Question about Mitac Mio P550 GPS Receiver
Mio p550 wireless N security connectivity problem
Have just upgraded to wireless N and now I cannot connect my p550 wirelessly. If I remove the security settings it works but as soon as I add a password protect I cannot connect, even though I have put the password into the Mio under connection setting. This device did work with my old wireless B router and secrity passwords. Any ideas?
  • jpmose9 Feb 23, 2009
    i cant get my MIO P550 to connect to my router
Had the same issue with my Mio P550's using an Airlink680W Wireless N Router and security mode WPA-PSK, TKIP & Password. I had to disable "Block WAN Ping" on the firewall and life is good.
BSL
Posted on Aug 22, 2009
  • ouajih_badre
    ouajih_badre Feb 06, 2013
    where to disable it on mio or on the router ??
I have a mio p550 pocket pc and I'm having trouble getting it to go online.its says I'm connected but I can't open any search pages or get to even google.any help
Connect with Our Customer Support team by dialing toll-free number +1-800-204-4427, and instant solution regarding your query.
Apr 19, 2017 | Mio Computers & Internet
I turn on my device and it only loads up the start page and then hangs there .......
First try a reset... then try turning off the little power switch next to the reset, then turn it back on. If none of this works, your firmware is likely corrupted... then: You either need to return it to Mitac or locate (Google) & flash the firmware file into the unit as follows:
Connect the mio p550 to PC
1.put the Button of the PDA in ON position
2. hold the joystick downward and press the reset button
3.choose "Image Upgrade tools"
4.choose "0=Image by USB"
5.intall the usb driver (PC require the drivers). The driver in the
folder "USB driver" that comes with the firmware file.
6.open the software "dnw5.0e" (also comes with the firmware package).
7.(if you want to make a test of connection USB, click the "USB
port/Status". If all is ok go to step 8
8. click "USB port/transmitted" and to show the way of the file
"MioP550 - Osc260A R05_P09.nb0"
9.press the reset button to restart the mio p550.
Jul 09, 2010 | Mitac Mio P550 GPS Receiver
I formatted my p550 and I don't know how to bootup or reinstall the O/S
You'll need to find the firmware (ROM) image file (Google) and then: Connect the mio p550 to PC
folder "USB driver"
7.(if you want to make a test of connection USB, click the" USB
port/Statute". If all is ok go to step 8
Feb 22, 2010 | Mitac Mio P550 GPS Receiver
I have a Mio P550 Digi walker. How do you open the battery chamber in order to change the battery? Many thanks cacameron@btopenworld.com
I removed the rubber infill that covered a hidden screw. Released screw and then removed back plate. Removing the battery then required care as it is stuck with two sided tape to the Mio internals. Here I used a knive to prise/cut free.
Sep 14, 2009 | Mitac Mio P550 Pocket PC
How to connect Mitac Mio P550 to a PC?
if you have xp you will need to download microsoft active sync from www.microsoft.com and if you have vista you will need microsoft sync centre, these will be the latest versions and should work fine good luck
Aug 08, 2009 | Mitac Mio P550 Pocket PC
Mio p550 not recocnized sd cards
Try this : Open your device ( it have 5 screws). Inside next to the sd card reader are two metallic sponges. Take them off ( they are glued on some electronic parts and it's shorting the circuits)
Mar 13, 2009 | Mitac Mio P550 GPS Receiver
MIO p550 will not turn on
hi
i think you must know the difference between hard and soft reset.
soft reset is the small hole you put the edge of your stylus to reset the device without erasing anything. (software restart)
hard reset (hardware restore) is:
switch the on/off slider button to OFF. keep the joystik pushed UP and without leaving the joystick slide the from OFF to ON and wait about 30 seconds.
do all that while connected to the power charge. I'd prefer you do that with a wall charger, and not with a USB cable connected to your computer (we dont like this charging state from USB ports)
let me know what happened after that. if possible, upload a video showing us what you did.
thanks
Gery
www.nextlab.co.il
Mar 02, 2009 | Mitac Mio P550 GPS Receiver
I have a Mio digi walker p550 pocket pc with gps and windows moblile software. The problem is that it won't start up at all. The start up screen comes up but it won't initialize. I've tried connecting to...
It sounds like the device is not reading the ROM card at all. This most likely is not a home type fix. Check your warranty and see if there is a solution there.
Nov 30, 2008 | Mitac Mio P550 Pocket PC
MIo 168 can't turn off flight mode
anyone resolve this I have the exact same issue with my 168 !!
Jan 04, 2008 | Mitac Mio 168 Pocket PC
Mio p550 USB devise not recognized.
Try a other usb cable had same problem new cable fixed it of other device
Nov 09, 2007 | Mitac Mio P550 GPS Receiver
Mitac Mio  P550 GPS Receiver Logo
1,109 people viewed this question
Top Mitac GPS Experts
Ed Mac
Greg Cann
Greg Cann
Are you a Mitac GPS Expert? Answer questions, earn points and help others
