Question about RCA RS2664 Shelf System
CD Player shelf will not open.
There are no cd's in the shelf system and the screen reads no cd's. When I push the buton to open the shelf - nothing happens. I have tried unplugging the power.
  • questdiva Oct 04, 2008
    I cannot open the disc player - no instructions please help just purchase this system
  • 905 Answers
The door could be stuck or the cd laser mech. is stuck or the power circut for the motor that opens the door or the motor has become weak or ect..... there are many posibilitys but you need to listen for the motor sound or a click when you hit the button , if you do hear it then its stuck or the motor is to weak and needs to be replaced , or the circut isn't giving enough power to the motor
Posted on Oct 06, 2008
  • jason Nov 01, 2008
    if its not opening then you need to take it to an electronic repair shop , before any more dammage is done
    electech
After moving doors willnot open
Koss XJ310 Shelf System Door not open - Questions - Fixya
www.fixya.com > ... > Koss > Koss XJ310 Shelf System
Question about Bang and Olufsen Audio Shelf Systems ... ...not opening. sign on screen,is flashing door.after pressing select button,sign disappears.door does not open The ... The cd player will not open when you press the open close button.
cd player door opens closes itself Audio Shelf Systems ...
www.fixya.com > Forum > Tags > cd player door opens closes itself
Get free help, advice & support for popular audio shelf system brands. ... CD player model SA248 the doors opening and closing mechanism does not work. ... flashingdoor.after pressing select button,sign disappears.door does not open The .
JVC MX-K30 CD Shelf System Cd door not open ... - Fixya
www.fixya.com > ... > JVC > JVC MX-K30 CD Shelf System
Question about Philips Audio Shelf Systems. 1 Answer · CD player door not opening. CD player door not opening when pressing cd open and closing select button ...door.after pressing select button,sign disappears.door does not open The .
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
When CD and DVD players stop working, its usually because of the drawer not opening and/or shutting ...
Jan 05, 2016 | Audio Players & Recorders
Question about Philips MC-50 CD Shelf System When I push the cd open-close buttons on the player, the disc tray does not come out. When I select a CD# it says reading, but nothing happens. The player
You have to fear a mechanical defect. In the player are gears and rubber bands involve in the open / close system. If on is defect, or even the motor is defect it won't open at all. When you don't have electronic skills, don't try this yourself.
Jan 15, 2015 | Philips Audio Players & Recorders
Wejust purchased a used Sharp CD-E67. It does not have an owner's manual. How do you open the disc changer?
two silver buttons down at bottom right under volume button the buton to the left rotates it and the other one on the right side close and opens it
Sep 18, 2011 | Sharp CD-E67 CD Shelf System
When I push the cd open-close buttons on the player, the disc tray does not come out. When I select a CD# it says reading, but nothing happens. The player indicates that there are discs in all 3 spaces,...
It is likely worn drive belts. There are 2 within this hi-fi. I replaced my belts with elastic bands. No issues so far.
1) Remove power and unplug unit
2) Remove 4 x lid screws and lid
3) Remove both side panels.
4) Remove silver plate from shielding cd drive
5) Replace belts with 25mm diameter bands
6) Reverse the strip down.
New belts are $6 each on e-bay
Jul 29, 2011 | Philips MC-70 CD Shelf System
Nothing on Radio stereo system works. The power comes on nothing plays. There is also CD jamed in the player. Where do I go from here? Emerson NR303TT serial number 61100051 CA
check to see if the cd player has a little hole next to it if it does that is a release use a paper clip to push into the hole that should get your cd out.
Mar 28, 2010 | Emerson NR303TT CD Shelf System
Cd cover doesn't open
Fiddled with it, looked at hinges to figure direction should open and pulled it slowly open. Button doesn't work but I can open/close unit. Just flips up from the front edge, doens't slide back or anything.
May 13, 2009 | Sharper Image GM402 CD Shelf System
Can not get cd player to read
optical head is burnt out i think.clean the lence before change it and try again.
nuwan
Dec 21, 2008 | GE Slim Spacemaker 7-5295 CD Shelf System
CD Changer spinning continually
i have the same exact problem with mine. what i did was manually pull open the cd deck, stop the disk carousel from spninning by holding it still, then push the deck closed. the cd deck will no longer work, but at least it stops spinning. the auxiliary works fine and so does the radio.
Feb 07, 2007 | RCA RS2652 5-CD BOOKSHELF SYSTEM Shelf...
RCA RS2664 Shelf System Logo
331 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
