Question about Garden
Toro lawn tractor : tractor will not start
Tractor has a new battery. but when you go to start, nothing happens ,not even a click. We had starter tested ,it;s ok.
  • 1 more comment
  • aldozac Apr 05, 2009
    When I turn the key on my tractor, nothing happens for a second or two, then sounds like it is straining to start cranking, then starts a full crank and turns over. Changed the battery and did full tune up, but it is still doing it. Wires all seem ok. Is the starter going bad??
    Al
  • Anonymous Mar 17, 2014
    have a craftman lawn tractor hp16 modle no. 917273351 has new battrey and starts up, but when I cut off have to jump start it. need to know why
  • Anonymous Mar 26, 2014
    cicking sound,slow starter,will not start sometimes
    Scholar:
  • 62 Answers
On most riding mowers there are several switches that must be actuated before it will start. First, make sure that blades are disengaged. Also, if there is a handle that engages and disengages the blades, you might try holding it in the dis-engage position in case the switch is out of adjustment. There is probably one under the seat also. This switch kills everything if you are not sitting in the seat for safety reasons. The switch here could be out of adjustment or mis-positioned. Also, make sure the parking brake is set, and the gear is in neutral, and not forward or reverse. Also, even if the parking brake is set, you might try pressing the brake all the way down while starting, as this switch might be out of adjustment. All of the switches should be easy to locate and adjust. Also, you should check the battery. It is possible that you left the key on by mistake and drained it.
Hope some of this helps.
C
Posted on Oct 07, 2008
With key my riding lawn mower does not start, not even crank. Nothing happened.
Are you positive that the battery is fully charged? If so check for current reaching the starter motor. If current is there then it appears that the starter motor is no good. If no current reaches motor it is possible the ignition switch is no good.
Aug 27, 2015 | Craftsman Garden
Toro lawn tractor starting problem
both of the small wires to the solenoid go threw safety switches start with the one on the clutch/brake pedal
Jun 09, 2012 | Garden
Where is the fuse box on the toro lx 425 lawn tractor
MOST LAWN TRACTORS DO NOT HAVE A FUSE BOX. SEE IF THERE MAY BE A IN-LINE FUSE.
May 26, 2012 | Toro Garden
Toro/Wheelhorse Tractor wont start
AS YOU HAVE CHANGED ALL OF THESE COMPONENTS TO NO AVAIL IT HAS TO BE A BREAK IN THE WIREING ITSELF, YOU WILL HAVE TO FOLLOW THE WIREING WITH A MULTI METER TO FIND WHERE THE POWER IS LOST.
May 02, 2012 | Echo Garden
Tractor will not turn over even with new battery
try taking the spark plug out and spinning it over, it your still not getting anything does it even make a noise when you turn the key if your hearing a click and nothing else you could have locked up motor, a bad starter solenoid, or a bad starter, let me know what happens
madminibiker@gmail.com
M.Woodring
Apr 19, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
HOW DO I TELL IF ITIS SOLENOID OR STRATER BAD ON MY SEAR LAWN TRACTOR?
you can check the starter by removing it and using jump cables to the body- and starter terminal to +. still there are the saftey switches in the picture when on the tractor. if you have a bad switch then it also wont start.
Jul 21, 2009 | Toro Lawn Mower With Toro Power Tools
Toro lawn tractor
There is a switch on the seat and one on the brake pedal
May 31, 2009 | Toro Lawn Mower With Toro Power Tools
Turn the key for electric start,nothing happens
If you never used the starter,You need to have it checked, possible that it i froze up. Or brushes in starter arn't making contact. Also check connections. Good Luck
May 19, 2009 | Toro Lawn Mower With Toro Power Tools
Replaced battery for lawn tractor and nothing happens.
You probably just blew the fuse behind the ignition or the fuse link on the power to solenoid.
May 16, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
755 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
