for this phone at the link below, which may help you reset the password.
http://phone.manualsonline.com/manuals/mfg/nortel_networks/nortel_business_series_terminal_t7208_nt8b26aabn.html
Cisco 48V Telephone Power Supply
Nov 13, 2012 | Nortel Business Series Terminal T7208 -...
How do I change the time on my BT T7208 telephone (Nortel Network).
1. Press Feature x x 8463 (x x TIME) you should have Password displayed on your telephone.
2. Enter 22742 (BASIC) or 23646 (ADMIN) you now should have Hour on your display.
3. Now press Change and enter the correct hours using the key pad
4. Press NEXT and you should have Minutes displayed on your telephone, now press CHANGE and enter the correct Minutes.
5. Press NEXT and you should have Year displayed on your telephone, now press CHANGE and enter the correct Year.
6. Press NEXT and you should have Month displayed on your telephone, now press CHANGE and enter the correct Month.
7. Press NEXT and you should have Day displayed on your telephone, now press CHANGE and enter the correct Day.
8. Now you will have ---End of List--- displayed on your screen, you can now press Rls or handset down button to come out of programming.
Feb 28, 2011 | Nortel Business Series Terminal T7208 -...
How to change name displyed on norstar T7208 & T7200 tele phone
To chane the name on the sets you'll need to enter telephone programming.
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number.
Enter extension number you want to change the name on.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
The display say Name.
press the Chng soft key.
use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
ex. Bill = 2,2 -> 4,4,4 -> 5,5,5 -> 5,5,5
Press the next key (bottom right arrow) to enter the name.
Press the release key when finished
Oct 28, 2010 | NorStar T7208 Corded Phone
I am considering buying a Nortel T7208 2 Line phone for my home office. I have two separate lines, with two separate numbers. I need a phone that will allow me to plug both lines into the desk top unit. I...
Hi there...
OK, the Nortel T7208 set works only on a Nortel system.
It has only one line cord plugged into it, cause the telephone system can be programmed for more telephone lines and features from the system.
If you want just a home (analog) telephone service; look at Aastra/ Telematrix/ there are others - 2 line sets.
ONLY buy this Nortel set is you have a Norstar system. Otherwise the set will not work for you. It needs a system to run off.
Good luck in your search!
Aug 29, 2009 | Nortel Business Series Terminal T7208 -...
I need to change to time and date on my T7208 telephone
On the right hand side of ur keypad there will be 8 buttons. Third button from top will be ur change button if u r using T7208 or M7208 phones.
Thanks.
Abhi
Jun 08, 2009 | NorStar T7208 Corded Phone
NorStar T7208 Corded Phone Logo
731 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Thomas F. Schneider
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
