Anonymous Posted on Dec 14, 2011
Sony dav s550 dvd has no colour
Hi my sony dav s550 when i put a dvd in or even turn it on to dvd screen all i get is black and white or grey no colour atall
  • Anonymous Dec 31, 2011
    problem solved it wqas a dodgy lead thanx for ur help
theodore roberts
Level 1:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 20 Answers
  • Posted on May 19, 2015
theodore roberts
Contributor
Level 1:
New Friend:
Night Owl:
Answers
20
Questions
Helped
8888
Points
47
I'll bet even money that your problem is the crystal. It should be a small metal (usually silver) container. It will say 3.579545 MHz. Replace that and you should be back in business! They'e preity tough, but they do go out (NTSC) To piggyback Walesarumi, slightly, you can't mix equipment without adding unnecessary cost.
Wale Sarumi KomputerSolution
Level 3:
  • Master 6,993 Answers
  • Posted on Dec 14, 2011
Master
Level 3:
Answers
6993
Questions
Helped
1700117
Points
1261
Hello, welcome to Fixya!
The display setting is set to NTSC either on the TV or DVD that's why it is showing in black and white.
Check the DVD display settings and change it to Pal or auto, save and try again. Also, check the PAl settings on the TV.
If the above doesn't solve the problem,then it means there is an incompatibilty problem between the TV and DVD.
I hope the above is clear.
Re
Hi,I can play a DVD disc on the system and get sound from the surround sound speakers but I can't get a picture on the tv,Sony Trinitron.The connetions are from the DAV S500:(DVD only)red and white cable...
First try with yellow video output of DAV-S500 in yellow video TV input to get its picture. (yellow output means composite video out)
Green-Blue-Red video output is component output that will be turn on when you switch the unit into Progressive picture mode, that option would be available in Menu of DAV-S500
Hope this info will help you.
Thanks.
Sony, DAV-C770 only plays in black and white
wrong playback system selection in bouth of tv and DVD player.
please slect auto mode bouth of . and try again.
nuwan
Someone made my video dvd combo black and white
It sounds like the video out put has been set to S video,go into the hv-dx300a menu and look for the video or picture out put settings and set to VIDEO or RGB, rgb is the best if it works for you.
Hope this helps.
CABLE GUY.
1helpful
Sony dav-s550
try un plugging it for a minute ant then plug it back in holding the eject button this should bypass the play button effect and eject your dvd the only other advice i can offer is to never let your sun touch the device again
DVD plays in black and white
You better put the system into AUTO so it works properly.That's all for now Paddavis.If you question message me.
1helpful
Wiring diagram
Hi samsdad
These are what I consider to be the standard wiring colours for Sony head units. The user manual does not even make reference to installation. Bit lame really:) Good luck ....happy installing
red-ignition power
yellow-constant power
black-ground
blue-remote signal
orange-dimmer
White - Front Left +
White/black - Front Left -
Grey - Front Right +
Grey/black - Front Right -
Purple - Rear Right +
Purple/black - Rear Right -
Green - Rear Left +
Green/black - Rear Left -
2answers
Movie playing black and white
the problem sounds like its with the s video connection, try using the composite video input
NO color output
DAV-DZ3k is a good sony product especially ...famous for book shelf speakers,the problem is basically due to the cables used to connect video terminals or the TVcircuits is not proper with the av receiver.. Thank you Regards Sambhu Dayal
 Grubhead
Grubhead
SmartAviator
SmartAviator
