The heating light stays on. When you set it on a full cup of coffee, you only get a quarter cup.
The 'Descale' light that turns on indicates that it is time to de-scale the machine.
Scale - or mineral deposits- form from the water you run through your
Keurig coffee machine. If not cleaned regularly, the buildup can clog
the lines in your machine and ruin the heating element. The manufacturer
recommends you descale Keurig coffee makers once every six months for
normal water conditions and once every three months if you live in an
area with hard water.
You will need :
Instructions :
6
Unplug the machine and dump the water into the sink.
7
Fill up the reservoir with fresh, clean water and plug it in. Place the ceramic cup back on the drip tray and run multiple brews in order to rinse the machine of any remaining vinegar residue.
Just have in mind that :
Some Keurig machines come equipped with a red warning light to let you know when it is time to descale your machine.
You may need to refill the water reservoir a second time and run additional cups through to rid it completely of the vinegar residue.
Never submerge your coffee machine or the electrical wires in water---it can lead to electrical shock.
Do not use a "K" cup when descaling; use only a ceramic cup.
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
