Question about Panasonic PT-47WX49 47" Rear Projection Television
Damaged circuit board
I really screwed up. I have a panasonic PT47WX42F TV that I tried replacing the "rectifiers" on. The part number that I ordered was a STK392-110. The orginal problem was when it was torned on, a click could be heard, the screen flashed then a pop could be heard, after which the red light on the front of the unit flashed three times. I tried replacing the "rectifiiers" and tore a small strip off of the circuit board. Any ideas on where to find a replacement board or have this one repaired? In over my head.
Thanks, Gary
  • jkavasch Oct 30, 2008
    Gary-Several nights ago my PT47WX42F died without warning with same characteristics as described your post. I unstand we not exact on Mod Nos hwever close enough in described failure to catch my eye & respond. When first powered up, screen starts to light then fails & the dreaded flashing red light on dash. Would ''rectifiers'' be poss cause my screen to burnout or not have enough power to fire on startup? Is there any repair
    possible to be made by ordinary Joe or do I need bring in Wizard from Panasonic or Circ City? Are these models old enough to have these types
    breakdowns? Appreciate much any/all comments-Advice you could
    provide. James Kavasch
    Medford, OR 97504
    jkavasch@charter.net
Couldnt you just make a tracer to replace path
Posted on Nov 21, 2008
  • Panasonic Master
  • 8,617 Answers
Gary, contact the following site and leave a email as they have a remnanufacturinng process where they can remanufacture your board and repair the trace strips to like new condition, as your board is no longer available from panasonic. Heres the link. Be sure to include your model number
http://servicemanuals.vstore.ca/
Posted on Oct 03, 2008
Remote with TV stopped working for vol, AV, and mute. Only power button works. Used new Batt; no change. Used buttons on TV; none work there too. Is there something broken on TV?
If the buttons on the TV -and- the buttons on the remote don't work, then there's definitely something wonky with the TV.
The good news is that the power works and the picture looks good. That rules out a bunch of things. If you don't mind tinkering, replacing circuit boards on TVs is pretty straight-forward -- just take off the back, unscrew the offending board and replace it. You'll have to do a little research to narrow down to the right board to replace -- it might be this key controller board:
http://www.shopjimmy.com/panasonic-tnpa4280s-gs-board.htm
May 04, 2016 | Panasonic TH-50PX75U Plasma HDTV
I have a teac dle3289hd digital TV with no power to unit
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jun 17, 2015 | Teac Audio Players & Recorders
HDMI STOPPED WORKING PANASONIC TH-42PV500B
I had a same issue with my Panasonic TH-42PV500B plasma television. I tried everything which is written above and can be found on different websites. Finally I decided to replace the HDMI Board itself. I was able to buy a used one on ebay, it was only 13 pounds with postage.It is relatively easy to remove this HDMI Board. You should just unplug the TV and remove all of the screws form the back which are fixing the back of the TV to the frame. There are plenty of screws. You should remove all of them! Remove the backplate of the TV. After this you can remove another metal plate from inside, which covers this HDMI board - 4 screws. After you can remove the HDMI Board - only one screw holding it to the main board. Replace the new one back and put back the cover plate and the back of the TV. And it is working. 10_19_2012_3_10_22_pm.png Panasonic 42 Plasma TV TH-42PV500B Part HDMI Board Order number: TNPA3626
Apr 11, 2012 | Panasonic Televison & Video
Panasonis 50" plasma, both fuses keep blowing when
This is a dead short, check power supply for diodes bad or zeners
Mar 08, 2011 | Panasonic Viera TH-50PX80U Plasma TV
My circuit board has a short on the soldering for the DC rectifier that supplies the carpet cleaning motor. Where can I order a new circuit board. Miele S251i
Just a suggestion, but you could try to re-solder the connection on the board. some of the circuit boards did not have enough solder on the board coming from the factory.
That being said, if the component is damaged due to the burning, I suggest you contact your local Miele dealer and have them order you a circuit board for the unit.
IF the unit is less than 5 years old as well, that part should be covered under warranty. Do NOT solder it, just have them replace the part.
Good luck
Nov 19, 2010 | Miele S251i Plus Bagged Canister Vacuum
Philips 14pt1686/05s Distorted audio
Hello
Distroted sound may due to some fault in the speaker or its ouput stage inside your TV. You jsut open your TV and unsolder the wires from speaker, and solder it to an other speaker and see whether the sound is normal or not. If it is normal, you can make sure that the speaker of your TV has damaged.
Other reason is of some fault in the output section of your TV, which is integrated on its circuit board. You just locate the audio output section on the circuit board. it will be an Ic that drives the speaker. It can be located very easly following the speaker wires. usually it is screwed on to a metal plate, and will have a number printed on it. Sometimes there may be some bad solderings on its leg solderings. You just resolder all the pins of that Ic by applying a little more solder to its points, and see the effect.
If this cannot rectify the problem, just resoder the Ic out from the cirtuit board, and go for a same type and number. Replacing it will solve your problem. Ok
Nov 14, 2010 | Philips 14PT1686 14" TV
Panasonic 50 Plasma TV will not turn on and red light blinks 10 times.
Found thsi list two different places:
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
Oct 27, 2010 | Panasonic Televison & Video
I have the same problem Panasonic Plasma TV wont come.
Alot of times capacitors on the power supply circuit board will go bad. They will bulge/dome or dry up which will cause this problem. Bad caps dont hold a charge, which is needed to maintain a voltage. The circuit board is two sided which makes replacing the caps difficult, and the board can be damaged and have to be replaced. Taking it to a repair shop may be cheeper and safer then doing it yourself. Having two-six caps replaced is a lot cheeper then a new board.
Aug 15, 2009 | Panasonic TH-42PX60U Television
My pt47wx42f model panasonic tv attempts to turn but fails
Thats the error code for the convergence. You can get the convergence repair kit for your model at www.tvrepairworld.com the kit contains the parts and detailed instructions on how to install the kit.
Aug 08, 2009 | Televison & Video
When i switch on my digital Panasonic TV (Model TX-32LMD70)using the remote control from standby (red light showing) the green (on light) flashes and then nothing happens i.e. the television does not...
Is your TV still under warranty? This problem seems common on this site with the Panasonic brand. I really can't say what exactly is causing this problem, but it seems like something in the power circuit board is faulty. My advice would be to call Panasonic's Technical Support Hotline and speak to a Technician. It could even be a problem that has warranted a recall of that particular model. The number for Panasonic's Hotline is 1-800-211-7262. Or, you can contact them via e-mail @ www.panasonic.com under "Get Support". Hope this helps...
Sep 08, 2008 | Panasonic Televison & Video
Panasonic PT-47WX49 47" Rear Projection Television Logo
116 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
