Question about Samsung LN-S3251D 32 in. LCD HDTV
TV/vcr I have a brand new Samsung tv, which the company hooked up, and connected my existing VCR to I have recorded a program and I am trying to play it back I switch teh tv to the channel I am supposed to use for playback, and I get weak or no signal
  • 10,594 Answers
VCRs are usually connected in Audio-Video inputs of TVs.
Please check what input is being used in TV for VCR cable hook up at rear of TV. Select that AV input in TV by remote and enjoy.
Posted on Oct 03, 2008
I replaced my TV and now my VCR Zenith Model 2100 will not record
Digital TV can use component video and stereo connections to record on analog VCR. Analog VCR needs DTV converter to record digital TV channels. VCR play back use AV channel on TV.
Feb 11, 2012 | Zenith Televison & Video
We recently connected to Direct TV...I want to transfer some old western TV Shows I recorded on my Direct TV DVR Recorder to VCR Tape. I was told by the people at Direct TV that I would need to contact you...
You can try this: Connect your DirecTv to VCR with Red/White/Yellow cables. Then the VCR to your TV with the same type of cables. Make sure the VCR is set to the video input, not the tuner. Turn your TV to the correct video input. Get the program ready on the DVR as if you were going to watch it. Press record on the VCR and then play on the DVR. At the end of the program, press stop on both. You may have a problem with the video recording properly. Some stations broadcast with copyright protection.
Apr 12, 2011 | Emerson Televison & Video
I have purchased Samsung 550 - series L5 - I don't seem to be able to hook up the VCR to it to record. I have cable on it and I would like to be enable to record programs. Television ask if I want to...
You don't record from TV, you record from cable so cable needs to be hooked up to input on VCR.
If you don't use cable box you would hook cable to VCR then out of VCR to TV. If you use cable box then you need to connect Video and Audio outputs on cable box to Video and Audio inputs on VCR and switch input of VCR to Line input.
Feb 28, 2011 | Samsung Televison & Video
I have a new digital tv but can't get my vcr/dvd player recorder to work. Can I use the converter box on a digital tv? will it work to record and play.
The output connection from the VCR/DVD needs to be different for the new digital TV. Instead of using the RF output from the VCR, use the video and audio outputs and connect them to the video and audio inputs on the digital TV. When you want to watch the VCR, select "video in" on the TV. The digital converter box should be hooked to the input of the VCR so you can record programs off-air.
Jun 14, 2009 | Insignia Digital-to-Analog Converter for...
I have 2 DTV converter boxes - one for TV and one for VCR. The wiring is exactly as prescribed by manuals and FCC. VCR does NOT record programs from TV - altho it plays back pre-recorded tapes OK. I have...
Use only one box.
Connection should be:::Video Source(cable, antenne) connected to converter box:::::Converter box connected to VCR:::VCR connected to TV.
Try this connection and let me know how it goes.
Please rate this solution.
Lone99star
Mar 10, 2009 | Sony Televison & Video
I have a sansui vhf6010 vcr. i need to hook it up to my cable dvr to copy a recording. how do i do this? thanks!
connect the cable from the tv to the "IN" of the vcr. then connect the "OUT" of the vcr to the tv. play the program on your tv and push record on the vcr. you have to watch what you're recording, but at least it will record.
Dec 30, 2008 | Sansui VHF6010 VHS VCR
Hook-up
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
Jul 15, 2008 | Televison & Video
How to Record TV Programs w/o Cable Box/Satellite Receiver?
if there are rca ports on the front of the vcr which are output, connect those to the tv input 3, the input to input connection is definitely not going to work...
May 09, 2008 | Sony RDR-VX525 DVD Recorder/VCR
CONNECTING A VCR RECORDER/PLAYER TO A HD FLAT SCREEN TV
Now one question - Do you want to record the TV program on the VCR or Movies from a DVD plater hooked to your HD TV?
Jan 10, 2008 | Goldstar GVR-E435 VHS VCR
Vcr to tv connection
There are probably a couple of different ways to hook things up. One is you hook the VCR "in between" the indoor antenna & the set. Hook antenna to VCR RF/Ant In, then VCR RF/Ant out to the Antenna input on TV. Your VCR will then be able to record one channel, while you watch another on TV. To play back the VCR, or do any VCR setup, TV channel must be set to either channel 3 or 4. The other way is to use the Video & audio input/outputs on the VCR & TV. You will need the appropriate cable(s). Match the VCR video/audio outs with the set of inputs on TV. Video and audio out on the TV go back to the video/audio inputs on VCR. In order to view VCR playback, menu setup, you will need to select that input (line, aux, video 1 etc.) on the TV. This hookup probably won't allow the recording of a second channel while watching one. As regards the hft channels, I assume you live in an area where such is being broadcast. The TV can probably be put into a programming mode where it will scan for all available channels, and put them into memory, or they can be programmed manually.
Jun 13, 2007 | Goldstar GVR-E435 VHS VCR
Samsung LN-S3251D 32 in. LCD HDTV Logo
119 people viewed this question
Henry  Thomas
Henry Thomas
