Question about Mitsubishi WS-65315 65" Rear Projection HDTV-Ready Television
Find parts for WS-65315
Can't seem to find any parts available for the WS65315 model...I scratched the screen- not sure how deep yet- so in the meantime I am trying to find the parts- lenticular screen (491P105050), Fresnel lens (491P1060), mirror (767D048090) or the diamond shield (760D627070). Can anyone help?
SOURCE:
  • 395 Answers
SOURCE: Where to find replacement Diamond Shield at reasonable price
part # 760D627060 you can get it at www.vancebaldwin.com for $136.30 plus S/H
Posted on Feb 18, 2008
  • 2337 Answers
SOURCE: looking for parts
Go HERE to find the parts you need.
Posted on Mar 06, 2008
Slinteriors
  • 8617 Answers
SOURCE: mitsubishi diamond shield
Yes the site I work for just parted one out today they just listed it on the website today. It comes complete with lenticular screen and diamond shield. Its excellent condition It sell for 125.00 and that includes shipping and handling. heres the link.
http://servicemanuals.vstore.ca/ Its listed under mitsubishi parts.
Posted on Mar 22, 2008
SOURCE: Diamond Shield Mitsubishi 55315
if either of u r close to michigan i have the above tv with no video possibly willing to part it out
Posted on Jun 19, 2008
SD Tech
  • 14553 Answers
SOURCE: Mitsubishi WS-65313 Screen burn-in
IF you have the area on either side of the picture used in the 4x3 burned---it is now burnt into the phosphor of all three picture tubes this set uses.
The real problem here is most of these sets the default setting for contrast or "picture" (same thing) is 100% and this is what burns fixed images into the tubes.
Pretty stupid, but that is how they are made--the black background in later models was replaced with a light gray one to try to prevent this.
If you do not have a warranty live with it--the cost of the three tubes would be about 900 dollars plus labor to replace them and adjust the set.
It takes less than 100 hours of use with the 4x3 up to cause this kind of problem, just like putting a fixed image on any projection set with full contrast and brightness set full--the damage is permanent.
I have replaced tubes in sets like this and when you get the tube out you can see the BURN in the phosphor.
I am sorry to give you bad news but based on your description this is what you have.
If this helped you rate this solution as I do this here for free.
SD TECH
Posted on Dec 13, 2009
Testimonial: "thanks for the feedback!"
The outer skin on the freezer door is scratched. Is there an inexpensive fix to replace the outer skin on model 10651123210
If the scratch is on the smaller side and not a deep gouge, you should be able to obtain touch-up paint for the appliance. These products are usually available at Sears appliance parts depots or more generically at home improvement stores.
Jul 16, 2015 | Kenmore Refrigerators
Check this link I believe they can help you with this http://fixmymonitor.com/
Hope that helps..........
Aug 01, 2008 | Mitsubishi WS-65813 65" Rear Projection...
Remove scratches on a dlp hdtv
Scratches if deep are rarely "removed" and depending on brand and model number the screen may or may not be available as a part that can be replaced.
Seen a few with Glass where it can be buffed out but that rarely works without leaving distortion in the picture.
Dec 11, 2012 | Televison & Video
I have a mitsubishi tv model ws65315 hd1080p front screen 65in is missing .where can i get a new screen a re
Try Mitsubishi to see if even available and be prepared to spend some real money as most use three screens and sold as a set.,,,,,
Mar 28, 2012 | Mitsubishi Televison & Video
User manual for mitsubishi TV model ws65315
here it is :
http://www.mitsubishi-tv.com/pdf/ownersguides/WS-55315.pdf
SD TECH
Oct 31, 2011 | Mitsubishi WS-65315 65" Rear Projection...
WS-55313 Where can I find replacement Lenticular screen?
800-553-7278 CALL MITSUBISHI PARTS
A WS-55413 LENTICULAR SCREEN IS $171.10 + DELIVERY BUT THE DIAMOND SHIELD ISNT NEEDED THEY TELL ME AND IT WAS DISCONTINUED ANYWAYS BUT YOUR PART IS PROBABLY AVAILABLE THERE.
Nov 24, 2010 | Mitsubishi WS-55313 55" Rear Projection...
I have Mitsubhishi HD 1080 model number WS65315
Your power source seems to be the problem, replace the part (located inside the television) and the problem will be solved.
Jul 19, 2010 | Mitsubishi Televison & Video
I have an Hd 1080 series one day i was watching tv and the volume just went up on it's own i couldn't turn it down and eventually i turned it off> since it hasn't turned back on at all. if i unplug it...
Are you saying the power light blinks constantly and does not stop blinking?
The model you have indicated does not flash light three times on its own.
Confirm model number and I will try to help you--WS65315 is the correct model number?
The more you tell me the better I am able to help you.
SD TECH
Feb 16, 2010 | Mitsubishi WS-65315 65" Rear Projection...
My tv model ws65315 green ligth turns on and then turns off and the screen doesn't turn on
The TV probably has the -27 volt fuse blown. This fuse will blow when your convergence amp IC's have gone bad (STK-392-250)
Call a good TV Tech.
Jul 30, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Mitsubishi WS-65315 65" Rear Projection HDTV-Ready Television Logo
69 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
