Question about Ovens
Fan assisted oven
What is a fan in a fan assisted oven used for?
  • 706 Answers
Like a clothes dryer.. simply applying heat and not moving the air will be less efficient than moving the air so the same principal applies in an oven..
Posted on Oct 03, 2008
OVEN DOES NOT HEAT IN FAN ASSISTED MODE but the fan works ok
I would suggest that the oven element is faulty
This is located at the rear of the innner oven compartment behind a removeable cover.
Mar 10, 2010 | Neff U1461 Double circotherm plus Electric...
Grill is working but oven wont heat up
You need to replace the oven element, it is located at the rear of the oven behind a removeable panel.
Please rate my sol;ution.
Thanks.
Nov 17, 2009 | Belling XOU252 Electric Single Oven
Oven not getting hot but oven fan ligth working
If it is a fan assisted electric ovenn, and the fan is working o/k, then you need to replace the oven element, usually located at rear of oven compartment.
Please rate my solution.
Thanks.
Nov 14, 2009 | DeLonghi Ovens
Fan assisted oven is not heating up
Hi.
Yes it is more than likely to be a faulty oven element, more so if the fan is workin o/k.
Please `rate my solution.
Thanks.
Jul 28, 2009 | Ovens
Fan assisted oven keeps going off ?
there is an overheat stat and this is cutting the oven off
things to check are.
is casing fan running ok? (this is the tangential fan inside the casing at the back and not the fan inside the fan oven)
this second fan is turned on by a fan stat. maybe this is faulty
is there plenty of ventilation?
is oven in fact overheating?
Oct 18, 2008 | Ovens
Fan assisted oven
i would suggest to renew the complete fan, but i found a company which sells lubricants that can bear tempratures of 550 degrees. follow this link: http://www.tomlinscientific.com/lubricants.html
Aug 16, 2007 | Belling XOU252 Electric Single Oven
Fan assist wont heat oven
the ring element may have blown. if it works ok with the top and bottom elements, (the convection oven) then it is likely the element surrounding the oven fan.
Jun 25, 2007 | Baumatic B187 Stainless Steel Electric...
Ovens Logo
61 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
