Whirlpool Duet washer, about 1 year old, F 70 code on display. Have tried disconnecting power, plugging back in. Have checked power supply to outlet. Have tried punching the cancel button twice and retrying. Still displaying F 70. Is there anything I can do or do I need a service call?
  • terryo_dadof Oct 11, 2008
    Ran the washer cleaning cycle and now getting F70 error
  • Anonymous Dec 21, 2008
    Same issue with Error f70.
Http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
Posted on Mar 27, 2009
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
If there is anyway i could get a free answer omg it would be appreciated! what does the error code on a whirlpool ht f 21 mean? please help.
F21 LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:After 4 minutes the "Sd" error will be displayed, then
4 minutes later the "F/21" error code will be displayed. Press
PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Mar 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader washer is no completing cycle. I see a F 02 code falshiing. How ca i fix it?
F-2 Long Drain
If the drain time exceeds eight minutes, the water valves are turned off
and "F/02" is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the "Sud" error will be displayed, then four
minutes later the "F/02" error code will be displayed.
or kinked.
make sure the pump is running.
4. Check the drain pump filter for foreign objects HERE"S HOW
I have a manual and repair photos HERE
Jan 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washergets a code 2 when it gets to spin cycle.wont rinse and spin
If the drain time exceeds eight minutes, the water valves are turned off and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the display. NOTE: After four minutes the “Sud” error will be displayed, then four minutes later the “F/02” error code will be displayed.
1. Check the drain hose and make sure it is not plugged or kinked. 2. Unplug washer or disconnect power. 3. Check the electrical connections at the pump and make sure the pump is running. 4. Check the drain pump filter for foreign objects. 5. Plug in washer or reconnect power. 6. If the above does not correct the problem, go to step 7. 7. Unplug washer or disconnect power. 8. Replace the pump.
Apr 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Code reading f 21, whirlpool, front loader, washer, duet sport
NOTES:After 4 minutes the “Sd” error will be displayed, then
4 minutes later the “F/21” error code will be displayed. Press
kinked.
Mar 03, 2010 | Whirlpool Washing Machines
Whirlpool Duet Washer error code A10
Motor Control Unit (MCU)
Heat Sink Thermal Trip
If the thermal protector on the MCU heat sink gets too hot, it will open
the thermal protector on the heat sink which will stop motor functions
and an “F/10” will be displayed.
1. Check for proper installation, verify the unit is not located
near a source of heat and has proper ventilation.
3. Check wire harness connections to the MCU, the motor,
and Central Control Unit (CCU).
4. Check the drive system for any worn or failed components.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
Feb 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Have error code of f 02 showing up on my duet. It is not finishing spin or drain cycle?
display.
or kinked.
Nov 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet front load washing machine stops in mid cycle
F21 = LONG DRAIN ERROR
If the drain time exceeds 8 minutes the water valves turn off. After 4 minutes the “Sd” error will be displayed, then 4 minutes later the F21 error code will be displayed.
Press PAUSE/CANCEL two times to clear.
Procedure:
5. If the above does not correct the problem, go to step 7.
6. Unplug washer or disconnect power.
7. Replace the pump.
Alternative Procedure:
If the machine cannot be forced to its diagnostic mode then:
1. Disconnect the washer from the power supply and water supply.
2. Remove the top panel by taking out the three screws in the back of the washer. The pressure switch is right on top.
3. Remove the Molex connector from the water level switch / pressure switch.
Refer to the picture below.
4. Reconnect the power supply but not the water supply.
5. Power the machine. The machine will enter diagnostic mode.
6. Power off the machine.
7. Replace the water level switch / pressure switch.
8. Reconnect the water supply.
9. Power on the machine it will work without error
Oct 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
640 people viewed this question
Top Washing Machines Experts
