Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE SSS25KFMD SIDE BY SIDE
Replace Icemaker wr30x10093. Works for one or two cycles of ice, then unit
freezes up at refill cup/hose. Suspect system is allowing water to come in slowly which then freezes the cup/line. Is there a solenoid for this?
  • GGTW Oct 13, 2008
    I replaced the water valve and it fixed the ice maker problem (freezing up of the line or freezer water in the water cup before it goes into the cube making chamber.
    . I changed the filter to get a little more water flow from the water dispenser. Thanks
  • 120 Answers
You might have a bad water valve that it wont close since your just repl ice maker then try to repl water valve at back if is leaking then the fill cup will be full of ice and also it will be over filling the ice maker mold
Posted on Oct 12, 2008
Troubleshooting a GE TPX24 icemaker
a19e2387-1433-4c2d-bb46-e670a2bac700.jpgSimple if the ice maker is not filling with water after cycling then fill ice maker until full allow water to freeze and if the ice maker drops the ice into the ice bin and then does not refill with water replace the=> WR57X10051 Water Inlet Valve If the Ice Maker does nothing with ice still inside the ice cube slots then replace the=> WR30X10093 Ice Maker Assembly These ice makers are electronic and once they fail there is no replacable parts. I am here should you have questions, Thanks Sea Breeze
Jan 13, 2013 | GE WR30X10093 Refrigerator Icemaker Kit
Our refrigerator stopped making ice. The water comes out fine. How do we correct this problem?
There are two sides to the water control valve=> WR57X10051 Dual Water Control Valve It's possible the side for the ice maker has failed. Try filling the ice maker with tap water and allow it to freeze. If the ice drops after freezing and the ice maker does not refill this will point to needing replace the WR57X10051 Dual Water Control Valve If the ice maker does nothing then that points to the ice maker itself=> WR30X10093 Ice Maker Assembly I will be here should you have questions, Thanks Sea Breeze
Jun 05, 2012 | GE Adora (DSF25KGTBG) Side by Side...
Why did the ice maker stopped making ice
You have two sides to the water control valve so look inside your ice maker and see if after the last ice harvest your ice maker refilled with water. If half full or empty try filling the ice maker with tap water up to the top of the the ice maker. If the ice maker dumps the ice after the water freezes then does not refill with water this will point to the WR57X10051 Dual Water Inlet Valve If the ice maker does nothing once filled with tap water will point to the WR30X10093 Ice Maker Assembly and will be better to repace. I will be here should you have more questions, Thanks Sea Breeze
May 20, 2012 | GE GSS25SGMBS Side by Side Refrigerator
Icemaker wont harvest
if you press the arm that slides out to feel the ice all the way in three times within a few seconds, this should start a harvest cycle. If it does, then you know it can cycle and you have a temperature issue.
your ice can freeze even at 25 degrees, but it won't harvest unless it is getting to about 8 degrees or colder, so check the temps in the freezer
Apr 17, 2012 | GE WR30X10093 Refrigerator Icemaker Kit
GE TFX24E side by side refrigerator, ice maker won't fill with water.
Hi, I have a GE TFX24E refrigerator. The ice maker is not filling with water. I replaced teh water valve with no joy. If I pour a cup of water into the dispenser the ice maker will freeze and harvest the ice. Any ideas? Is there a replaceable water fill sensor?
Sep 03, 2011 | GE WR30X10093 Refrigerator Icemaker Kit
I have a ge sig=de by side refrigerator and it has
Your model came with an electronic ice maker. If trays are empty tour on and fill with tap water. After it freezes if it cycles and dumps but does not refill with water the the problem will be the side of the water control valve on rear of the refrigerator that controls the water to ice maker. If the water freezes and does nothing then you may need to shop around for a new ice maker. Part number is WR30X10093 for the Ice Maker and WR57X10032 for the Water Control Valve. Let me know what you find or ask questions, Thanks, Sea Breeze
Dec 19, 2009 | GE Refrigerators
Icemaker water overflows into freezer
the condensate tube is run incorrectly on this model and goes uphill into the area above the refrigerator where there is a condensate pan. This will plug and back up and cause this problem. I have fixed ours several times but it always came back. The last time I bought a new clear plastic tube and reran the condensate out the back of the refrigerator and down through my floor. It's all downhill now and seems to have fixed the problem.
Nov 28, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
WR30X10093 Icemaker problems
Remove the white plastic cover. Upper right screw sideways with + and - on the head. This is the fill adjustment.
May 10, 2009 | GE Profile PSI23SGR Arctica¿...
Water seems to be flowing into icemaker fine. When I turn on the icemaker the water flows for a few seconds then stops, I have waited to see if the cycle to dump works and it seems as if it never attempts...
If your freezer temperaures are good i.e. it freezes ice cream and the like, then you need to replace trhe icemaker. Typically, under normal conditions, the icemaker would dump a load of cubes @ every 1-1/2 hours. Icemaker part number WR30x10093 @ $148.00 from Marcone Appinace parts or AP Wagner
Apr 09, 2009 | GE Profile PSI23SGR Arctica¿...
Icemaker does not make ice after first harvest.
theres whats called a cam inside of the ice maker and that is more than like;ly the problem. you can but your own ice maker from place like first service. good luck.
Jan 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
564 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
